11-19-2014, 08:40 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Looking for Nokia 108/130/220/225 dumps Main things - should be with SMS/Phonebook inside. Better - if bigger counts inside. If you have some time and clean phone - make copy from sim card to phone and make readout. Better send in PrivateMessage due private/personal information inside dump. Clean dumps NOT interested! |
11-22-2014, 23:42 | #4 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | i have Nokia225 rm-1012 i can read info from powered phone w/o problem but how to read fullflash? when i press Read flash - prog asks to connect phone on USB and after phone restarts does it mean problem with drivers or what? |
12-05-2014, 18:09 | #9 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | I have 3 different Nokia 225 and all cant upload job and even read flash seems BEST dont work correctly with new loaders BEST v 1.98 try to upload job: phone powered off Code: --- Insert USB cable now! --- Wait for phone... Phone found! [ 125 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : CCEF6B85234FE6268915DE0DCE95C96A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : AA DA_JUMP : 00AAAAAA DA_INFO : 0xAA , Ver : 170.170 , BBID : 0xAA DA_CSTAT : 0xAA SOC Verify failed! Error Code : 0x00 Connect phone on selected interface... phone powered on Code: Software Info: 20.10.11 00-00-00 RM-1012 IMEI: 3523950xxxxxxxx PPM version : EI Product code: 059W329 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 125 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : CCEF6B85234FE6268915DE0DCE95C96A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : AA DA_JUMP : 00AAAAAA DA_INFO : 0xAA , Ver : 170.170 , BBID : 0xAA DA_CSTAT : 0xAA SOC Verify failed! Error Code : 0x00 Connect phone on selected interface... |
12-05-2014, 18:18 | #10 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | It work , for sure - if check over forum - there is hundred logs with those phones. Due log - something wrong with PC - Win/Drivers/Cable - much things can be. There was not much changes in booting between versions was, so can't even adjust anything, because it is working. |
12-07-2014, 23:10 | #12 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | tried new ver 1.99 still not working tried on 3 different Nokia 225 "Nokia USB Serial Port" seems to be installed correctly Code: Software Info: 20.10.11 00-00-00 RM-1012 IMEI: 3523950xxxxxxxx PPM version : EI Product code: 059W329 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 125 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : CCEF6B85234FE6268915DE0DCE95C96A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : AA DA_JUMP : 00AAAAAA DA_INFO : 0xAA , Ver : 170.170 , BBID : 0xAA DA_CSTAT : 0xAA SOC Verify failed! Error Code : 0x00 Connect phone on selected interface... |
12-08-2014, 09:22 | #13 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | I not found any bugs on 3 pc's and 5 phones at all, check in different os and modes. Will compile test one today or tomorrow for check on your side. |
12-09-2014, 13:09 | #14 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | i tried these phones again on v1.99: win7 - works reading flash and uploading job XP - not work drivers used from support i think still bug in sw |
