![]() | #91 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2012 Location: < Man is stronger than stone.>
Member: 1744389 Status: Offline Sonork: 100.1657056 Thanks Meter: 215 | Reading Phone Info.... Connected phone - Nokia C2-01 Software ver : V 11.40 24-10-12 RM-721 (c) Nokia IMEI : 357376044178591 DSP Ver : SPR91_11.40 PPM : V 11.40 24-10-12 RM-721 (c) Nokia D CNT : Content: d_059D681 V 11.40 24-10-12 RM-721 (c) Nokia Product SN : 07D2E06AH Product code : 059D673 Base Prd.code: 059C872 Module code : 0204769 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : 51 Tahvo : 00 Batery: 3471 mV CMT BT: 1673-46038 LCDVer: SEIKO Lock info =========== IMEI : 357376044178591 IMEI spNet : 3A 75 73 06 44 71 58 09 IMEI svNet : 33 75 73 06 44 71 58 79 F6 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Damaged!!!!! PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
![]() | #93 (permalink) |
Member: 1744389 Status: Offline Sonork: 100.1657056 Thanks Meter: 215 | Looks like im not fit for this job.. ![]() Phone found! Series 40 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 357376044178591 Key file exists, no need to read... Break SdRepReq (on alive SD) by user Repair fail...! Repair SD procedure started... Phone Imei: 357376044178591 Key file exists, no need to read... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connection error #1 Server not found... SX4 Auth error ![]() Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 357376044178591 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Seek file for this phone.... ----------------------------- - > RPL file found for this phone! - > NPC Found in : 357376044178591.rpl Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! WMDRM key found! ----------------------------- Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600000001020C192102044100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 2090010A6F9F5740FC1485BF064B1850C750E933 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! ![]() TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ![]() ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Wait, reconneting... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Key... Ok! Writing SimLock Data... Ok! Product Code Update : 059D673 SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security Damaged!!!!! ![]() - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 WMDRM_PD key sent... Ok Done! Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 357376044178591 Key file exists, no need to read... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connection error #1 Server not found... SX4 Auth error ![]() Uploading RF/Battery tune to phone... Using : RM-721.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 Upload failed Reading Phone Info.... Connected phone - Nokia C2-01 Software ver : V 11.40 24-10-12 RM-721 (c) Nokia IMEI : 357376044178591 DSP Ver : SPR91_11.40 PPM : V 11.40 24-10-12 RM-721 (c) Nokia D CNT : Content: d_059D681 V 11.40 24-10-12 RM-721 (c) Nokia Product SN : 07D2E06AH Product code : 059D673 Base Prd.code: 059C872 Module code : 0204769 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : 51 Tahvo : 00 Batery: 3691 mV CMT BT: 1673-46038 LCDVer: SEIKO Lock info =========== IMEI : 357376044178591 IMEI spNet : 3A 75 73 06 44 71 58 09 IMEI svNet : 33 75 73 06 44 71 58 79 F6 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Damaged!!!!! PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
![]() | #95 (permalink) |
Member: 1744389 Status: Offline Sonork: 100.1657056 Thanks Meter: 215 | thanks for replying and help offered.. Will check for new version of BEST, when i learn more about nokia flashing...meantime this c2-01 stays in closet of customer and for a while.. all the best |
