01-11-2011, 01:56 | #121 (permalink) |
Insane Poster Join Date: Aug 2004 Age: 64
Member: 79423 Status: Offline Thanks Meter: 3 | [/URL]Please help. Iphone 3gs 32g, restore error 29, I try to changed many battery but still same, now I found 2 cap are missing A is broken pads, B is good pads, any solution like jump ? Thanks |
01-11-2011, 02:15 | #122 (permalink) |
Member: 79423 Status: Offline Thanks Meter: 3 | Iphone 3gs restore error 29, try to changed 3 battery still same, now I found missing 2 caps A is good pads, B is broken pads , any help me how to jump wire to make it work, Thanks very much. Photo 2 of 2, 3gs error 29 |
01-14-2011, 23:06 | #123 (permalink) |
Junior Member Join Date: May 2010
Member: 1301361 Status: Offline Thanks Meter: 0 | Hi, I have issue with my 3gs, i can't slide the phone to open.. Phone never got wet, or dropped. I changed out new digitizer and still couldn't cure the sliding. Does any one have any idea what's going? Is it a board issue? If it is, do you know what chip control this mechanism? Thanks |
01-14-2011, 23:59 | #125 (permalink) |
Member: 1301361 Status: Offline Thanks Meter: 0 | I have another issue, I have a water damage 3g. After cleaning out the board, LCD is white and i tried another LCD, but it doesn't do the trick. Does any 1 have any ideas? Please help. Thank you |
01-30-2011, 15:48 | #126 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1505171 Status: Offline Thanks Meter: 0 | iPhone drains very quick! Hi, i have a 3G[S] 16Gb. I bought a solar power charger from ebay and plugged two iPhones and it killed them both. I dont know how but after a week the one started working but the battery drains 4% per hour. Even if you switch the device off (power off) it still drains the battery 4% per hour. I replaced the battery with a new one but this didn't solve the problem. Please help me... |
02-01-2011, 02:21 | #127 (permalink) |
Junior Member Join Date: Apr 2008
Member: 751479 Status: Offline Thanks Meter: 7 | iPhone 4 strange problem my iPhone 4 is turning off if i don't us it after 10min to 2h maximum...but don't turn on if i try to turn it...when i plug the usb cable to computer it says "usb device not recognized" the only way to turn it on is to unplug and replug the battery connector,after that the iphone is working perfect,but i have to use it and not to enter in stand by mode the only way to use it and not autoturnoff is to put it in the charger and leave it there 24/24...but i don't need a fix phone,i wan't to use it like a mobile phone! i try to replace the battery but same when i buy it it was 4.0.2...i update the firmware to 4.1 but is turning off the same somebody can help me? thanks! |
02-03-2011, 05:26 | #128 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1110700 Status: Offline Thanks Meter: 2 | So, i purchased an iphone off craigslist. The phone is unlocked and jailbroken. OS 4.2.1. modem firmware 6.15.00. However, when i put my sim card inside.. it doesnt even search for a carrier. it goes straight to showing 1 bar ( in the signal panel). It seemed like an antenna problem. So i installed a brand new dock assembly. However, the same problem persists ( only 1 signal bar is shown, without searching). Does anyone know what the problem can be? Thank you in advance!! |
02-06-2011, 21:46 | #129 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1510912 Status: Offline Thanks Meter: 0 | iphone 3g 8gb i have an iphone 3g 8gb.. it used to work before.. then one time it started to reboot itself during file transfer(music and apps) and while using the phone(calls and apps). then i opened the phone to check it.. then after i closed it back. i cannot get it back to home. i always end up at recovery mode. i tried to restore it but i always get error 21 or 9. during restore it reboots during the "restoring iphone software phase" or just hangs. i also encountered white screen with colors flashing. i dont know whats wrong with my iphone. i brought it to a repair shop and the tech said its a logic board problem. any suggestion? could this be some faulty connection? p.s the phone turns on sometimes with a black screen followed by the white screen then turns off. but itunes is able to recognize the phone both dfu and recovery mode. |
02-10-2011, 17:29 | #130 (permalink) | |
Member: 1510912 Status: Offline Thanks Meter: 0 | need help here Quote:
02-12-2011, 14:41 | #131 (permalink) |
Member: 1302256 Status: Offline Thanks Meter: 1 | wifi problem in iphone 3g hi friends i have i phone iphone 3g 8gb. one day it falled from my hands & from that day onward my wifi is not working it says no wifi. i not even able to slect the wifi option plz help me.... |
02-13-2011, 13:40 | #132 (permalink) |
Insane Poster Join Date: May 2009
Member: 1038927 Status: Offline Thanks Meter: 8 | hi... I have changed the LCD screen on IPHone 4... Now its not showing any signal....it always says searching......and then no service... I tried another antenna too...but still the same... any idea what could be the problem ???????? thanks |
02-19-2011, 22:03 | #135 (permalink) |
Member: 1520359 Status: Offline Thanks Meter: 0 | iphone 3gs no audio hello, I have a big problem ... my iphone 3g and I 'fell and broke his touch with the display .. I've changed upon but now it does not work in audio headphones do not get phone calls ... I do not feel, I can not hear system sounds, I do not feel talking on the phone, I replaced the sensor is that the speaker top and bottom Includes microphone ... but nothing .... help me!! |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
