Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-16-2020, 01:07   #16 (permalink)
Member: 169896
Thanks Meter: 323
Originally Posted by P3T3 View Post
A5 work on all devices and activate, I have a mini 4 on min 1 and iPad 4 on iPad Pro 12.9 second gen no problem...
Can use JC tools, Digitiser.app and Purple pro.app to get digi mode..
Then can program new details with with JC tools on windows or magiccfg.app on Mac.
Very simple to do!
Make shore you reflash iPad after program or will not activate.
Dos anyone know where we can get a8/9/10 serials from? Need a trusted seller.
Try on Aliexpress.com
Sent from my SM-G986W using Tapatalk
The Following User Says Thank You to ashahzad_pk For This Useful Post:
Old 09-16-2020, 08:57   #17 (permalink)
Member: 1939450
Thanks Meter: 165
Originally Posted by MiRoOo View Post
I can confirm that A5 SN works on A7/A9.
Tested many times actually.
Will test this soon. Does facetime and imessage activates? And does Apple id "binds" to Sn or you can flash it unlimited as what you have with A5 models after sn change. (then i never had a proper icloud binding to sn)
Old 09-18-2020, 08:04   #18 (permalink)
Member: 2277735
Thanks Meter: 215
The details will lock to the iCloud you sign in to...
All works as they are clean sireals is like setting up a new iPad, flash setup and lock to your icloud
Old 09-21-2020, 01:33   #19 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
In september 2020 any serial are not work on a7 cpu devices.....
All sourced over the world stop selling a7 sn due to 99%complain...
If some one done post proof
The Following 2 Users Say Thank You to chand_gee For This Useful Post:
Old 09-21-2020, 22:54   #20 (permalink)
bobo bokota's Avatar
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 496
I just passed iPad Air 2 Gsm purple mode with # b-box then I removed the wifi ic
Envoyé de mon iPhone en utilisant Tapatalk
Old 09-24-2020, 09:46   #21 (permalink)
Member: 1253358
Thanks Meter: 2
Very simple to do!
is purple pro app available right now?
Old 10-14-2020, 14:58   #22 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
https://mega.nz/file/Ed0RQaAR#O6sQ_9...wQJ5xfY0uBwOdQ
The Following User Says Thank You to chand_gee For This Useful Post:
Old 10-19-2020, 00:23   #23 (permalink)
Member: 302596
Thanks Meter: 784
hi chand_lee the file was damage
Old 10-19-2020, 07:37   #24 (permalink)
Member: 1675922
Thanks Meter: 61
use this command in terminal:
xattr -cr /path/to/application.app
Replace /path/to/application.app with purple app path
The Following 2 Users Say Thank You to mcmihai003 For This Useful Post:
Old 10-27-2020, 02:14   #25 (permalink)
Member: 2970811
Thanks Meter: 5
i have ipad mini 3 A1600. i remove resistor to change to wifi only then i remove nand to reprog. but when i restore i get error 4014? any one can help?
The Following User Says Thank You to l3ibniz For This Useful Post:
Old 10-30-2020, 00:42   #26 (permalink)
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 496
iPad Pro 10.5 4G bypass to mode purple sous iOS 14.1 succès
Old 10-30-2020, 19:26   #27 (permalink)
Member: 1675922
Thanks Meter: 61
Hello,
Did you used engineering cable or it worked with normal one?
Thx,
Old 10-30-2020, 21:06   #28 (permalink)
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 496
IPad 9.5 (2017) successfully made in purple mode
Old 01-14-2021, 02:18   #29 (permalink)
Member: 2533829
Thanks Meter: 2
whois supplying serial for ipad .i need a good supplier
The Following 2 Users Say Thank You to ocpr.co For This Useful Post:
Old 02-05-2021, 21:35   #30 (permalink)
Member: 88304
Thanks Meter: 9
do you have WORKING serial for a1822? something changed with this model and now it doesnt activate with a7/a8 sn, i have 2 pcs and both unable to activate
The Following User Says Thank You to $ide$tep For This Useful Post:
Page generated in 0.23884 seconds with 8 queries
