12-29-2012, 11:31 | #91 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Reball of Big IC Without Stencil. Last edited by Wites OM Tesla; 12-29-2012 at 11:37. |
The Following 7 Users Say Thank You to Wites OM Tesla For This Useful Post: |
12-29-2012, 11:36 | #92 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 4g A4 CPU Reball Without Stencil Video Slideshow. Watch and like most hard was cleaning glue from board and cpu,reball can be done fast. |
The Following 11 Users Say Thank You to Wites OM Tesla For This Useful Post: |
01-26-2013, 00:10 | #93 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 3GS PMIC Replace No Need Stencil,No Need Reball! This how i replace PMIC on iPhone 3GS no need to reball only resolder each print on PMIC then on board fix and heat that is all it take around 10 minutes! Slide show video. |
The Following 9 Users Say Thank You to Wites OM Tesla For This Useful Post: |
03-05-2013, 23:12 | #94 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 4G SWI Line Removed Filter Repair! This how i repair if some pad is removed no need to make long jumpers. |
The Following 5 Users Say Thank You to Wites OM Tesla For This Useful Post: |
05-07-2013, 08:29 | #97 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 4S Battery Connector Repair! This repair if battery connector was removed with 2 middle pads,never use thick wire connector will not align properly. By the way press thanks if this helps! |
The Following 15 Users Say Thank You to Wites OM Tesla For This Useful Post: |
05-13-2013, 21:42 | #98 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 4G Audio IC U62 Reball,No Sound During Call! This method i use almost for all ic only where are big ic i can lift up some more heat or change nozzle,you can see i not use board holder that eat the heat! |
The Following 12 Users Say Thank You to Wites OM Tesla For This Useful Post: |
05-17-2013, 19:16 | #99 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Apple Products Black Resin Clean! Give 180C of heat for harder resin give 190C that is like in iPhone 4S when do this need patience and be careful to not cut some track or remove an component,solvents are not very useful this is best i know! |
05-23-2013, 20:35 | #100 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Repair Removed BGA Print With Thin Wire! Find thin wire in wrist watch and repair any removed print with a track or component that remain. Press thanks bro other video coming soon! |
The Following 14 Users Say Thank You to Wites OM Tesla For This Useful Post: |
05-30-2013, 18:55 | #101 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Removed Solder Pad Fix! Be careful what you do this video is only to show how to fix in case if there is no solder pad to solder the component if it was eaten by water or removed accidentally,never do what i did in first 45 seconds!!!!!! |
The Following 6 Users Say Thank You to Wites OM Tesla For This Useful Post: |
06-04-2013, 18:31 | #102 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Rework of corroded components! This procedure is made when device was water damaged,corroded components need resoldered so all connections are made again like from factory because water eats away solder and some component might loose it's connection and resoldering is the first step when device have problems! |
06-30-2013, 19:53 | #103 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | iPhone 4 Rear Camera Connector Replace! Here are the steps. 1st.Resolder each pin with cyberdocllc QuickAlloy. 2nd.Clean solder with copper wick. 3nd.Solder back new/used connector with normal solder wire that melt harder not low melt solder. 4th.Clean with thinner. To unsolder from used board i used also 180C of heat because cyberdocllc QuickAlloy solder will melt with less temp it was enough 180C to not destroy the plastic. |
The Following 4 Users Say Thank You to Wites OM Tesla For This Useful Post: |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
