04-26-2012, 12:31 | #61 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1239558 Status: Offline Thanks Meter: 0 | All Soulution Tested my iphone has been water damaged and after that this problem come to my phone and after 1-2mins it show az fully charged and stop charging and after that phone Restart Automaticly..i chk all the batt connectors and all jumpers are tested and their path are ok but all of them has path to ground...help me and give me a solution |
04-26-2012, 12:54 | #62 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
04-26-2012, 13:17 | #64 (permalink) | |
after water they make problems,i will not reply anymore if you have doubts removing them. | |
04-26-2012, 16:45 | #65 (permalink) |
Temporary banned !! Join Date: Apr 2008 Location: philippines
Member: 741567 Status: Offline Thanks Meter: 9 | charging problem also i also face same problem with iphone 4 charging wen put charger and usb cable it show plug sign only and its not charging definitely seems domjuan1500 made it and i cant follow it clearly maybe wites can help me with my problem thanks regards |
11-02-2012, 17:28 | #66 (permalink) |
Junior Member Join Date: May 2008 Location: karachi pakistan
Member: 783599 Status: Offline Thanks Meter: 1 | iphone charging not save hi i have a iPhone 4 i remove Q2 & make jumpers now its showing charging but not save charging i mean if i connect charger at 20% after one hour still same showing. and when i connect charger without battery its not showing any output voltages. and not power on . i check other ok iphone without battery connect charger power on but this phone not on. if you have a any solution so please kindly reply me thanks regards |
11-02-2012, 19:15 | #67 (permalink) | |
Freak Poster Join Date: Oct 2011
Member: 1679608 Status: Offline Thanks Meter: 190 | Quote:
remove your jumper and change Q2 if not solved check this R81 and replace it also when you connect the charger chek on L2_PMU you must have 3.7v if not change the coil if not solved change power ic also check the battery ways on FL5_RF must have 1.1v or 1.4v anyway i think the problem in Q2 | |
08-31-2013, 15:09 | #69 (permalink) | |
Registered User Join Date: Oct 2006 Age: 48
Member: 362673 Status: Offline Thanks Meter: 37 | Quote:
I changed fuses but nothing, i changed ic but nothing and when i tested with your picture i found a short on pcb and after making jump my phone is ok ! Thanks a lot ! | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
