Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-16-2014, 15:51   #391 (permalink)
Member: 81491
Thanks Meter: 7
Hi Ernesto.
I have distroed one logic board with earlier post about removing the R1204 from it,then I read that I have to remove the R1205 ,and as I have done this I had to bypass the R1204 with the R1206, end of the day I had distroed the board. After this I restore other 2 iPads successful with the correct way.
What you have to do very carefull is to remove the R1205 on ipad 2 A1396 and just restore with the 8.1 iOS for wifi. That's it. Again dry not to touch any other resistors next to this one and remove your battery first.
Regards
The Following User Says Thank You to nikko2 For This Useful Post:
Old 11-16-2014, 16:01   #392 (permalink)
Member: 333555
Thanks Meter: 2
I did this but my ipad is not powering on
Sent from my SM-N900P using Tapatalk
Old 11-16-2014, 16:38   #393 (permalink)
ton1x's Avatar
Member: 258858
Thanks Meter: 96
Bypass iCloud Activation Lock HardWare Solution!
Plug it on itune without battery, what u got?
Old 11-16-2014, 16:40   #394 (permalink)
Member: 1444459
Originally Posted by nikko2 View Post
Hi Ernesto.
Regards
thanks! but.. i don't know how to access to this resistors... and how i can recognize the r1205??? can u post a pic?
thanks in advance
Old 11-16-2014, 16:46   #395 (permalink)
ton1x's Avatar
Member: 258858
Thanks Meter: 96
thanks in advance
U check this threat from beginning, u will get it
Old 11-16-2014, 17:22   #396 (permalink)
Member: 1444459
checked but... i can't read the "schemes" and how to disassembly to access to the mb
Old 11-16-2014, 17:25   #397 (permalink)
ton1x's Avatar
Member: 258858
Thanks Meter: 96
How u can make a cake if u dont know how to cook it.. So just leave it
Old 11-16-2014, 20:41   #398 (permalink)
Member: 1444459
ok. thanks.
just for curiosity, the resistor have to be removed by a tool?? or whaT?
Old 11-16-2014, 20:54   #399 (permalink)
ton1x's Avatar
Member: 258858
Thanks Meter: 96
ok. thanks.
YoU can remove use ur nail. Its to easy
Old 11-16-2014, 21:52   #400 (permalink)
Member: 1444459
really? OMG
I want to try! my iPad 2 it's a piece of alluminium now... so .. i don't have anything to loose ....
Old 11-16-2014, 23:58   #401 (permalink)
Member: 2293969
Thanks Meter: 2
Wow it really works!
Be prepared to buy a digitizer if this is your first time pulling an ipad apart, but aside from that, this method is confirmed working on a ipad 3 version 3 gsm. NO soldering iron required, I used a steak knife to pop the a1024 restor off the board, itunes downloaded and installed the wifi ipsw and presto I was through the gates!
The Following User Says Thank You to avaktech For This Useful Post:
Old 11-17-2014, 12:17   #402 (permalink)
Member: 2294443
Sir I am New iN tHis Forum sir pLz give me the sluTIon Ipad mini haRdwere bYpass..
Old 11-17-2014, 13:32   #403 (permalink)
ton1x's Avatar
Member: 258858
Thanks Meter: 96
1st u have to learn how to diassembly ur ipad..
Old 11-17-2014, 14:07   #404 (permalink)
Member: 2294443
ok i diassemble i pad then??
Old 11-17-2014, 17:59   #405 (permalink)
benguetcowboy1's Avatar
Member: 51716
Sonork: 100.1594676
Thanks Meter: 217
simple...........GO TO THE NEXT STEP!!!!!!! good luck!
Page generated in 0.21794 seconds with 9 queries
