10-04-2011, 16:21 | #1441 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,595 | |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
10-06-2011, 14:53 | #1443 (permalink) |
Junior Member Join Date: Feb 2004 Age: 47
Member: 54896 Status: Offline Thanks Meter: 0 | Iphone 3gs proximity sensor faulty Hi, I have an Iphone 3gs with proximity sensor faulty. I changed sensor flat, connector on pcb and touchscreen but i didn't resolve it. Can anyone help me? Thanks |
10-07-2011, 15:05 | #1446 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1667553 Status: Offline Thanks Meter: 0 | 3gs battery draining sorry for the double post from a other treath but i think i will get a quicker response here... my iphone 3gs went black/dead after i tried to charge it with and external portabloe charger and would not startup anymore. i opened it up and reseated the mobo on the battery and he turned on but got hot and the battery drain was terrible (complete in standby in 2-3 hours) after a wile he started to become normal, without the running hot issue but with a battery drain of 4-5% per hour. now i would like to know if somebody knows witch part got damaged because he act right now quite normal, charges the phone in 2-3 hours from 2%-100%, doesn't run hot, but drains 5%/h in standby without anything turned on (bt, wifi, pusht etc.) the last 2 days i checked the fuse on the charging dock and the fuse seams to be ok, a new battery arrived today and its the same... draining 4-5% per hour. since nothing seams to heat up during use or charging i am not sure if the main trouble comes from the power management ic but maybe im wrong can someone give me further instructions what to do/test on the mobo a big thanx to you |
10-07-2011, 15:27 | #1447 (permalink) |
Insane Poster Join Date: May 2007 Location: brazil
Member: 499010 Status: Offline Thanks Meter: 11 | i have iphone 3gs its problem is during starting hang on apple . i flash in DFU mode with ver 4,1 . and after i restore with help itune it showing me (error 2005) . after i tried again . but still same problem i think the phone was not flashed properly . so please tell me the correct solution ... thankssss |
10-07-2011, 16:01 | #1448 (permalink) | |
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Quote:
Problem connecting. Probably a hardware failure. After what this problem occurred did you dropped in water or on ground? | |
10-07-2011, 16:04 | #1449 (permalink) | |
10-07-2011, 16:10 | #1450 (permalink) |
Member: 1667553 Status: Offline Thanks Meter: 0 | bb 05.16.02 factory unlocked, firmware 4.3.3 without jailbreak since i have saved all shsh blobs from 3.0 to 4.3.5 i tried all kinds of os's and can say it is not caused by software! |
10-07-2011, 17:18 | #1452 (permalink) |
Member: 1667553 Status: Offline Thanks Meter: 0 | well, with a use of aprox. 1.5-2h i can get a maximum of 16-18 hours of the battery life with everything turned off like 3g, location services, bt, push etc if i dont use the phone at all i get a battery loss of 5% per hour = 20 hours of standby time until it reaches 0% from 100% and then turnes off |
10-07-2011, 17:40 | #1453 (permalink) | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
