![]() | #4040 (permalink) |
Junior Member ![]() Join Date: Dec 2010
Member: 1468990 Status: Offline Thanks Meter: 11 | Hello i have a problem with an iphone 4s that is seems home button is always clicked (but it no respond) even if i disconnect the flex cable. However if i try to power on the and i force to enter in dfu the button works. How can i solve it?where is the ic? Thanks |
![]() | #4043 (permalink) |
Junior Member ![]() ![]() Join Date: Sep 2012
Member: 1817515 Status: Offline Thanks Meter: 2 | Hi, iPhone 4S, short circuit on battery connector. Phone in water wasn't, didn't fall, simply took and was switched off. At connection to the computer, itunes finds phone in a recovery mode. In attempt to restore shows different mistakes. Where that on a mainboard short circuit of any capacitor. Which capacitors to look for in the first place? Help please ![]() |
![]() | #4044 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2011 Location: tbilisi, georgia Age: 33
Member: 1679251 Status: Offline Thanks Meter: 385 | ![]() Quote:
there is the solution for that ![]() http://forum.gsmhosting.com/vbb/9281825-post47.html | |
The Following User Says Thank You to Levani_Pmic For This Useful Post: |
![]() | #4045 (permalink) |
Member: 1817515 Status: Offline Thanks Meter: 2 | And iPhone 4G - WiFi greyed. And in the top part of the screen three darkenings (at the left, on the center and on the right). As the insufficient brightness of the display if to put on a maximum, on most put as on a half. Phone in water wasn't. |
![]() | #4046 (permalink) |
Junior Member ![]() Join Date: Jan 2010
Member: 1220118 Status: Offline Thanks Meter: 0 | Hey. Iphone 4 front camera in my hand touch the liquid beautifully cleaned and changed on off socket. C135_RF and C246 removed, integrated in Q2 glass was removed and the jumper, instead of C486 and had no place was FL21, Battery Connector solders renewed. But the phone is connected to pc but the pc sees the apple resets, PC is not connected to the phone resets 15 seconds after the opening, but in the meantime tried to open the locked screen with touch button works but ask imei off the POWER button on the touch screen on the phone is shutting down. the device is being restored smoothly. What is the solution.? |
![]() | #4049 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1917649 Status: Offline Thanks Meter: 0 | ![]() Hey, Got an iPhone 5 no water damage, it fell, the volume flex was broken - replaced it, on the way somehow the ground pin got broken at the battery itself, anyway I've ordered 6 additional batteries, each one same problem - fake charging and rebooting every 5 minutes, any ideas? I think the batteries are poor quality, I do not think this is an issue of the iPhone itself since it worked perfectly fine before the original battery was broken. Do you think of something I can check before returning the batteries to the supplier? ![]() Thanks in advance, Daniel |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
