Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-15-2017, 02:42   #1 (permalink)
Member: 2350837
Thanks Meter: 8
Iphone 7 stuck on apple logo
HI, I HAD AN IPHONE 7 FOR SCREEN REPLACEMENT, after diconnecting battery, i removed old screen and put new screen for testing and it got stuck on apple logo, tried putting back old screen, but its still stuck on apple logo, is anyone here faced similar issue?
Old 11-15-2017, 05:24   #2 (permalink)
plentong's Avatar
Member: 44095
Thanks Meter: 38
maybe is Audio ic problem
https://www.youtube.com/watch?v=Bro_fIP2_mY&t=5s
if you can restore finish no error try this solution
i tried 2 pcs 7 and 7plus
it working
The Following User Says Thank You to plentong For This Useful Post:
Old 11-15-2017, 16:55   #3 (permalink)
Member: 657332
Thanks Meter: 16
connect all connectors, home button and front camera flex, unless it will not boot up
Sent from my iPhone using Tapatalk
The Following User Says Thank You to dvdbackuper For This Useful Post:
Old 11-15-2017, 16:57   #4 (permalink)
xe_d_sono's Avatar
Member: 813493
Thanks Meter: 85
Yes! This is VERY IMPORTANT you must have all conect, if phone don't enter in OS.
Old 11-26-2017, 17:36   #5 (permalink)
Member: 278546
Thanks Meter: 145
it working
Ifmphone freezing on logo but home button responds . You can reball audio if fallowed above you tube link, i
Old 11-26-2017, 20:27   #6 (permalink)
plentong's Avatar
Member: 44095
Thanks Meter: 38
yes i do few set already
Old 11-27-2017, 09:17   #7 (permalink)
Member: 2142442
Thanks Meter: 53
Restore it with original display works for me
Old 11-27-2017, 14:02   #8 (permalink)
Crazy Poster
Member: 831155
Thanks Meter: 10
restore the latest firmware and original part to be use.
Old 01-26-2018, 16:17   #9 (permalink)
Member: 2665825
There is a way though so make sure you follow these instructions carefully:
1. Hold the home and power buttons down together
2. The Apple logo should disappear from your screen
3. After a couple of minutes it should reappear – when it does, release the buttons
4. Quickly hold them both down again until your device goes off
5. Plug the USB cable into your computer (not to your device yet)
6. Hold the Home button down and plug the cable to your device
7. When you see the Connect to iTunes screen, release the button
8. iTunes will open and the Device in Recovery message will appear
Click on Restore
If the method can't fix your problem, you may try this method.
Fix Issue Like iPhone Stuck on Apple Logo
Old 10-19-2020, 02:22   #10 (permalink)
Member: 2965059
Maybe iOS system has some problems. You can try these methods.
1. Force Restart iPhone
Press and hold the Power button and Home button together until you see the Apple logo appear on the screen.
2. Put Your iPhone into Recovery Mode
3. Put Your iPhone into DFU Mode
You can try force restart the iPhone first. Press and hold the Power button and Home button together until you see the Apple logo appear on the screen. Put Your iPhone into Recovery Mode. If that does not work, put it into DFU Mode.
Still does not work. Use iOS System fix software like TunesKit iOS System Recovery, which can fix iOS system problems without data loss.
Old 02-03-2021, 06:58   #11 (permalink)
Crazy Poster
Member: 2964041
Thanks Meter: 3
Hey, there, to fix iPhone stuck on Apple Logo, you could try the following ways.
1. Force restart iPhone;
2. Apply Joyoshare UltFix, TunesKit, etc professional iPhone repair tools; (no data loss)
3. Restore iPhone via iTunes. (Data Loss)
Old 02-03-2021, 19:33   #12 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
Stop spamming please. We are on gsmforum, a worldwide forum for professional technicians.
Page generated in 0.22145 seconds with 8 queries
