11-18-2010, 09:21 | #61 (permalink) | |
Junior Member Join Date: Nov 2010
Member: 1445673 Status: Offline Thanks Meter: 1 | Quote:
fixed mine i got the coil from a guy on ebay for £7.50 he even explained how to replace the coil...heres his ebay id if any1 wants a new coil... Seller information Member ID adrianwoodward ( Feedback score of 409) 100% Positive feedback | |
The Following User Says Thank You to fonefixer1 For This Useful Post: |
11-18-2010, 09:30 | #63 (permalink) |
Member: 1445673 Status: Offline Thanks Meter: 1 | Otherwise contact him if you have bought a coil from him , he can recommend a company who can install it for you if you don't feel confident, but you have to buy the coil from him first. Works a treat though. |
11-18-2010, 17:45 | #64 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 717129 Status: Offline Thanks Meter: 11 | I'm in the UK??? I just buy the part from Farnell United Kingdom | world-leading distributor of electronic and maintenance, repair and operations products.. Using a solder station I remove the faulty coil then resolder the new coil. You do not need any special equipment just a good temperature controlled solder iron and good solder. If you want I can fix it for you if you're in the UK.....PM me |
The Following User Says Thank You to oliverkop For This Useful Post: |
11-19-2010, 03:11 | #65 (permalink) | |
Inductance Tolerance:± 30% not 20% DC Resistance Max:0.35ohm not 270.0 mOhm Max DC Current Rating:650mA not 830mA It's not even the same dimensions. Seems to me it makes sense to buy the correct part on ebay, to save having niggley faults later when the part does not perform... Maybe its just me but I want my iPhone fixed correctly and once and for all. | |
11-21-2010, 00:29 | #67 (permalink) |
Freak Poster Join Date: Jul 2010 Location: California
Member: 1352483 Status: Offline Thanks Meter: 24 | Hey guys this weekend i changed the coils out on two different 3gs's with no back light and it didn't fix my no back light problem. Id like to try the jumper wire from the #1 near the coil to the #3 o the connector, but i want to attempt on a Iphone I own first. what size wire is it thats used for the jumper. And do you think it would be easier to use solder paste and hot air to make the connections. Since these are so close to other things and the chance of unsoldering something else is a possibility. So here's what i need to know.... what size wire to use, and i suppose copper is better? and should i use paste to do it? Thanks so much Tony |
12-01-2010, 16:13 | #68 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1249507 Status: Offline Sonork: [email protected] Thanks Meter: 9 | hi thanx sir good job bom bom/./...././........////////////////// |
12-03-2010, 09:22 | #69 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1273461 Status: Offline Thanks Meter: 0 | Hi Tinner105, same problem here. I bought a few coils from a very smart guy in US and changed the coil - but still no backlight. From pin 1 to pin 3 (you now what I mean) there is electrical continuity. So why it should be neccesary to do the jumper? Regards, Karl |
12-03-2010, 19:24 | #70 (permalink) |
Member: 1352483 Status: Offline Thanks Meter: 24 | Karl I ended up getting some 30awg wire and made the jumper from 1 to 3 and they are both working now. I ended up using solder paste to do the job. It was very tedious to say the least. since the solder point is so small on both ends i used a sewing needle to put the paste where it was needed. Microscope definitely helped. The paste looks like silver caviar And i glued down the wire along its path to keep it from moving around as i did the job. I used a very small tip on the hot air gun and was careful not to melt the connector for the LCD etc. Careful that the wire on the #3 doesn't keep the LCD cable from ******* on the connector. I'm going to try and find some smaller wire for the next ones i do it will probably make the job easier. Tinner105 |
12-03-2010, 21:39 | #71 (permalink) |
Member: 1352483 Status: Offline Thanks Meter: 24 | PS i just got done doing another. I ohmed out the coil first and it was ok, so i jumpered the #1 to #3 and it didn't work. So for the heck of it I changed the coil and presto change Backlight now works. These freakin IPhones are EVIL |
12-10-2010, 12:24 | #74 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1404320 Status: Offline Thanks Meter: 53 | For 3G FIX look here For 3G FIX look here: http://forum.gsmhosting.com/vbb/f631...5/#post6512348 |
12-17-2010, 16:06 | #75 (permalink) | |
Member: 1393283 Status: Offline Thanks Meter: 3 | Quote:
Fixed a water damaged no backlight 3GS with the 100 Coil from a dead 3GS. Found near the bottom of the board. Thanks again guys. | |
iphone 3gs no light | irangsm | iPhone 2 / iPhone 3G / iPhone 3GS | 13 | 01-31-2011 15:33 |
Iphone no light solution | mamun_iqbal2000 | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 01-18-2010 16:31 |
Iphone 3GS No Light | HAKIM | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 11-19-2009 13:17 |
3GS iPhones can no longer restore to 3.0 / 3.01- WARNING | dubaimobiles | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 09-11-2009 02:08 |
