01-06-2012, 21:15 | #766 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
After download chk green fuse it is in schematic. | |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
01-06-2012, 22:19 | #767 (permalink) | |
Junior Member Join Date: Feb 2011 Location: Estonia
Member: 1509123 Status: Offline Thanks Meter: 0 | Quote:
01-06-2012, 22:46 | #768 (permalink) | |
Might be that phone not charge and it not power with charger,you need to charge battery externally if it power on then it have problem with charge. | |
01-06-2012, 22:51 | #769 (permalink) |
Member: 1509123 Status: Offline Thanks Meter: 0 | Ok, I don't know what has changed but now it powers on when I plug in the USB. But the screen goes white for 10 seconds and then the iphone shuts off again. What should I try next? Thanks for the help! |
01-07-2012, 00:02 | #773 (permalink) |
Member: 1509123 Status: Offline Thanks Meter: 0 | I actually have 2 iPhone motherboards and both have same problem: boot up but with white screen and then shut off after some time. The second motherboard stays on longer and even shows up in iTunes but then disconnects and iTunes throws connection error. I have tested with 2 LCDs and both stay white (and sometimes show random colored lines). According to the previous owner both of the motherboards used to work (with some wifi problems) and have since been stored. It would be awesome if I could get one these motherboards to work. I once had iPhone 2g, which was a great device, and I now try to rebuild one iPhone from parts. Anyway, I separated the boards and chip shields and cleaned the motherboard with isopropyl alcohol and toothbrush but no success. Thank you for all the help, Wites! Last edited by andre402; 01-07-2012 at 00:09. |
01-07-2012, 10:55 | #774 (permalink) | |
01-07-2012, 18:52 | #775 (permalink) |
Member: 1509123 Status: Offline Thanks Meter: 0 | I did not see any cracks in black glue or in any other components even with 40x magnification. Also, pressing the CPU did not make a difference. Is there anything else I can test (voltage checkpoints, ohm readings, continuity etc.)? Thanks! |
01-08-2012, 00:58 | #777 (permalink) |
Member: 1509123 Status: Offline Thanks Meter: 0 | Ok, some update: I cleaned motherboards again, resoldered batteries and then both motehrboards turned on when I connected to USB! One of the motherboards showed logo on LCD and then switched off. The other motherboard booted up, showed lock screen (and connected to iTunes) and then turned itself off and then restarted itself. Then I took motherboards apart, tested with multimeter (all coils have continuity (beeped) and all resistors work (no short-circuit)). Then I connected again to USB and now both motherboards are dead (do not turn on)! I don't understand how this happened and try to sort this out. For both motherboards, red battery wire is 3,7V and white is 0V (no USB) or 2,1V (USB connected). Green R49 is 990 ohm and shows 3V on right side (no USB) or 4,2V (USB connected) and 3,7V on left side. Here is a picture of my motherboard (click for bigger size): Thanks! |
01-08-2012, 04:38 | #778 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1678566 Status: Offline Thanks Meter: 16 | Wites, Regarding that iPhone 3GS that I mentioned a few posts back. The one with the battery problem and error 2009. I noticed it has the old Bootrom. Could that be why it's having this issue? |
01-08-2012, 11:31 | #779 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote: You see fuse is bad it must short or show 00.2ohm this is less than 1ohm. Make jumper with wire on it. |
01-08-2012, 11:33 | #780 (permalink) | |
By wites13 at 2011-12-20 | |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
