hi i have got a 3GS 16GB with insert sim problrm, customer put the sim tray wrong way and ended up with no sim card inserted in the phone. i put bit pressure on sim tray with my thumb and it used to recognise the sim but soon as i remove my thumb, message appears"no sim card inserted" now i have replaced the sime reader with another one but still having the same problem, anyone could help me to fix this problem please, thanks |
I have an iphone 3gs with version 4.0.2... I have cellular data tab in my network settings but no cellular data network settings..hence, i couldn't activate it... Im a novice when it comes to this and don't know how to proceed further..any help ?? |
iphone 3gs speaker problem hi, my friends speaker on her iphone 3gs import stopped working. she took it to a local shop and they said they could not fix it. is there a known cure for this problem. greg |
no body replay in this thread?????????????????????????????????:mad: |
i think tis thread is to long/big, and some questions a totaly confused. The most answers of this questions are given in other shorter threads. In most cases it will help to work with the "search function" in this forum ;) |
I have an iPhone that does not start and when you put the heat charging in mazim 15 minutes. I opened the card and put the battery in a short board. Do you have a solution? The phone is a 3Gs Do you have a solution? The phone is a 3Gs |
Dude, i m currently on 4.1 with bb 5.14.02. i want to keep me on 4.1 not to 4.2.1. what process should i follow to update bb to 6.15.00 then unlock via ultrasnow. |
HI everyone m on 4.1 with 5.14.02 it is jailbreak with limera1n and working perfectly without sim card, i want to unlock it, please guide me should i restore again to 4.1 coz i dont want to go to 4.2.1 coz of tethered jailbreak. should i again restore n then run redsnow 0.96b5 or what should i do with current situation. please guide in detail step by step process for the battery issue. after run this should i put my original at & t sim n then run rep0666 1.2 for unlock. should i simply click to install ipad baseband in redsnow, or click on both install cydia n ipad baseband ? i m really confuse. |
helloooooo iphone dos"t conect to pc. but with charger charging ok |
iphone 3g show call ended..plz help meee..... thanx AK' |
hi gus i have iphone 4 new not start without charge what i can do plz help |
i phone is disable connect to itunes |
hi bro i have a iphone 3gs has broblem when i trey to restor but it's allways giving unknone error i trey my best but still same can u help me thanks. |
hi mr can u tell me please about a solution for 3Gs with no imei no iccid with greyed bluetooth and wifi if u have a solution ??? |
my iphone 3gs very slow charging, plz help.. |
