Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 05-07-2019, 12:59   #1 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
List NON supported nands IPAD AIR / AIR 2 for S/N replace
JC ADAPT:
32G THGBX2G8D4JLA01
32G THGBX2G8B4JLA01
32G THGBX3G8D4KLA0C
32G H2JTEG8VD1CMS
64G THGBX4G9T4KLF0C
64G H2JTFG8PD1MMR
Option Nand format :YES
NAVIPLUS PRO3000S ADAPTER :
32G THGBX2G8D4JLA01
32G THGBX2G8B4JLA01
32G THGBX3G8D4KLA0C
32G H2JTEG8VD1CMS
64G THGBX4G9T4KLF0C
64G H2JTFG8PD1MMR
Option Nand format (with adapter ) :NO
EASY56 ADAPTER:
Option Nand format : NO
SDMILBCF4
THGBX4G9T4KLF0C
H2JTFG8PD1MMR
TOSHIBA THGBX4T0T8KLF0E 128gb ( tested and non supported )
maybe others...
Nand pro with adapter seems to be the only tool to support nand toshiba 32/64 gb
The Following 10 Users Say Thank You to orx For This Useful Post:
Old 06-07-2019, 09:57   #2 (permalink)
Member: 2904736
Thanks Meter: 6
Hi everyone,
nand with code: H2JTEG8VD1CRM (NAVI read as H2JTEG8VD1CMS) can be read/write with NAVI PLUS with adapter.
The Following User Says Thank You to ackopk For This Useful Post:
Old 06-07-2019, 10:33   #3 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
Originally Posted by ackopk View Post
Hi everyone,
this HYNIX nand no problem is supported .
The Following User Says Thank You to orx For This Useful Post:
Old 06-14-2019, 12:07   #4 (permalink)
Registered User
Member: 1848477
Thanks Meter: 3
Hello, i have a question here, i stumbled across this post while having issues reprogramming a nand on iPad Air. It's a toshiba 32gb model, the original one that was on the iPad, however changing the serial with NaviPlus Pro3000 doesn't work, always activation error. 3u tools reports the serial as the one i've programmed as well as the Wifi/BT macs. What do you mean by 'not supported' ? As the flash chip is the original one on this iPad, it should work, no ? It means the programmers are buggy and not doing the job correctly ?
I've also tried with nand pro and result was the same, activation error. Serial was bought from gsmfather for A7/A8 specifically. Any input would be great, thanks !
Old 06-14-2019, 14:34   #5 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
hello
nand model please
anyway
try with nand pro , format , rewrite boot and write new data
Old 06-14-2019, 14:47   #6 (permalink)
Registered User
Member: 1848477
Thanks Meter: 3
THGBX2G8B4JLA01 is the model.
Old 06-14-2019, 14:58   #7 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
non supported from jc and naviplus , as i've write try with nand pro , check list supported nand (about nand pro)
Old 06-14-2019, 15:16   #8 (permalink)
Registered User
Member: 1848477
Thanks Meter: 3
Ok, but can you explain what you mean as non supported? I dont get any errors in navi plus
Old 06-14-2019, 15:55   #9 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
on naviplus does not appear the writing of the serial is not stored in the nand
on jc error in writing
Old 06-14-2019, 16:59   #10 (permalink)
Registered User
Member: 1848477
Thanks Meter: 3
Yes i can confirm the same, but it's weird, after the write on the nand the ipad is being detected in 3u with the new serial, however itunes will not activate it... Very weird
Old 06-16-2019, 09:28   #11 (permalink)
Crazy Poster
Member: 2871948
Thanks Meter: 3
ON iPad Air YOU HAVE TO CHANGE SN WITH CORRESPONDING WIFI AND MAC ADRESSES
Old 06-16-2019, 12:48   #12 (permalink)
Member: 2904736
Thanks Meter: 6
Hello,
After i write that nand H2JTEG8VD1CMS can be read/write with naviplus 3000s I was got another ipad with this nand and I unable to edit serial, all time I was got old number on 3uTools. Very wierd situation. Today I have air 2 with THGBX4G8D4LLDYC and also can’t change serial. Again the same situation. naviplus read and write new serial but ipad and 3uTools read old serial and another information.
Old 06-18-2019, 14:28   #13 (permalink)
Registered User
Member: 1848477
Thanks Meter: 3
Yes i have seen this also. So naviplus is messing something up it's confirmed.
Now i did a test. iPad Air, 3g. Removed resistor, removed nand, changed serial/bt/wf with nand pro, but didn't write boot files just the serial and macs.
First time got stuck on waiting for ipad, but will check after a nand reflow now.
Do i NEED to write boot files, or format and write boot files ?
Also, need to change model from A1475 to A1474 in nand pro, or removing resistor will do it automatically when restoring ?
Many questions.
Old 06-18-2019, 17:01   #14 (permalink)
Member: 2904736
Thanks Meter: 6
Hi, you didn’t need to write boot files, just change model number. After you remove resistor itunes will automaticaly recognize as a wifi model but you must download wifi ios from ipsw site. After you connect with itunes or 3uTools do Shift + restore and chose file that you download from ipsw site. Also check your stencil for nand. Maybe is stencil bad, maybe is wrong diameter hole and ball are not the same. I was have that problem, side hole are the same diameter but nand pads on side are bigger than inside pads so when I put and melt solder past I get different ball size.
Old 01-08-2020, 16:46   #15 (permalink)
Member: 775445
is it possiable to upgrade ipad air 16gb to 128gb by using jc pro????
Page generated in 0.23999 seconds with 9 queries
