Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-14-2017, 00:20   #1 (permalink)
Member: 48344
Thanks Meter: 2
iPad Air Not Charging
i have an ipad air with charging problem.
when lcd is on, it charges 0,70amp
when lcd goes off or sleep,it stop charging, goes to 0 amps.
when i connect to itunes, it says not charging on ipad screen,but its recognised on pc.
i tested voltages on charging flex cable,its 5,1v.
i have changed Charging TRISTAR IC U6000.still same problem.
i have checked BATT_SWI_CONN line,BATT_NTC line,PPBATT_POS_CONN line,
no shorts.
please if anyone knows the solution,thank you!!
Old 11-14-2017, 07:20   #2 (permalink)
Cheater -Don't Deal with him-
Member: 975047
Thanks Meter: 330
Chnage The U2 iC will be solved
The Following User Says Thank You to GsmDiamond For This Useful Post:
Old 11-14-2017, 08:32   #3 (permalink)
Member: 48344
Thanks Meter: 2
Thanks for the quick replay.
i already changed the U2.still exactly same problem.
any other solution ?
thanks
Old 11-14-2017, 10:22   #4 (permalink)
Member: 2515187
Thanks Meter: 114
Hello
Try replace Q8123.
Old 11-14-2017, 11:19   #5 (permalink)
Member: 48344
Thanks Meter: 2
Originally Posted by Pallle View Post
Hello
Try replace Q8123.
Even if C8145 is getting 5V? can i jump Q8123 ?
thanks
Old 11-20-2017, 14:48   #6 (permalink)
Member: 48344
Thanks Meter: 2
up,anyone have an idea ?!
Old 11-27-2017, 14:18   #7 (permalink)
Crazy Poster
Member: 831155
Thanks Meter: 10
try to check to shematic diagram for trace the connector of charging.
Old 12-13-2017, 16:36   #8 (permalink)
Member: 48344
Thanks Meter: 2
still no help.any other solution ?
Old 12-19-2017, 17:23   #9 (permalink)
Member: 2342759
Hi have same problem with my iPad air, no charging
Help
Old 02-17-2018, 00:30   #10 (permalink)
Member: 2598526
Thanks Meter: 52
Anyone firgire this out? Have same issue with two iPad Airs. Says “not charging” top and usb meter shows it’s pulling half amps from charger.
Changed u2 twice on each one and same issue. Sometimes it charges normal but most of the time says “not charging”
Old 03-08-2018, 13:46   #11 (permalink)
Member: 2745141
if nand flash supply is ok then change charging port, i tested this solution just now, all fixed
The Following User Says Thank You to re.billy For This Useful Post:
Old 03-10-2018, 23:03   #12 (permalink)
Crazy Poster
Member: 111710
charging
This is a battery problem.!
(one side of the battery is dead)
Old 03-11-2018, 14:07   #13 (permalink)
Member: 2598526
Thanks Meter: 52
Can you confirm this?
Old 04-18-2018, 10:45   #14 (permalink)
..:: i-MAX ::..'s Avatar
Member: 94762
Thanks Meter: 115
same problem
no charge
no USB connection
change a1610a1
same problem
Old 10-23-2018, 08:15   #15 (permalink)
Member: 995038
Thanks Meter: 6
any solution for this case? i experience the same problem.
already change u2 2 times and charging flex but still have this problem
Page generated in 0.24483 seconds with 9 queries
