Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 07-25-2019, 19:10   #1 (permalink)
Registered User
Member: 171336
Thanks Meter: 61
oppo a3s
OPPO A3S CPH 1803 UNLOCK PATTON possible with riff box
Old 08-14-2019, 06:51   #2 (permalink)
shabirahmad22's Avatar
Member: 2293727
Sonork: 100.1660528
Thanks Meter: 450
riff team sleeping..................
The Following User Says Thank You to shabirahmad22 For This Useful Post:
Old 08-20-2019, 20:58   #3 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
http://forum.gsmhosting.com/vbb/f634...nlock-2670501/
Read post
Follow instruction
Br,
The Following User Says Thank You to ~AKSingh~ For This Useful Post:
Old 08-21-2019, 12:26   #4 (permalink)
Member: 1733156
Thanks Meter: 3
this working method?
The Following User Says Thank You to estagent For This Useful Post:
Old 08-21-2019, 12:32   #5 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
Offcource
Working
Br,
Old 08-23-2019, 05:43   #6 (permalink)
Member: 1910376
Thanks Meter: 50
oppo a5 and realme c1 dead after coneect isp
hello sir i connect realme c1 as show pinout and emmc not detect in box and mobile got dead i remove clk resistor bt not solve again i connect oppo a5 and emmc not connet and mobile is dead pls help sir clean pcb no damege pls solve my problem
The Following User Says Thank You to khothbharat For This Useful Post:
Old 08-23-2019, 06:23   #7 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
First of all check the hardware
Mobile cannot go to dead mode simply by connecting emmc connections
You must have made some mistake...or careless handling
Br,
Old 08-23-2019, 07:07   #8 (permalink)
Member: 1910376
Thanks Meter: 50
ok sir i check both pcb totly clean and no damage remove clk
i read other post some user face this problem bt not solve
Old 08-23-2019, 07:09   #9 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
Have you replace clk resistor back to its place ?
Br,
Old 08-23-2019, 07:19   #10 (permalink)
Member: 1910376
Thanks Meter: 50
no i connect by jumper
Old 08-23-2019, 07:42   #11 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
Check online support
Come online there
Br,
Old 08-23-2019, 07:53   #12 (permalink)
Member: 1910376
Thanks Meter: 50
where i check online support ? sir plz explain
Old 08-23-2019, 07:55   #13 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
Sticky thread
Br,
Old 08-26-2019, 15:25   #14 (permalink)
.::JYOTIRMAY::.'s Avatar
Member: 1440339
Sonork: 100.1616914;CHOLOMAN
Thanks Meter: 116
I have done more than one REALME C1(RMX1811) and OPPO A3S there is no issue /cause of dead.
Join Riff box Viber group for proof/ more explanation.
First off all cut the metal shield very carefully.
Second soldier iron may take a part of dead( use dc iron with low voltage) because over hitting may damage smd parts.
For Realme C1 first remove clk resistor. After successful resurrection just make a jumper(no need to replace clk resistor).
Believe me and make a try. You should get success.
Old 08-27-2019, 12:15   #15 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 517
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.51 (RIFFBOX1), JTAG Manager Version: 1.86
Selected Package: [Oppo A3s CPH1853 Reset V1.02 by <legija>, <RJ-45>, 1 Bit Bus Width (DAT0)]
Connecting to the SD/eMMC Card...OK
Set I/O Voltage reads as 1.79V, SD_CLK Frequency is 2.50 MHz
Memory Type .......................... eMMC
Manufacturer ID ...................... 0x90
OEM/Application ID ................... 0x4A
Product Name ......................... "HCG8a4"
Package .............................. BGA
User Area Partition Size ............. 0x000E8F800000 Bytes (58.24 GB)
Boot Partition Size .................. 0x000000400000 Bytes (4.00 MB)
RPMB Partition Size .................. 0x000000400000 Bytes (4.00 MB)
OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity)
Write Protection Bits ................ NONE
ExtCSD Register Fields ............... [177] = 0x00, [179] = 0x38, [162] = 0x01
Boot Configuration ................... Boot from User Area (Bus Width = 1 Bit)
Chip Revision ........................ 10.2
Multimedia Card Revision ............. 1.8 (eMMC v5.1)
Serial Number ........................ 0x4C31D266
Memory Manufacturing Date ............ August, 2018
Detected eMMC Chip, ID: 0x90/0x4A (HCG8a4), User Area Partition = 0x000E8F800000 Bytes (58.24 GB)
Analizing the FullImage File:
Looking for the MBR Signature ................... ERROR
ERROR: Failed to read data from the connected Device!
notwork
The Following User Says Thank You to SAJONDUTTA For This Useful Post:
Page generated in 0.22320 seconds with 8 queries
