Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-18-2012, 02:46   #2656 (permalink)
Member: 883543
Sonork: gsm-forum
I just bought iphone 4s (factory unlocked). What are the things I have to do with the phone to use it with Nepal Telecommunication sim?
Old 01-18-2012, 10:42   #2657 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,595
Originally Posted by jcdes View Post
3GS 16 GB newer board Voltage on top of mosfet
Is mosfet supposed to have +5V on top? I just used my multimeter and verified voltage literally on top of mosfet located by power chip and there is +5 right on top of it, is that normal for such a component to be "live" on the outside?
Not turning on, not recognized by pc, tried board on other phone and no good.
Try jump both in place of them maybe they short and phone not power on.
Old 01-18-2012, 16:53   #2658 (permalink)
Member: 1176031
Thanks Meter: 62
Originally Posted by tuli View Post
hello
I have an Iphone 3gs,it stuck at recovery mode and when I connect to pc the iphone restarts everytime. I tried to restore in dfu mode but always itunes give me error 9.
I tried with another usb cable ,with another pc ,I have changed the dock connector but always the same error 9.
maybe a hardware problem?!?!?!?
Please give me a solution !
thank you!
I hardly think this is a hardware problem as error 9 indicates ASR and kernel issues. Try rebooting your machine or else try to restore on a new machine which hasn't got iTunes installed yet so you will start fresh
The Following User Says Thank You to limespirit For This Useful Post:
Old 01-18-2012, 17:00   #2659 (permalink)
Member: 1176031
Thanks Meter: 62
What do you mean what you have to do to the phone...
Put the sim ejecter in the hole of the sim tray put in your sim, close the sim tray and push power on
Old 01-18-2012, 18:41   #2660 (permalink)
Member: 946381
Thanks Meter: 150
which iphone server fast/good service for iphone factory unlock?
Old 01-18-2012, 22:11   #2661 (permalink)
karabey's Avatar
Member: 45183
Thanks Meter: 474
Originally Posted by Wites View Post
By wites13 at 2011-12-05
Chk now bro Oraj for good result.
I have forgot to write in photo green fuse near light driver if it not beep short make jumper.
Do you know which resistor give power if lcd gets light?
The Following User Says Thank You to karabey For This Useful Post:
Old 01-19-2012, 13:08   #2662 (permalink)
Member: 1710261
Question Freezes iPhone 4 cam after focusing
Dears,
I have an iphone 4 (model A1332), it had water damage.
So I went to our "service centre" where masters said that they replaced touchscreen, battery, wi-fi & bluetooth and power controler and returned me my iphone for testing.
In test I found that facetime camera not working(rear cam worked perfectly), so I went to centre again. Masters said that contacts of cam had oxidation (corrosion) and they replaced facetime cam.
Now facetime cam works great, but when I try to change front cam to rear cam, rear cam automatically focuses the image and freezes. After restarting camera application, screen view a closed curtains. But I can change cam again from rear to front after several attempts.
I went to masters again and they have replaced A4 processor by another processor from iPhone which works perfectly, but it also did`t help.
I kindly ask you help for solve this problem if someone have had the same problem.
Thank you and sorry for my English.
Old 01-19-2012, 13:57   #2663 (permalink)
Member: 1710261
Originally Posted by nelson-GreenDay View Post
Dears,
Sorry, Forgot to add that Led-Flash also does not working.
Old 01-19-2012, 14:22   #2664 (permalink)
Member: 1695725
Thanks Meter: 10
Hi Limespirit,
first of all thanks for ur helping thread! awesome
My Problem:
iPhone 4 IOS: 4.3.3
The iphone still get power and itunes also recognize the iphone.
But the iphone lcd stays black. after waiting some minutes the cpu heats up very mutch.
If i disconnect the lcd and power on, the cpu doesnt heat up.
Another Problem is the flashlight of the camera is permanent aktive.
Is there a solution for my problem?
Old 01-19-2012, 17:11   #2665 (permalink)
tuli's Avatar
Member: 511615
Thanks Meter: 35
Hi sir!
I tried with another pc that installed for the first time itunes and in restore again error 9. did you have another idea how to solve this problem?
please help me!
Old 01-19-2012, 17:16   #2666 (permalink)
Member: 1176031
Thanks Meter: 62
Hi sir!
please help me!
Ok what firmware are you trying to restore?
And at what percentage roughly is giving the error? (You can tell me how much of the progress bar is filled on the phone during the restore before it gives error 9)
Have you got older shsh like 3.1.3?
Old 01-19-2012, 17:33   #2667 (permalink)
tuli's Avatar
Member: 511615
Thanks Meter: 35
I have tried the 5.0.1 and 4.1 . the itunes gives error 9 at 0 % at the times when the restore will start and when I connect the iphone to pc at recovery mode the iphone make the dispaly white and restarts .this iphone arrived at my hands with that problem I don't have shsh
Old 01-19-2012, 22:57   #2668 (permalink)
Member: 21937
Thanks Meter: 279
thanks very much
3gs no ear speaker ???
can you post steps ? as all i found didnt fix ear problem
Old 01-20-2012, 12:24   #2669 (permalink)
Member: 1695725
Thanks Meter: 10
no solution 4 my prob ?
Old 01-20-2012, 15:55   #2670 (permalink)
Member: 1176031
Thanks Meter: 62
So the phone is sort of in a dead state? Any heat on the board?
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.28538 seconds with 10 queries
