09-21-2012, 13:38 | #1 (permalink) |
Crazy Poster Join Date: Aug 2011
Member: 1633386 Status: Offline Thanks Meter: 4 | iPhone 3G: Doesn't charge, doesn't start, but see charging screen No matter how long I let it charge, this image will not disappear and the iPhone will not charge. If I remove the charger cable, the image disappears. But if I replace the empty battery with a charged battery, the phone won't start. All I see is a faint flickering of the screen. So what is wrong? |
09-21-2012, 20:02 | #6 (permalink) | ||
Member: 1633386 Status: Offline Thanks Meter: 4 | Quote:
So: NO charger cable, (almost) EMPTY battery: NO charger cable, CHARGED battery: Charger cable INSERTED, (almost) EMPTY battery: Charger cable INSERTED, (semi) CHARGED battery: | ||
The Following User Says Thank You to ZP1970 For This Useful Post: |
09-21-2012, 20:18 | #7 (permalink) |
No Life Poster Join Date: Jan 2005 Location: root
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | have you checked fuseīs voltage with charged batt? if itīs ok, did you check pmic surrounding voltages? and was it water damage? does it gets abnormally hot? |
The Following 2 Users Say Thank You to vazgsm For This Useful Post: |
09-21-2012, 20:49 | #9 (permalink) |
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | itīs surely liquid damage, pehaps water. but first thing of all, is to remove all oxidation from board. remove shields and clean it all up, then measure fuseīs and pmic voltages. pcb is shorted somewhere, may be in oxidized spots. |
09-21-2012, 21:15 | #10 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1679608 Status: Offline Thanks Meter: 190 | clean the board and replace all damaged part maybe when your iphone turn on the camera also not working any way after clean board replace the green fuse iPhone_S1.jpg |
09-21-2012, 23:50 | #11 (permalink) |
Member: 1633386 Status: Offline Thanks Meter: 4 | I measured between ground and both sides of the green fuse and didn't measure anything (on a charged battery). What should I measure? |
09-22-2012, 15:17 | #12 (permalink) |
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | that green fuse is supposed to have same voltage as battery. if it shows 0v, it must be a broken line from batt connector v+ to other side of the board, so now you know where to begin. sorry, but I canīt seem to understand why your board wasnīt cleaned up already. is the most important thing to do. get a toothbrush and some thinner, and rub it up till not a single oxidation spot can be seen anywhere on the board (even inside shields!). with oxidized phone, you canīt trust measures, as it may be the cause of the shortage. br |
09-22-2012, 20:26 | #14 (permalink) | ||
Oxidation in itself isn't a problem. But it eats into the electronic component causing it to fail. So if a component doesn't work and it's oxidized, it won't start working all of a sudden when you remove the oxidation. | ||
09-23-2012, 16:04 | #15 (permalink) | |
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | Quote:
never had problems for cleaning, they happen when pcb is not cleaned properly. how many phones began to work again simply by cleaning up the board, which proves the importance of it. when you keep powering oxidized boards, you risk to damage it even more. Something I NEVER do, is to power an oxidized board, but maybe itīs just me... | |
