Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-15-2010, 14:56   #211 (permalink)
Member: 1231825
Thanks Meter: 4
Originally Posted by schumythebest2 View Post
I have an iPhone 3G which when connector 3 is connected, it freezes when starts. If this is disconnected, everything works ok(obviously without earphone or light sensor).
So.. is there any kind of solution to the problem?
Regards
Had this problem before. I replaced the light sensor and earpiece flex and it worked again. It only cost a few £'s on ebay.
The Following User Says Thank You to adam_pres For This Useful Post:
Old 02-15-2010, 15:05   #212 (permalink)
Member: 1231825
Thanks Meter: 4
Originally Posted by adam_pres View Post
Digikey part number: P14216CT-ND
I only found it by getting the dimesions off another motherboard with the compenent still on.
Don't know if it is the right values if anyone could confirm its the right values i'll all order a few up, as i have to make an order to dgikey for a few other things.
EDIT:
I have now ordered and fitted this part. Woking fine. If anyone wants one i can ship one out to you. PM if you want one. I only have 25
The Following 2 Users Say Thank You to adam_pres For This Useful Post:
Old 02-15-2010, 16:27   #213 (permalink)
Member: 549849
Thanks Meter: 20
Old 02-15-2010, 16:28   #214 (permalink)
Member: 549849
Thanks Meter: 20
iphone servis manuel
The Following 3 Users Say Thank You to muharrem şen For This Useful Post:
Old 02-16-2010, 02:43   #215 (permalink)
Member: 1222631
Thanks Meter: 24
Hi muharrem_sen what should i do if iphone 3g felt into water ad after cleaning it turns on for few seconds , the bcklight turn on but doesn't show anything ? Thank You
Old 02-16-2010, 15:15   #216 (permalink)
Crazy Poster
Member: 1190812
Thanks Meter: 17
Hi...i have a problem with these iphone. The problem is no charge and pc do not recognize the iphone. The logic board have these fracture line on the back side:
I know i have to make some bridge to recover the mainboard...someone know where i have to bridge the pin of connector 4?
Old 02-16-2010, 17:07   #217 (permalink)
Member: 221978
Thanks Meter: 11
Was that! It tested it with other screen and started to work again. Fantastic!
Now, I have a 3G S with with screen. Everything works, screen also in other 3G S but the phone shows white everyting. ¿Any idea?
Regards
Old 02-18-2010, 14:27   #218 (permalink)
Crazy Poster
Member: 1190812
Thanks Meter: 17
The iphone power on correctly and charge but it's not recognised by the PC!!!...please help! someone know on wich pin on the logic board i have to make a bidge???
Help me please
Old 02-19-2010, 06:25   #219 (permalink)
Member: 947827
Thanks Meter: 6
iPhone 3g headPhone Problem
Hello bossess. help me out from my problem....i have iPhone 3g when i use headphone then everything ok but when i remove headphone then no sound no ear sound no mic.. it still show connected headphone.. please help me out of this problem...
Old 02-20-2010, 03:56   #220 (permalink)
mccm's Avatar
Member: 173565
Thanks Meter: 71
Think of using cable type for its wifi antenna 3g or 3gs,their original are too short and using metal plate.Anyone have better l ideas to boost the wifi signal.
or chance the original antt to sold gold?no kidding
Old 02-21-2010, 05:55   #221 (permalink)
Member: 5792
Iphone 3G gsm signal drops???
Hi.
I have Iphone 3G always signal drops. It seems someone tried to repair this iphone before me. He bended lower part of logic board as shown on picture.
Small part shown green rectangular is cracked. That crack is too tiny. Is there any other place where I can make jumper short connection for that? Also I short connected red dotted part because small inductor is ripped off from there.
Old 02-24-2010, 10:53   #222 (permalink)
Crazy Poster
Member: 1190812
Thanks Meter: 17
Originally Posted by xmans View Post
Hi.
Make a jumper like these:
Old 02-24-2010, 16:33   #223 (permalink)
Member: 777761
Sonork: waqartitoo
i phone 3g speaker mic not work. any solution
Old 02-24-2010, 16:44   #224 (permalink)
sassaki's Avatar
Member: 159096
Thanks Meter: 48
Poronpad on audio codec.
regards
Old 02-24-2010, 16:47   #225 (permalink)
sassaki's Avatar
Member: 159096
Thanks Meter: 48
Diagram logic
Iphone 3g!!!!!!!
Regards
iPhone 3G S Diagram Here delower10 iPhone, iPad, iPod Hardware Repair 11 12-27-2010 14:57
IPhone 3g broken motherboard no service Farntet iPhone 4 / iPhone 4S 4 11-25-2010 11:51
iphone 3G MotherBoard Diagram------By {{{Rasel--Wingstel--Bangladesh}}} Wingstel iPhone 2 / iPhone 3G / iPhone 3GS 4 01-27-2010 12:26
iPhone 3G S Motherboard Diagram by parts Zulea II iPhone 2 / iPhone 3G / iPhone 3GS 0 11-23-2009 08:03
Page generated in 0.22354 seconds with 10 queries
