08-23-2018, 21:52 | #1 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 225506 Status: Offline Thanks Meter: 31 | dead iphone 6s power supply = 4.5v vcc is ok = 4.3v Tristar 1.8v ok 3v ok 5v ok no short in vcc or bat_vcc power sup amp = 0.04a with battery and cable charging go 0.44A after few seconde go 0A and loop mainboard in normal temperature ?????????????? whats this strong problem any help please thanks |
08-25-2018, 06:48 | #2 (permalink) |
Freak Poster Join Date: Nov 2017 Location: Canada
Member: 2777379 Status: Offline Thanks Meter: 34 | First off lower your power supply to 3.8V, 4.5V is too much. If you haven't found a fault yet then what you do is you check your voltage rails. If it's boot looping at ~400mA then it's likely PMIC or CPU related. check for low or missing voltages in lines produced by the PMIC. |
08-25-2018, 10:29 | #3 (permalink) | |
Member: 225506 Status: Offline Thanks Meter: 31 | Quote:
Thanks for your resposte i need check point for volt in and out PMIC in c4003 c4004 c4005 not present any volt is 0v | |
08-26-2018, 00:36 | #4 (permalink) |
Member: 2777379 Status: Offline Thanks Meter: 34 | These lines are connected to U4000 (display driver) however your phone doesn't boot so the issue is something else. Check PP_CPU, PP_SOC, PP_FIXED, PP1V8_SDRAM |
