04-11-2012, 22:50 | #46 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 3G PMIC Pinout on board! Save in PC and zoom to see each print number. |
The Following 6 Users Say Thank You to Wites OM Tesla For This Useful Post: |
04-12-2012, 13:12 | #47 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Black resin clean video! This is Paint Remover i used it acts good where is thin layer of glue you can try. Press thank if you like and forget what i say before. |
The Following 22 Users Say Thank You to Wites OM Tesla For This Useful Post: |
04-20-2012, 22:39 | #48 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 3G No Service,low signal etc Solution! If phone unlocked and antenna way ok try this. |
The Following 15 Users Say Thank You to Wites OM Tesla For This Useful Post: |
05-06-2012, 13:06 | #49 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPod Touch 4G Touch Screen Solution NEW! If other touch not help try this step by step. 6 Step only after fix but not necessary. Last edited by Wites OM Tesla; 10-29-2012 at 17:01. |
The Following 11 Users Say Thank You to Wites OM Tesla For This Useful Post: |
05-15-2012, 22:55 | #50 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 4S Battery Ways Solution! Try this if some track is broken no beep,no continuity etc. Last edited by Wites OM Tesla; 04-15-2013 at 10:56. Reason: link edit |
05-21-2012, 15:19 | #51 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 3G Dead No Power No Reaction At Power Supply Solution Dead happen after dropped replace PMIC available in ipod video and ipod touch 1G tested working no matter what number it have. Last edited by Wites OM Tesla; 11-10-2012 at 20:34. |
The Following 3 Users Say Thank You to Wites OM Tesla For This Useful Post: |
05-25-2012, 14:33 | #52 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPod Clasic some Info! Info about some components that are similar with other idevices for example PMIC like in iPhone 3G and iPod touch 1G,2 mosfet for charge prot like in iPhone 3G and 3GS only here are with legs. Last edited by Wites OM Tesla; 10-31-2012 at 22:30. |
The Following 7 Users Say Thank You to Wites OM Tesla For This Useful Post: |
06-09-2012, 13:03 | #55 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 4S USB Solution Ways. People not post here or reply i will not answer in this thread. |
06-25-2012, 11:43 | #57 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPad 2 No Backlight Full Solution! This make if you try other lcd and flex. Hi to all have made some investigation of an iPad 2 Board and made this solution. Last edited by Wites OM Tesla; 01-23-2013 at 18:45. Reason: Edit of Solution! |
The Following 13 Users Say Thank You to Wites OM Tesla For This Useful Post: |
06-26-2012, 14:12 | #58 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 4S Wifi-BT Signal Way. Here chk the signal way if you have low signal or no signal not beep,open replace components or jump you decide. By wites13 at 2012-06-26 |
The Following 9 Users Say Thank You to Wites OM Tesla For This Useful Post: |
07-04-2012, 21:42 | #59 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPad 2 No Image,White Screen,Blue Screen with lines Solution. Today i fix ipad 2 blue screen with lines someone try to replace touch or lcd problem was burn filter it showed 20OHM i replaced it from iphone 3G near dock connector FL13_AP here picture. For future do not replace touch or lcd when ipad is powered on!!! Press thanks and not forget to donate. Last edited by Wites OM Tesla; 10-26-2012 at 12:06. |
The Following 10 Users Say Thank You to Wites OM Tesla For This Useful Post: |
07-08-2012, 19:58 | #60 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 4 Sim Ways Solution! Make like this unsolder connector make jumpers then solder back connector and solder other ends at sim pins solder pads good luck. Not forget to press thanks or donate. Last edited by Wites OM Tesla; 03-18-2013 at 12:32. Reason: edit |
The Following 20 Users Say Thank You to Wites OM Tesla For This Useful Post: |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
