05-11-2018, 13:24 | #196 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Chin
Member: 1531030 Status: Offline Sonork: Yahoo_Akm Thanks Meter: 118 | Riff Box-1 idea Maybe good for team & Users Quote:
http://forum.gsmhosting.com/vbb/f634.../#post13127361 This is My Hand Made & Which is Best For You ? | |
05-11-2018, 17:35 | #197 (permalink) | |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Quote:
Please see very carefully... That is Official Instroduction For RIFF Box 1 (For eMMC ISP Connectivity)... Just Follow Yellow Mark in PCB ~ A & B... A = VCC & B = VCCIO | |
05-12-2018, 12:58 | #198 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Cebu Phils.
Member: 183390 Status: Offline Thanks Meter: 74 | hello there sir , My riff box was the old version . Its ver 1. also i already have an account . but i wasn't able to use the box for quite a time now. and i was reading on support that there are so many models are on the list . I was kinda optimistic to use the box again. Is ther a way to sue my old box again . so i can able to make some money out of it. thanks a lot |
05-15-2018, 14:22 | #199 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF Box 1/2 updates - JTAG Manager v1.78, eMMC Plugin v4.09, 12 new models Hello, RIFF Box v1/v2 updates, 15.05.2018: RIFF Box JTAG Manager v1.78 --------------------------- - (SDK): more functions are now available (exported) for future Resurrector DLLs; - PKG Editor: added button 'Visual Conditional Writes' - which helps sorting write actions into specified groups of conditions Those who have experience in PKG creation will understand the purpose. - Fixed SD/MMC voltage list for RIFFBOX1 - Fixed correct partition name logging when reading/writting via Direct EMMC interface RIFF Box v1 users now have option to fine tune VCCIO (VCCQ) voltage in order to achieve best stability. VCCIO can be increased/decreased in 0.05v steps. We recommend this procedure if nominal 1.8v VCCIO doesn't work properly. eMMC Partition Table FullFlash Image Files Processing Plugin (eMMCDiskPartitions.dll) v4.09 ------------------------------------- - "Load Firmware Files" button is added. This feature will allow to load official firmware files directly into recognized partitions. At the release moment only MTK Scatter Files are supported. - Added MTK Scatter Files support. Please note, to load a Scatter File, first is required for plugin to Load a valid Dump (Load Layout from File or read Layout from Device (Load Layout from Device). After partitions layout is recognized by plugin, a Scatter File can be loaded: files of partitions listed in scatter file will be automatically injected into current Layout. - Plugin now supports OTHERS THAN the User Area partition!!! For example, if after parsing, plugin detects extra used partitions (e.g. boot partition1 in some Samsung phones, boot partition1,2&RPMB in some phones with MTK MCU-based layout) then these partitions are displayed in the partitions list too. User can work with these partitions as usual - read/write, inject data from file, storing to disk, etc - plugin will automatically manage data redirection to proper hardware locations of the eMMC chip. - Added column "LOCATION ON CHIP" - displays hardware location of the current partition inside the eMMC Chip (Boot parition1,2, User Area, etc.) - Keyboard shortcuts are added for Read Partitions button (F6) and Flash partition button (F7) - Context menu is expanded with same new minor features (right-click on any partition in the partitions list window) - 'PRESENT' column is added to the partitions list. This shows info about each partiton - whether partition is available in dump file or dump ends prematurely (100% - means partition is completely present in dump file, 0% - partition is not present in dump file, between 0 and 100 - partition is partially available, but a definite part of it is not available due to premature end of dump file) - 'SIZE' column is added to the partitions list. This shows human-understandable size in KBs/MBs/GBs/TBs - HEX window now supports 'NOT_AVAILABLE' data displaying: the '**' is displayed instead of HEX data for areas when data is not available (for example this is true when local dump file size is less than current partition address, so the plugin cannot obtain data for such case) (for example this is true when plugin failed to read data on-the-fly due to read errors) - Progress bar in HEX window is fixed for chunks of data of size up to ~32GB, but still is not full 64-bit wide, thus weird behaviour is expected for partition sizes more than ~32GB (more than 0x7FFFFFFF0 bytes = 31,9999GB) - Due to obsolete meaning, removed ACTIVE and SELECTED columns in the parsed partitions list. - Added new column 'RELATIVE PARTITION' to