05-06-2011, 07:07 | #1023 (permalink) | |
Crazy Poster Join Date: Nov 2010
Member: 1448091 Status: Offline Thanks Meter: 9 | Quote:
I reflowed BROADCOM BCM6974 (Touchscreen Controller) and NATIONAL SEMICONDUCTOR LM2512AA (Display Interface). Check a iphone Diagram for locations. (this is 3G not 3GS but i guess its kinda the same). just check 3GS diagram before u start. | |
05-06-2011, 07:11 | #1024 (permalink) |
Freak Poster Join Date: Sep 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 354893 Status: Offline Sonork: 100.1579833 Thanks Meter: 21 | Hello, i hv an iphone 4gs,problem is sim nt found. Insert sim card. In sim pin, there no omhz in a pin connector. Really i need in bad position.pls i need sim mezarment,pls help me |
05-06-2011, 12:51 | #1025 (permalink) |
Junior Member Join Date: Jan 2006
Member: 225707 Status: Offline Thanks Meter: 0 | Hi! I have iPhone 3GS.. ARM is so hot, after change battery. I have new battery APN: 616-0435, but i have still same problem.. Any solution ? I don't see any water damage elements.. Sorry for my bad english |
05-07-2011, 10:12 | #1027 (permalink) |
Junior Member Join Date: Nov 2004 Age: 34
Member: 90245 Status: Offline Thanks Meter: 0 | Hello, I have one Iphone 4 with iOS 4.1 . I have a bad problem with DFU Loop. The phone was disabled and i "put in pwned DFU mode" with redsn0w0.9.6.rc8 and restore it with iOS 4.1 restore official. And it stucks in DFU mode. I exit recover with redsn0w0.9.6.rc8 with "just boot tethered right now". The phone turn on and everything was ok, till the moment i turn off it. It go in DFU black screen mode again. I tried with greenpoison to jailbreak, try with redsn0w to jailbreak, and it again Loop in DFU mode. When i try to restore with 4.1 Custom firmware Itunes show me Error 14. Any ideas ? Thanks . |
05-07-2011, 23:34 | #1028 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1533166 Status: Offline Thanks Meter: 3 | Hi, i have iphone 3gs 16gb and ever when try restore get error 9, i think is a hardware problem of flash chip, what i can do??, because i tried all changing usb port/pc, so i have another iphone 3gs 32gb and it restore normal without problems. |
05-07-2011, 23:39 | #1029 (permalink) |
Member: 225707 Status: Offline Thanks Meter: 0 | WorldMaster restore your device using iOS 4.3.2, and use redsn0w 0.9.6rc14 to Untethered JB. redsn0w 0.9.6rc14 - Untethered JB 4.3.2 redsn0w 0.9.6rc15 - Untethered JB 4.3.3 Cheers! |
05-08-2011, 03:23 | #1030 (permalink) |
Registered User Join Date: Oct 2006 Age: 49
Member: 362673 Status: Offline Thanks Meter: 37 | Iphone 4 Dead after mic changing Hi I Have an iphone 4, it had a mic problem. I replaced the mic, i have taken the mic from an other iphone4 (a dead one). After changing the mic with charge connector completly, the phone doesn't want to work anymore. I put the old charge connector but it is the same. The battery is ok, the display too. After connecting to my computer, no signal !!!!! Help !!! Thanks |
05-08-2011, 05:12 | #1032 (permalink) | |
Major Poster Join Date: Nov 2009
Member: 1168213 Status: Offline Thanks Meter: 8 | Quote:
Seems to be a kernel panic. After patching kernel in PwnageTool with custom patches, restore failed with this. iRecovery then showed increased kernel panic count." | |
05-08-2011, 10:25 | #1033 (permalink) | |
Member: 90245 Status: Offline Thanks Meter: 0 | Quote:
05-08-2011, 12:21 | #1035 (permalink) |
Member: 225707 Status: Offline Thanks Meter: 0 | WorldMaster go to Ultimate jailbreak and unlock wizard and check it! |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
