Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-27-2011, 12:36   #2476 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,595
Originally Posted by limespirit View Post
Hi,
Fl30 checked and beeps fine. I want to make it clear that everything with regards to sound works apart from speaker, that is mic, headphones, ringer vibrate and earpiece all work fine, it's just the speaker which is not making any sound.
As mentioned yesterday I can't check the caps since I don't own a capacitance meter. However I checked the track between the Dz6 and C195 and track between Dz7 and C194 and they both beep so that makes the Speaker +ve and -ve connections good. What else could be the problem?
Hi
I still not understand what not work internal speaker or what
Old 12-27-2011, 12:52   #2477 (permalink)
Member: 1017374
Thanks Meter: 2,595
Hi,
This chk is for internal speaker.
But for output speaker chk FL10_AP & FL11_AP at dock connector.
Old 12-27-2011, 12:58   #2478 (permalink)
Member: 1176031
Thanks Meter: 62
Hi Wites, the speaker which is not working is the one that is supposed to make sound when listening to music or putting a call on speaker or when you hear the lock sound (when you push the power button to go to sleep)
What do you mean by internal and external speaker? Theres only one speaker no in an iphone?
Old 12-27-2011, 13:07   #2479 (permalink)
Member: 1017374
Thanks Meter: 2,595
Ok i understand now unsolder carefully DZ6_AP & DZ7_AP don't ask why they are s...t.
Also chk speaker itself it must beep 10 ohm.
Check lines from varistors DZ6 & DZ7 to dock pins if arrive.
Old 12-27-2011, 13:15   #2480 (permalink)
Member: 1176031
Thanks Meter: 62
And should i jump dz6 and dz7 after i remove them? Also what is the electric component named dz? Its not a filter or capacitor, right?
by the way fl10 and fl11 (line out left and right) checked and both beep
Thanks
Old 12-27-2011, 13:21   #2481 (permalink)
Member: 1017374
Thanks Meter: 2,595
Thanks
DZ are varistors that are not needed they might short or not short but make problems.
No need to jump them exclude this option.
Old 12-27-2011, 15:22   #2482 (permalink)
Member: 1176031
Thanks Meter: 62
Hey wites,
Dz6 and dz7 are removed, speaker beeps and show 14ohm and varistors pads arrive both at dock pins 30 and 32 and C194 and C195 caps (next to audio IC)
However there is still no sound
Old 12-27-2011, 16:35   #2483 (permalink)
Member: 1017374
Thanks Meter: 2,595
Hey wites,
Check if tracks arrive from C194 & C195 to solder pads of speaker.
Also if you have from other phone speaker assembly check this board in it.
Try restore settings and firmaware.
Also chk with multimeter to track and to gnd if show numbers.
Old 12-27-2011, 17:01   #2484 (permalink)
Member: 1708510
Thanks Meter: 2
iphone 3GS 32GB iTunes recognized but nothing more!
I have two of them with the same problem! iTunes recognizes them, but NO LCD display, NO SOUND, no KEYS response!(vibration) etc..
Measured all common voltages seem ok!.. Problem produced when a guy tried to exchange batteries between them.. he broke the flex of both screens and these screens are white on normal phone.. on these two even backlight doesn't turn on... From where i should start?
i.e. in keys connector all commands seem ok.. but no response from keys! Any help would be appreciated!
Old 12-27-2011, 17:32   #2485 (permalink)
Member: 1176031
Thanks Meter: 62
Do you mean I connect the speaker assembly to the board without battery and check continuity having one probe at cap and the other at speaker pad?
I checked with different speaker assembly and restored to 4.2.1 and still no sound.
Old 12-27-2011, 18:46   #2486 (permalink)
Member: 1017374
Thanks Meter: 2,595
Is volume set at maxim?
You chk with other dock flex also?
Old 12-27-2011, 18:50   #2487 (permalink)
Member: 1176031
Thanks Meter: 62
Volume at max both ringer and application sound. And yes also checked with both flex. Do you think it is a faulty audio IC? I checked there are no cracks on the glue
Old 12-27-2011, 19:11   #2488 (permalink)
Member: 1017374
Thanks Meter: 2,595
1.Chk lines from capacitors to speaker solder pads at dock flex if arrive track
must have 00.1 or 00.2 ohm not more,if it have more make long jumper.
2.Chk with multimeter each of 2 tracks if show numbers with GND,red to track
black to gnd and vice versa see how much numbers show each track.
3.Chk input voltages for audio ic at FL6_AP=1.8V,FL28_AP=3V,FL29_AP=3V
FL30_AP=3.7V,this voltages are not exact check schematic at this filters.
See entire board if not missing some component.
If everything ok this is audio ic problem.
The Following 2 Users Say Thank You to Wites OM Tesla For This Useful Post:
Old 12-27-2011, 19:13   #2489 (permalink)
Member: 1176031
Thanks Meter: 62
must have 1 or 2 ohm not more,if it have more make long jumper.
Thanks Wites, I'll check all these and report.
Old 12-28-2011, 12:04   #2490 (permalink)
kali_fuchi's Avatar
Member: 1705433
Sonork: kali
Thanks Meter: 45
you are right mr.wites
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.28417 seconds with 10 queries
