08-23-2019, 15:08 | #1 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2808721 Status: Offline Thanks Meter: 1 | iPhone 6s No Home button works? Tried putting her original button back in and now it doesn't even recognise it for Touch ID or as a normal home button? It's not the screen that's at fault as I've tried a new screen just incase the flex was faulty. I'm assuming there's a fault somewhere on the board, anyone know the best place to start? |
08-26-2019, 06:23 | #2 (permalink) |
Junior Member Join Date: Sep 2018 Location: Lincoln, Nebraska
Member: 2863634 Status: Offline Thanks Meter: 0 | I think the first thing you want to do is try to restore the phone in DFU mode and see if that solves the problem. If that doesn't work you could try taking diode mode readings at the the home button connector on the motherboard and compare it to the known good values. If you don't have a known good motherboard let me know and I can take some readings for you. You could also take some diode mode readings at the connector on the original home button and the new home button and see if there is some major discrepancy. It might give you a hint about what's going on. |
