06-08-2010, 00:41 | #23 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1317399 Status: Offline Thanks Meter: 0 | does anybody know how the specs on the iphone coil and how to check the coils of other devices to see if they are in spec? I know that most devices have a coil of some kind in them. |
08-31-2010, 18:01 | #25 (permalink) |
Junior Member Join Date: Jan 2004 Location: Poland
Member: 49250 Status: Offline Thanks Meter: 3 | hello I have not backlight in my iphone 3GS. I changed coil but still not work. Probably DC/DC converter is faulty but I dont know where can I buy it. Does anyone have any idea for this? |
09-29-2010, 12:32 | #26 (permalink) |
Major Poster Join Date: Sep 2010
Member: 1405991 Status: Offline Thanks Meter: 11 | I also replaced the coil with a new original 6R8 and the backlight still doesn't work. Does anyone have a suggestion? I found a fix with a bypass but I don't really know if I whant to do that. Can someone suggest where on the mainboard I should check for continuity or how to check if the problem is not with the LCD screen or 6R8 coil. |
The Following 2 Users Say Thank You to tayfix For This Useful Post: |
09-29-2010, 15:49 | #27 (permalink) |
Member: 1405991 Status: Offline Thanks Meter: 11 | I did a test... Pin 1 (A) on 6 pin chip (to left of 6r8 inductor) is continuous with pin 3 (B) of LCD connector. This is also continuous with the lower gold contact point 2 (C) of the left-most pair of contact points along the top left edge on bottom of the board. Pin 6 (A) on 6 pin chip is continuous with coil. The coil is continuous, cca. 0.7 ohm. Pin1 of the LCD connector is continuous with the inboard solder pad of the two LED connections on the LCD unit. It is also continuous with the upper gold contact point 1 (C) in the leftmost pair of contacts along the top left edge on the bottom of the board. Help me out please. |
The Following 4 Users Say Thank You to tayfix For This Useful Post: |
09-30-2010, 09:01 | #30 (permalink) |
Member: 1405991 Status: Offline Thanks Meter: 11 | Can someone tell if this is correct, pin 3 (B) powers the backlight on the LCD, where is the returning point, does the current from backlight LEDs return through pin 2 (B) or through some other pin??? Please help, need to do some tests. |
The Following User Says Thank You to tayfix For This Useful Post: |
iphone 3gs no light | irangsm | iPhone 2 / iPhone 3G / iPhone 3GS | 13 | 01-31-2011 15:33 |
Iphone no light solution | mamun_iqbal2000 | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 01-18-2010 16:31 |
Iphone 3GS No Light | HAKIM | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 11-19-2009 13:17 |
3GS iPhones can no longer restore to 3.0 / 3.01- WARNING | dubaimobiles | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 09-11-2009 02:08 |
