Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-12-2020, 04:53   #1 (permalink)
Member: 2962202
Thanks Meter: 2
WiFi iPad DCSD S/N iCloud Questions
Has anyone had success booting a non cellular iPad with diags? I hear it can only work on iPad 5/6, iPad mini 4 and both iPad Pro 1st and 2nd Gen until more support is added.... If so what model did you do it on since that is the only way to remove iCloud from WiFi only iPads is to chage the S/N.... I perfer DCSD Alex cable as I don't want to take any iPad apart and need it to be quick. If not when do you think support will be added for more iPads. Or do you even need to boot diags to change S/N of WiFi iPads for iCloud unlock via S/N?
The Following 2 Users Say Thank You to nicehack2020 For This Useful Post:
Old 07-12-2020, 22:50   #2 (permalink)
Member: 2277735
Thanks Meter: 215
Mini 4 and iPad 6 Work for me, wrote new details, tested 10.5 sim and 12.9 WiFi both second generation. They fail on checkm8, once checkm8 works then should supports 12.9 and 10.5 without issue. Can also convert board to WiFi only and the write new details if there are issues with sim.
Old 07-13-2020, 20:58   #3 (permalink)
Miluk's Avatar
Member: 384541
Thanks Meter: 101
For me ipad 6 and ipad 5 not working. Just show error. With iphones not have that issue.
Wysłane z mojego Pixel 3 przy użyciu Tapatalka
Old 07-14-2020, 19:16   #4 (permalink)
Stunman112's Avatar
Member: 2567774
Thanks Meter: 255
need support CFG file 12.9 J127AP (iPad 6,3)
Sent from my SM-G950U using Tapatalk
The Following User Says Thank You to Stunman112 For This Useful Post:
Old 07-14-2020, 19:18   #5 (permalink)
Stunman112's Avatar
Member: 2567774
Thanks Meter: 255
how are these sysCFG files created? looking at them under .txt i can see they must have been extracted from the individual devices.
Old 07-22-2020, 20:15   #6 (permalink)
Member: 67927
Thanks Meter: 108
How did you convert to wifi only model? I can't find a way to change the BoardID to wifi model. Changing model number didn't help.
Old 08-03-2020, 23:15   #7 (permalink)
Member: 2277735
Thanks Meter: 215
https://twitter.com/p3t3ks/status/12...491787269?s=21
iPad Pro 12.9 2nd GEN done manually, took me a few days but got there.
The Following 3 Users Say Thank You to P3T3 For This Useful Post:
Old 08-03-2020, 23:18   #8 (permalink)
Member: 2277735
Thanks Meter: 215
By removing resistor on logic board, a dev told me that we can disable it in software somehow but not worked that out so only hardware I do.
Old 08-04-2020, 01:02   #9 (permalink)
Member: 67927
Thanks Meter: 108
Do you have a picture of the location? im also looking for ipad 5 and 6.
Old 08-21-2020, 08:05   #10 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
hi have in hand this model and unable to diag purple tool give error...can you help with all steps thanks
Old 08-23-2020, 10:16   #11 (permalink)
Member: 2277735
Thanks Meter: 215
I already gave you basics, you have everything...
As said in PM!
Old 09-23-2020, 19:07   #12 (permalink)
Medusin's Avatar
Member: 400280
Thanks Meter: 83
for me work Ipad 5 2017 Wifi... purple 2.01b1 and magicCFG... just done.
Old 09-30-2020, 04:39   #13 (permalink)
Member: 2336705
Thanks Meter: 8
Has anyone had success with iPad Air 2
Hi,
Has anyone had success with iPad Air 2, I can’t get it into diag. Purple gets stuck on sending exploit....and than iPad reboots.
Thanks in advance for help.
Old 09-30-2020, 15:14   #14 (permalink)
Member: 1773784
Thanks Meter: 27
iPad Air 2 im getting the same thing Purple gets stuck on sending exploit
Old 10-01-2020, 13:31   #15 (permalink)
Member: 1939450
Thanks Meter: 165
Sometimes I succeed with purple if i do a restart after each try. Otherwise cant get in. with ipbox it always works.
The Following User Says Thank You to timvandenboo For This Useful Post:
Page generated in 0.19679 seconds with 8 queries
