Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 05-10-2019, 08:18   #31 (permalink)
Member: 2605593
Thanks Meter: 4
i need QLM tab and Repair imei...
Old 05-11-2019, 02:56   #32 (permalink)
Member: 1200900
Thanks Meter: 3
keep it up
keep it up infinity team
Old 05-12-2019, 17:31   #33 (permalink)
mohammed imran's Avatar
Member: 533912
Thanks Meter: 115
nokia 3.1 boot error
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
- > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage!
Waiting for device connection ...
PTFN : MediaTek USB Port (COM13)
MODE : BOOTROM
PORT : 13
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : DSLevel : DEV_KEY
BROM : BOOTROM
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6755
AGENT : Nokia DownloadAgent ver.07220419 BEST2
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
DA : SETUP EMI PARAMS FAILED!
ERROR : ABORT
Error : Fail to init protocol!
Reconnect Power/Cable!
Old 05-15-2019, 18:35   #34 (permalink)
Member: 2637597
Sonork: 100.1680047
Thanks Meter: 11
thanks a lot of thanks best team
Old 05-16-2019, 11:29   #35 (permalink)
Member: 2266425
Thanks Meter: 58
Card found : , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.14
Firmare path for FeaturePhone products NOT set!
Select it in settings first!
Operation : Read FirmWare [ v1.14 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
PTFN : Nokia USB Serial Port (COM13)
MODE : NOKIA USB SERIAL
PORT : 13
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000005
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 2597233111B0471BEB687942869C343B
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : NEMO61D.10.00.11.p2
BOOT : SWR : 10.00.11
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : NEMO61D.10.00.11.p2
FLASH : 00C2 : 0025 : 0036 : 0000
CODE : 0x00370000
Reading Flash ...
TDSN : TA-1114
PRDC : 059Z0X8
PPM : IJ
LANG :
[1] : Urdu (Islamic Republic of Pakistan)
[2] : English (United Kingdom)
BUILD : TA-1114_ROM_eMP_10.00.11
BUILD : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001
BUILD : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001
BUILD : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001
BUILD : TA-1114_VIVA_eMP_10.00.11
Make VPL definition
Save Path : G:\TA-1114\
Save Name : TA-1114_059Z0X8_10.00.11.vpl
Build Finished!
Done!
Elapsed: 00:06:04
Old 05-17-2019, 07:24   #36 (permalink)
Member: 2266425
Thanks Meter: 58
focus on qualcom oreo cm2 not suported new chinees models like oppo a83 vivo y91 etc plese update we need more power
Old 05-17-2019, 15:14   #37 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
MODE : BOOTROM
PORT : 13
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
ERROR : ABORT
Use LATEST BEST2 version for start, atleast one, mentioned in thread.
Old 05-19-2019, 14:19   #38 (permalink)
mazentel..'s Avatar
Member: 155719
Thanks Meter: 93
Originally Posted by YellowBoss View Post
Infinity-Box [BEST] NK2 v1.16 - Android 9 firmwares support, model finder
- MTK flash engine updated ( Feature Line )
- MTK flash engine updated ( SmartPhone Line )
- Android 9P firmwares can not be flashed in Nokia 5.1/3.1/3.1+ , fixed
- Model selector over TA/RM identifier activated. Double click on model to open required tab
- Base
Loader database updated
Bugfixes and minor changes
- Support
New firmwares can be found on support for all supported lines
Download link
- How to upload files to support
Infinity-Box 14 years (2005 - 2019) updates and support as nobody else !
i cant access to support file please help
Old 05-19-2019, 16:36   #39 (permalink)
Member: 2387344
Thanks Meter: 37
Infinity Box Setup Download Free
Download infinity box latest setup absolutely free from this page.
Link: Infinity Box Setup Download
Old 05-22-2019, 12:30   #40 (permalink)
hafiz4saqib's Avatar
Member: 2289628
Thanks Meter: 226
Nokia 106 (TA-1114) Repair Security
How to Repair/Write IMEI on Nokia 106 (TA-1114)
Repair Security option available in Nokia SP tab.
Old 05-23-2019, 10:50   #41 (permalink)
JayDi's Avatar
Member: 462970
You can repair it only over SWP - BEST allow swap security from one device to another on Nokia 106. And you can't enter number, which you want.
It like samsung certs, in simple words.
The Following 5 Users Say Thank You to JayDi For This Useful Post:
Old 05-27-2019, 14:16   #42 (permalink)
Member: 2289628
Thanks Meter: 226
I dont want SWAP sec from one to another mobile.
I want repair original imei which written its own the sticker.
Old 05-27-2019, 14:53   #43 (permalink)
Member: 718470
Thanks Meter: 79
Originally Posted by hafiz4saqib View Post
I have Nokia 2 (TA-1029).
Its can Identify but no such option for write firmware or I am in wrong section.
And all tabs are disabled.
i have same problem ta 10-29
The Following User Says Thank You to gsmiulian For This Useful Post:
Old 05-27-2019, 15:09   #44 (permalink)
JayDi's Avatar
Member: 462970
If you don't have backup with this digits - then you can't.
Old 05-29-2019, 10:59   #45 (permalink)
dany_boy's Avatar
Member: 1977629
Thanks Meter: 429
only nokia 106 able to read write security over swp or any other modles also done with same function?
Page generated in 0.25126 seconds with 8 queries
