Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-25-2013, 12:00   #1 (permalink)
Member: 1399227
Sonork: 100.1594671
Thanks Meter: 29
iPhone 4s keep searching only solution
unit = iphone 4s 64gb lock to smart pp
problem= keep searching
action taken= try another smart sim = no luck
retore to ios 6.1.2
activate
set time manualy
restart
no luck
i open the phone check all posible line open like antina fuse and soso....blah all is good
re asimble then power on reset network, manualy set the time.
restart again mmmnnn no luck
any solution plss????
Old 02-25-2013, 12:23   #2 (permalink)
Member: 425548
Thanks Meter: 16
try to jailbreak it and install ultrasn0w
The Following User Says Thank You to GULAB-GUL For This Useful Post:
Old 02-26-2013, 07:44   #3 (permalink)
Member: 1399227
Sonork: 100.1594671
Thanks Meter: 29
done by this
open again the phone and check all hide parts near to the signal components and i discover this.
imediatly get another board and look the missing parts.
since not easy to replace this parts by using hot air. i try to jumper and it works
vow!
The Following 3 Users Say Thank You to boknoy For This Useful Post:
Old 03-29-2013, 18:39   #4 (permalink)
Member: 1889273
Thanks Meter: 12
hi how u jumper it? not more photos ?
Old 06-04-2013, 08:40   #5 (permalink)
Member: 176989
Thanks Meter: 13
i have iphone 4s give error -1
any solve
plzzzzzzzz
Old 06-06-2013, 03:26   #6 (permalink)
Member: 1399227
Sonork: 100.1594671
Thanks Meter: 29
any solve
plzzzzzzzz
baseband chip is the damage.
try reball or change
not all do this will be done.
just depend upon your hand carry the gadget that you use.
Old 06-13-2013, 21:10   #7 (permalink)
Member: 1951778
How did you actually do the jumper? What do I need to do it? And how do I do it.
Thanks
Old 09-29-2013, 10:09   #8 (permalink)
Member: 1399227
Sonork: 100.1594671
Thanks Meter: 29
Thanks
since not long to jumper, just jumper by lead only use sharp soldering iron. the missing parts is small resistor only
Old 09-30-2013, 10:09   #9 (permalink)
Member: 2036952
Thanks Meter: 3
Will this work on any resistor?
Old 09-30-2013, 22:33   #10 (permalink)
Member: 1927307
Thanks Meter: 3
I have a similar problem.
Missing FL9_RF, C107_RF and C59_RF.
Tried to jump with no sucess, any other possibilites?
Still just searching.
Old 09-30-2013, 22:57   #11 (permalink)
Member: 2036952
Thanks Meter: 3
Im sure somebody will chime in.
Is the phone u speak of gsm or cdma?
Old 10-01-2013, 01:49   #12 (permalink)
Member: 1927307
Thanks Meter: 3
Its a GSM iPhone 4S
I saw the schematics for this components an instead of jump the pads I grounded the components before them on the chain
Old 10-01-2013, 19:28   #13 (permalink)
Member: 1927307
Thanks Meter: 3
Someone with a different suggestion?
Old 11-19-2013, 11:23   #14 (permalink)
Member: 968529
Thanks boknoy for that thread, it really helped!
Got iphone 4S with same problem, though my mainboard wasn't that messed up.
My problem was that FL2_RF was loose and was pushed against C79_RF, so I managed to fix it and got signal.
Unfortunately it lasted only 2 weeks and then again "Searching" and "No Signal" appeared. So I took it apart again but everything seemed fine, no short circuits or missing grounds. So I put it together again and finally managed to contact emergency service, with that, phone had signal again. That one lasted for 2 days, then again no signal.
Both times this happened was while phone was charging, don't know if these thing are tied or just luck.
Did I missed something? I have run out of ideas what may cause this?
I really would appreciate some help.
I would also attach image of details what i soldered, but I can't post links or attach image..
Old 08-21-2014, 06:54   #15 (permalink)
Member: 744438
Sonork: 100.1640287
Thanks Meter: 279
Originally Posted by boknoy View Post
done by this
vow!
Thanks A Lot My Problem has solved
Page generated in 0.30865 seconds with 8 queries
