05-22-2011, 16:19 | #107 (permalink) |
Insane Poster Join Date: Jul 2009
Member: 1086977 Status: Offline Thanks Meter: 50 | It should be remembered that the coil is just 1 part involved in functioning of the backlight. The 109B MOSFET + schottky diode is part of the the boost converter that, in combination with the 6R8 inductor, boosts the voltage to a high level to run the 6 LEDs mounted in the screen. And the boost converter itself is managed by the 338S0768 power management IC. So, any of these parts can be responsible for the backlight not functioning. Another fault common with the 3GS is that the copper tracks connecting the output of the boost converter IC (109B) to the LCD connector can become open-circuit. There is also an independent track from the 338S0768 PMIC to the LCD connector which is involved in backlight control, and this should be checked with a multimeter for continuity as well. And, of course, ultimately the screen itself may be faulty. There is a thread on here in which someone details finding the fault on the LCD module and repairing it. To sum it up: don't be surprised if just changing the 6R8 inductor doesn't repair the backlight fault. |
06-17-2011, 19:50 | #109 (permalink) |
Junior Member Join Date: Jul 2005 Age: 40
Member: 163866 Status: Offline Thanks Meter: 1 | hello, I have a problem in some 3gs, at each power on the phone the light is on for few second ( 1-2 second ) then the light turn off, I change 6R8 and the problem is still present. what can I do, please help me. |
06-18-2011, 13:00 | #110 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 809882 Status: Offline Thanks Meter: 19 | Repaired a lot of these check coil again the one you replaced could be shorting I have one the same replaced the coil and the IC then the light came on then off when I replaced the coil another one it worked. Check pin number 6 on to the LCD connector to make sure it is not open circuit. Check out all the posts here of help. |
07-08-2011, 10:05 | #112 (permalink) |
Freak Poster Join Date: Oct 2008 Location: ROMANIA Age: 36
Member: 888603 Status: Offline Sonork: 100.1641525 Thanks Meter: 40 | worked for me...the phone was water damaged! Now it's working 100% |
The Following User Says Thank You to gopo_nike For This Useful Post: |
07-09-2011, 19:50 | #113 (permalink) |
Junior Member Join Date: Dec 2010 Location: bucuresti
Member: 1461284 Status: Offline Thanks Meter: 0 | i have a 3gs that have no backlight and the coil was ripped from the motherbord and cannot replace and the pin no.3 from connector 1 is broken. can i make a the backlight working or is busted |
09-19-2011, 00:48 | #116 (permalink) | |
Junior Member Join Date: Aug 2011
Member: 1638625 Status: Offline Thanks Meter: 0 | Quote:
Uploaded with ImageShack.us | |
01-26-2012, 12:55 | #118 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Swakopmund, Namibia, Africa Age: 51
Member: 70374 Status: Offline Thanks Meter: 19 | iPhone 3GS No LED Display Lights Repair Try this tracks - it worked for me for LCD no display lights! Last edited by Normang; 04-12-2020 at 05:32. |
The Following User Says Thank You to Normang For This Useful Post: |
01-27-2012, 16:58 | #119 (permalink) | |
Junior Member Join Date: Sep 2010
Member: 1393283 Status: Offline Thanks Meter: 3 | Quote:
Based on this, I have voltage (4.0V) at my 2 input leads, 1 and 3, and voltage output at 6, I have a ground present at 5, but no output voltage at 4. Therefore I have a faulty 109 IC. Now to breakout the heat gun and replace. Gotta order the IC's first though. | |
iphone 3gs no light | irangsm | iPhone 2 / iPhone 3G / iPhone 3GS | 13 | 01-31-2011 15:33 |
Iphone no light solution | mamun_iqbal2000 | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 01-18-2010 16:31 |
Iphone 3GS No Light | HAKIM | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 11-19-2009 13:17 |
3GS iPhones can no longer restore to 3.0 / 3.01- WARNING | dubaimobiles | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 09-11-2009 02:08 |
