Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-09-2011, 10:29   #16 (permalink)
Member: 77313
Sonork: contact +971529524995
Thanks Meter: 16
ImageShack® - Online Photo and Video Hosting
its power supply jumper see it first ur all answer in image
Old 02-09-2011, 10:43   #17 (permalink)
Member: 77313
Thanks Meter: 16
remove all component who attach with ground at coil and make a wire direct jump on antenna its simple soultion
Old 02-09-2011, 12:05   #18 (permalink)
Member: 1421153
Thanks Meter: 2
iphone not detecting on pc or laptop but charges fine, now stuck on apple logo cannot put in dfu mode, have changed charging port but still same problem.
Old 02-09-2011, 12:19   #19 (permalink)
Member: 77313
Thanks Meter: 16
attach ur phone with ur pc and press power and home booth after that ur set restart now he is in dfu mode leave power button but donut leave home key till end atteach ur phone
The Following User Says Thank You to sohail_19pk For This Useful Post:
Old 02-09-2011, 14:31   #20 (permalink)
Member: 1421153
Thanks Meter: 2
this is problem not going into dfu mode.
Old 02-09-2011, 16:57   #21 (permalink)
Member: 1380602
Thanks Meter: 2
Hello everyone,and you sohail_19pk...I have i4 4.1 1.59.00 FL at&T,jailbroaken snowbreez,,and I have a problem with it.I drop it and since then i have no carrier signal.Try to restore-doesn't work.install and uninstall ultrasn0w-doesn't work.So i deside it's not software.Then get another i4 and put my motherboard in other.Ithink maybe it's the antena.But again it searscing...searching and says no service.I clean all couplings.So its not the antena,in my opinion.So remains to be samthing on motherboard.Can you give me some solution.
Old 02-09-2011, 18:15   #22 (permalink)
Member: 77313
Thanks Meter: 16
your phone will restart when u press home & power key ? if he cant than your home key not work properly
Old 02-09-2011, 18:20   #23 (permalink)
Member: 77313
Thanks Meter: 16
when u insert Sim did u get iccid ? if u cant then check your sim points 2ndly re hot your pa and antenna switch or check the point whose came to antenna
Old 02-09-2011, 18:29   #24 (permalink)
kidgz's Avatar
Member: 551599
Thanks Meter: 139
another qeustion sir
if its just ok
i have her iPhone2g
no imei wifi icced
i think its BASEBAND chip
my qeustion is
can i transfer a working BASEBAND CHIP of 2g to
the other iphone 2g?
tnx you very much sir SOHAIL
http://forum.gsmhosting.com/vbb/f456...olved-1204376/
i solved my problem
tnx bro
Old 02-09-2011, 23:52   #25 (permalink)
Member: 1511860
Was this in reference to my antenna coil question ? If so, do you have a pic of how this jumper would go ?
Old 02-10-2011, 13:54   #26 (permalink)
Member: 77313
Thanks Meter: 16
you send me pic ill edit jumper and send u
Old 02-10-2011, 17:25   #27 (permalink)
Member: 1510912
iphone 3g 8gb
Originally Posted by markeeinsik View Post
okey.. im a bit confused.. your telling me that im having a "main power manager chip problem" right?
and you want me to disassemble my board? how will i do that? you mean open the metal cover of the board to expose the chips?
and remove my battery and attach it to power supply? where will i get the power supply?
and lastly, attach it with itunes? you restore it with itunes?
im sorry, i cant picture it out..
i saw the picture you gave me but i dont know what to do with that..
whats "jumper by the way"?
can you also include pictures..
Old 02-12-2011, 11:50   #28 (permalink)
Member: 1380602
Thanks Meter: 2
Smile
sohail_19pk yes i have iccid when insert sim.And one question where is the point whose came to antenna and how to check it? Can you show exactly antenna swicth and the point whose come to antenna..thank in advance..
Old 02-12-2011, 15:32   #29 (permalink)
Member: 77313
Thanks Meter: 16
antenna jumper
Old 02-15-2011, 08:46   #30 (permalink)
Member: 1380602
Thanks Meter: 2
IBMOBILES First try to restore from DFU, if doesn't work try to change battery and again restore from DFU or Recovery mode,if not change and power dock...this things worked for me usually
Page generated in 0.20019 seconds with 10 queries
