10-03-2013, 12:46 | #1 (permalink) | |
Freak Poster Join Date: May 2009 Location: lake lanao
Member: 1030567 Status: Offline Thanks Meter: 67 | LG E960 nexux 4 resurection error Quote:
tnx advance | |
10-03-2013, 13:18 | #3 (permalink) | |
Member: 1030567 Status: Offline Thanks Meter: 67 | Quote:
10-03-2013, 23:35 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Goto "DCC Read/Write" Page Press "Setting By Code" Then Select "Read xx" Unselect "Auto Full Flash Size" Now,Select 128 or 256mb in "Data Length" List Press "Read Memory" Then after done,Press "Save" and select "Name for File" and Target for Create file Thx |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
10-04-2013, 07:29 | #7 (permalink) |
Member: 1030567 Status: Offline Thanks Meter: 67 | 128mb files LG E960 nexux4 128files - Download - 4shared - ken adoma 256mb files LG E960 nexux4 256files - Download - 4shared - ken adoma i hope you can solve my problem tnx advance!! |
10-04-2013, 09:46 | #9 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Contact Mr.Legija at ICQ or Me. We are Online Now and We Can Check Your Phone Via Remote Helper Index of /remote Thanks |
10-04-2013, 10:01 | #10 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | @zenk11 Dump looks okay, so this could be some other problem not related to software. Do You know phone history, and have You checked if battery is fully charged? |
11-08-2013, 16:33 | #12 (permalink) |
Major Poster Join Date: Jul 2007
Member: 547943 Status: Offline Sonork: 1596598 Thanks Meter: 5 | Same here... phone dead after resureccton, before red light nad now pc no recondnizes ir, totally dead Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [LG E960 V1.0.5053.51137] Connecting to the dead body...OK Detected dead body ID: 0x107190E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0011/0x0100 (016G92, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0011/0x0100 (016G92, 0x000000400000 Bytes = 4.00 MB) Flashing the dead body...OK Resurrection complete! |
11-08-2013, 16:43 | #13 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | If phone is not detected on usb port as "QHUSB" it means that You just have to charge battery. "Dead" phone would always enumerate in QDLoader mode (QHUSB). |
The Following User Says Thank You to legija For This Useful Post: |
06-19-2014, 12:34 | #14 (permalink) |
No Life Poster Join Date: Apr 2012 Location: Black Market Age: 39
Member: 1744748 Status: Offline Thanks Meter: 752 | Please advise what am I doing wrong??? Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [LG E960 V1.0.5053.51137] Connecting to the dead body...OK Detected dead body ID: 0x107190E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x2A0100000000000000000000064FFFFF Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x07080036 Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface Writting FLASH1 memory from 0x000000000000 to 0x0000064FFFFF ERROR: Selected FLASH Chip was not initialized by the DCC Loader. |
06-19-2014, 12:46 | #15 (permalink) |
Member: 1744748 Status: Offline Thanks Meter: 752 | Another device I am getting this error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [LG E960 V1.0.5053.51137] Connecting to the dead body...OK Detected dead body ID: 0x107190E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 2 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0011/0x0100 (016G92, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0011/0x0100 (016G92, 0x000000400000 Bytes = 4.00 MB) Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3E (0x007FFF <> 0x010000) |
