02-16-2017, 23:26 | #6001 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2672199 Status: Offline Thanks Meter: 0 | Any one can help me? |
02-17-2017, 14:10 | #6005 (permalink) |
Member: 2672199 Status: Offline Thanks Meter: 0 | I used 370 ° to take off the old u2 and to put the new one, and protect with kepton tape the other parts from heat. You think i damaged baseband? So theres no solution in this case? Enviado de meu SM-J500M usando Tapatalk |
02-20-2017, 16:46 | #6007 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2686964 Status: Offline Thanks Meter: 4 | hi all, i'm new in this forum. i have a iphone 6 where i replace wifi ic because after drop, wifi stop work (2,4ghz and 5 ghz). now i replace wifi ic and antenna.... after this only 5ghz is ok.... 2,4ghz wifi not working (in wifi list i only see 5ghz network). how i can fix it? thank's |
The Following User Says Thank You to art83 For This Useful Post: |
02-22-2017, 17:28 | #6009 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2553503 Status: Offline Thanks Meter: 1 | Hi My iPhone 5s freezes when making a call. Otherwise works just fine. Mic and buzzer aren't working even if it unfreezes sometimes. Anyone with a solution? |
The Following User Says Thank You to alexmobihouse For This Useful Post: |
02-24-2017, 04:20 | #6011 (permalink) |
Member: 2686906 Status: Offline Thanks Meter: 0 | Hi, The home button on my iPhone 6 stopped working after I replaced the lcd. I tried replacing both the button and the flex cable, but it still won't work... However the touchID is working fine with the OEM button. I even re-soldered the connector on the motherboard, but nothing... What can I do ? Thanks |
03-04-2017, 08:39 | #6012 (permalink) |
Junior Member Join Date: Mar 2008
Member: 737754 Status: Offline Sonork: [email protected] Thanks Meter: 3 | hi,everyone I have iphone 6s 64gb.....its getting heat when i attached it with charger...no power on.. no charging....what is the problem..i checked it with multimeter its show me the shorting in motherboard...please give me any solution as soon as early....thakyou. |
03-05-2017, 00:08 | #6013 (permalink) | |
Freak Poster Join Date: Apr 2013
Member: 1921245 Status: Offline Thanks Meter: 43 | Quote:
You probably damaged the flex cable maybe on the inside where you cannot see. Also change the cable that transfers the Touch ID to board, long flex. Try Restore phone, sometimes it works Sent from my iPhone using Tapatalk | |
03-05-2017, 00:09 | #6014 (permalink) | |
Usually U2 ic problem. Find short, remove caps, follow line and check what is shorting. Sent from my iPhone using Tapatalk | |
03-06-2017, 15:41 | #6015 (permalink) |
Member: 737754 Status: Offline Sonork: [email protected] Thanks Meter: 3 | will u please tell me proper guidline how to check it thanks |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
