10-25-2009, 00:42 | #63 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1148454 Status: Offline Thanks Meter: 25 | @Sliplock hello, I don't Know if this component is linked with your charging problem but it could as it is placed just behind the charger connector. Do you Still have the component? If yes what you should do is a reballing. You must have a hot air soldering station to proceed and buy Some bga balls with eBay for $5. this should be 5mm I guess. An other solution could be to try to short the pins 2 by 2 and test. Indeed this component could just be a kind of ESD supressor or something like That... |
10-25-2009, 14:07 | #66 (permalink) |
Member: 1148454 Status: Offline Thanks Meter: 25 | @Sliplock last things, if you don't want to reball and resolder the component you could do a "wirebonding" which means that you have to solder very thin (and coated) wire to each component pad and then solder the wire's end to the PCB. This should be easy to do as you only have 4 pads to solder. You just need to have a soldering iron with a very thin tip (<=0.4mm). But before to proceed, you should also try to figure out what was the component side/position regarding to the PCB because this is really important. Regards, Guileukow |
10-25-2009, 21:12 | #67 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: Galaxy Age: 46
Member: 86301 Status: Offline Thanks Meter: 107 | Quote:
my poblem is that i don't know exactly what this part is. i will try to do connection when the phone is in Charge for see if it change someting. | |
10-28-2009, 20:12 | #68 (permalink) |
Member: 1148454 Status: Offline Thanks Meter: 25 | Hello SLIPLOCK, just FYI, today I've repaired an iPhone watter dammaged which didn't want to charge. When plugged everything was fine except that after one or two minutes the battery logo was filled up with a plug instead of a spark, and didn't want to charge. So I checked first with the same area than you and found nothing wrong so I removed the battery and finally found that the electronic embeded with the battery was highly corroded. I've cleaned this area (there was lots of kapton tape to remove before to operate) and everything started to work again and the iPhone was able to fully charge its battery. Then my today's suggestion is: when an iPhone was watter dammaged it is important to not forget to check the battery's embeded electronic to see if there is no corrosion on it!! Hope this help!! Guileukow |
The Following User Says Thank You to guileukow For This Useful Post: |
10-28-2009, 21:19 | #69 (permalink) | |
i check now!!!! wbr | |
10-28-2009, 23:04 | #70 (permalink) |
Member: 86301 Status: Offline Thanks Meter: 107 | @guileukow man thank you very much! with your good advice and the help of my tornado TP i succeded to solve my charging probleme on my 3G phone! the IC was charge IC (or some kind of diode or protection....) but by linking the 2 lines, phone is charging and can communicate with pc again! sorry i don't know why, i am unable to post picture... thanks again best regards |
10-29-2009, 22:14 | #71 (permalink) |
Member: 1148454 Status: Offline Thanks Meter: 25 | Hi, I'm glad to hear that your phone will charge again. If this work just by shorting the pins, I guess that this is probably T diodes linked to the ground or something like that. If I have a time I will try to find out what this component is but as my phone is well working now I don't have the heart to reopen it again lol regards |
11-25-2009, 02:03 | #75 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 895524 Status: Offline Thanks Meter: 33 | not to be rude but mic normally dont stuff up as often if i was you try changing the headphone jack cable. ive ran into this problem about 3 time i think ive prob worked over 2day trying to solve this problem. |
iPhone 3G S Diagram Here | delower10 | iPhone, iPad, iPod Hardware Repair | 11 | 12-27-2010 14:57 |
IPhone 3g broken motherboard no service | Farntet | iPhone 4 / iPhone 4S | 4 | 11-25-2010 11:51 |
iphone 3G MotherBoard Diagram------By {{{Rasel--Wingstel--Bangladesh}}} | Wingstel | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 01-27-2010 12:26 |
iPhone 3G S Motherboard Diagram by parts | Zulea II | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 11-23-2009 08:03 |
