03-28-2018, 11:27 | #19 (permalink) |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | Having this problem also here from ipad mini 2/4/air1 and air2 after change u2 or flex /new battery still not charging after 1-3% (depending on model) |
03-30-2018, 20:19 | #20 (permalink) |
No Life Poster Join Date: Jul 2016
Member: 2598526 Status: Offline Thanks Meter: 52 | I’ve had this happen on every single one I’ve gotten and I’m led to believe it’s the main power ic. But they’re an expensive part so I’m just going to piss all over these stupid iPads |
03-31-2018, 18:43 | #21 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48755 Status: Offline Thanks Meter: 30 | that's the U2 issue i got few like that, replacing the U2 is not easy as it's too close to nand. so put kapton tape and even a small aluminium radiator used for microcotrollers or cpu, and try to clean all that ****ty glue under the chip, then try to clean all the old solder and try again some chinese refurbished U2 IC's, and especially the 1610U1 IC's are bad. i got 75% failure on one delivery from Aliexpress once .. |
03-31-2018, 18:44 | #22 (permalink) | |
Member: 2598526 Status: Offline Thanks Meter: 52 | Quote:
For me I tried u2 many times and always same issue | |
03-31-2018, 18:48 | #23 (permalink) |
Member: 48755 Status: Offline Thanks Meter: 30 | i fixed one like that recently. it was laying in my shop for almost a year after i lost hope to fix it because like you, i tried many different U2 chips. i just tried a new U2 IC, and got it to work as it should. no draining, no charging issues .. |
04-19-2018, 17:37 | #24 (permalink) |
Freak Poster Join Date: Oct 2016
Member: 2634857 Status: Offline Thanks Meter: 25 | This should help you . https://dgpcrepairs.wixsite.com/ipho...g/date/2017-10 Sent from my X98 Plus 3G using Tapatalk |
The Following User Says Thank You to deegee2016 For This Useful Post: |
05-31-2018, 14:05 | #25 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | I had the same problem. Ipad Air not charging when powered on. 0.02a Not even charging symbol. But will charge when powered off. I got 5v on caps from usb to Tristar. So I changed Tristar with 1610A3.. didnt help. Then i took a 1610A1.. didnt help. Other battery didnt help. In my case the solution was to change the docking flex. After that the ipad was chagring pefectly. So dont get fooled if you have 5v on the caps neer your Tristar. Your docking flex can still be defect! |
06-01-2018, 12:04 | #27 (permalink) | |
Thanks. Wonder how the docking flex gets damaged preventing charging when powered on | |