the parsed partitions list. Plugin now supports relative partitions, base of which depends on connected physical eMMC chip. Thus the real address is calculated by plugin on-the-fly, during read/write operations. For relative partitions, 'RELATIVE PARTITION' column shows relative offset from the end of the chip area where partition must be located. In this case the 'STARTING OFFSET' column shows absolute address calculated at the moment of parsing (that is if partitions were parsed from dump file, the starting offset is calculated using dump's file size; if partitions were parsed from connected emmc device, then starting offset is calculated using current emmc chip's user area size). This address will be recalculated every time any read/write on this partition is performed. P.S. Real life relative partitions can be found in MTK-based devices (BMPOOL partition), Samsung phones (SGPT partition) - added keyboard control to the partitions list window. One can navigate through partitions with keyboard keys, select/deselect single entry with ENTER key, use INSERT key to select an entry and automatically move cursor down. In case the plugin is invoked by the JTAG Manager (PKG Editor, MassStorage selector, etc.) the ESC key serves the function of buttons "Back to MassStorage" and "Back to PKG Editor" - The order of focused controls when TAB key is pressed is sorted correctly. - Option "When parsing is possible from GPT and PIT, force discarding PIT so GPT data is used" is transfered to CheckBox for better convenience. It is named "PIT Dumps -> Force EFI Layout" - Option "When parsing is possible from MBR and MTK Tables, force discarding MTK layout, so data from MBR/EBR is used" is transfered to CheckBox for better convenience. It is named "MTK Dumps -< Force MBR Layout" - Double progress is implemented - to display read/write progress of current partition and total read/write progress of selected group of partitions - Color of selected text in partitions list window is adjusted - For MBR/EBR parsing added feature to resize last partition into reasonable size: sometimes last partition is reported having maximum possible size (~2TB). If layout is read from device then last partition is resized to fit into the current memory chip. If layout is read from a local dump file then the last partition is resized to fit into the 58.25GB memory chip. - after parsing supported file system into Embedded F/S Explorer, loss of foreground position of the main plugin window bug is fixed - 'Check for Blank' operation is made more informative: each partiton checking progress is drawn. Blank partitions are grayed out in the partitions list, so blank partitions are visible instantly. Checking for blank is improved - partitions which have "NOT_AVAILABLE" data status are considered to be blank and time is not lost doing unnecessary checks (especially big sized partitions) LG Models boot repair, ISP pinout, Read/Write eMMC:
To download and install updates, click "Check for Updates" button on "Box Service" tab. You can also register an account at Turbo-Support download server: Index of ../../RIFF/RIFF_ROOT/ RIFF Box v1 (Black box) users who havent used 15 days trial can activate it after installing JTAG Manager v1.76 and downloading new data. In case that trial period is used but fw version is still 1.48 or older, please request trial reset in "Account recovery" section. Box S/N and "Trial reset" required. |
The Following 30 Users Say Thank You to legija For This Useful Post: |
05-15-2018, 15:53 | #201 (permalink) | |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
The Following User Says Thank You to legija For This Useful Post: |
05-19-2018, 18:04 | #203 (permalink) |
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Small update for today 19.05.2018 (By Legija Sir) HTC Desire D728h (2PQ830000) Huawei U8815 Samsung G800H Samsung N910T Last edited by Pijush Das; 05-20-2018 at 00:03. |
The Following User Says Thank You to Pijush Das For This Useful Post: |
05-31-2018, 13:42 | #206 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF Box v1/v2 updates, 31.05.2018 52 new models RIFF Box updates, 31.05.2018
The Following 42 Users Say Thank You to legija For This Useful Post: |
05-31-2018, 13:54 | #207 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, boss, is there a way to repair boot to LG LS775 by USB??? or only available solution is ISP/EMMC??? |
The Following 2 Users Say Thank You to Shensohau For This Useful Post: |
05-31-2018, 14:25 | #209 (permalink) |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | Hello sir can you add dead boot samsung s7 edge SM-G935P dead after flashing combination files UFS type ic |
The Following 2 Users Say Thank You to MARVZ_TG For This Useful Post: |
