Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-09-2010, 11:48   #61 (permalink)
Member: 4274
Thanks Meter: 18
anybody knows the input voltage for 3GS LCD backlight???
The Following User Says Thank You to ambot For This Useful Post:
Old 08-10-2010, 09:56   #62 (permalink)
Member: 1365739
Thanks Meter: 5
Any way to fix error 23 on iPhone 3g? solder any points or what ever?
The Following User Says Thank You to sullz94 For This Useful Post:
Old 08-13-2010, 02:04   #63 (permalink)
Member: 1368029
Thanks Meter: 3
Hello Ladies and Gentlemen,
My 1st post
I have a 3GS that takes long (too long I think) to fully charge. From a complete discharge (shut off automatically) it takes 5 1/2 hours to reach 100% (1 1/2 hrs off + 3 hrs in standby). My research indicates this is about 2X normal time and leads me to believe it only accepts 500ma and not the higher 1amp charge. Also, the charger does not get warm like it does with the 3G. A 3G charges in less than 1/2 the time.
Note: I purchased this 1 yr-old 3GS a couple weeks ago and noticed this. So, 1st thing I did was replace the battery with an Apple original. Charging times did not change. Although this setup worked fine on my 3G, I also tried different Apple chargers/cables without success.
I plan to replace the dock connector because the water sensor is a bit pinkish. Note: the other sensors are white showing any water was minimal.
Any ideas?
Also, the battery display appears to go from 100 to 90 quickly (10-15 min), but thereafter it's normal. A complete charge yields 5-6 hrs with wifi on, bluetooth on, push on, email, safari, etc. I assume this is normal for a 3GS.
The Following User Says Thank You to Mesmurized For This Useful Post:
Old 08-13-2010, 02:53   #64 (permalink)
Member: 1368029
Thanks Meter: 3
Originally Posted by Mesmurized View Post
... My research indicates this is about 2X normal time ...
Oops: 50% of normal time ...
Old 08-16-2010, 06:37   #65 (permalink)
Member: 1365739
Thanks Meter: 5
Paying $20 paypal!
Any way to fix error 23 on iPhone 3g? do i have to solder any point together or something? PAYING $20 PAYPAL!
Old 08-18-2010, 15:29   #66 (permalink)
Member: 1036343
Thanks Meter: 13
help pls 3g phone not charge + usb not conect to pc
Hi all !!!!!! I had 2 ip 3g both off them same problem is phone not charging + not conect to pc as well ,,,,, any 1 know the solution to repair pls !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:eek :
The Following User Says Thank You to ptmobile For This Useful Post:
Old 08-19-2010, 21:26   #67 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
try to do this connection shown in red and then retry to restore.
hope this helps and solves your problem
The Following 6 Users Say Thank You to Burnt Cobba For This Useful Post:
Old 08-19-2010, 21:28   #68 (permalink)
Member: 11325
Thanks Meter: 266
pls check the picture i just posted. Try it and get back with results. Hope it helps you out.
If you want to do something with your money send those $20 to Pakistan. They need it more than anyone else right now.
The Following User Says Thank You to Burnt Cobba For This Useful Post:
Old 08-19-2010, 21:32   #69 (permalink)
Member: 11325
Thanks Meter: 266
First the obvious. Am assuming you tried already a 100% working charging module.
If you are sure it is not from this then check the first post on Page 5 thanks to Mryeye in this thread... exactly here and follow that diagram.Do the appropriate suggested connections. Unless you already did try that.
http://forum.gsmhosting.com/vbb/f631...66/index5.html
The Following 2 Users Say Thank You to Burnt Cobba For This Useful Post:
Old 08-20-2010, 07:59   #70 (permalink)
Member: 1365739
Thanks Meter: 5
what do i connect it with? and how do i connect it? i dont have a soldering iron...is there anything alternative to that? and im raising the price to $28 thanks
Old 08-20-2010, 10:32   #71 (permalink)
Member: 11325
Thanks Meter: 266
how can you work without a soldering iron mate? Its like driving a car without pedals and a steer ring. Its an essential tool in mobiles.
If you only are dealing with this iphone get it over to someone with a soldering iron and make that conenction. Then restore. Hopefully it will fix it.
Old 08-20-2010, 11:06   #72 (permalink)
Member: 868273
Sonork: 100.1621746
Thanks Meter: 56
please any body help me, when my iphone 3g working on headphone sound ok what when normal mode no sound in speaker?
The Following User Says Thank You to deep24 For This Useful Post:
Old 08-20-2010, 11:12   #73 (permalink)
Member: 11325
Thanks Meter: 266
If you have another one available swap the motherboard into the working unit and check. If it works then problem is either from bottom module or the upper ribbon.
Had many with problem from upper ribbon and others from bottom module. Till now i never met this problem in the motherboard.
Hopefully its not from the motherboard in your case too
Old 08-20-2010, 11:27   #74 (permalink)
Member: 1365739
Thanks Meter: 5
okay ill buy a soldering iron but, how do i solder the upper part? theres no metal there and the bottom part isnt made of metal...
Old 08-20-2010, 11:41   #75 (permalink)
Member: 868273
Sonork: 100.1621746
Thanks Meter: 56
how i change upper rebon, all or just one piece
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.29401 seconds with 10 queries
