05-16-2019, 12:03 | #32 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | correct me if im wrong Quote:
so this post is all about read and write only? | |
05-30-2019, 15:20 | #34 (permalink) |
Insane Poster Join Date: Nov 2001 Location: Poland
Member: 7612 Status: Offline Thanks Meter: 15 | Ta-1022 can write firmware ta-1006 ,works, dual sim menu stays visible.Single sim model has hidden second imei,also can write 15xxx firmware to 20xxx (downgrade).Tested . So if your language is unavailable u can try cross flashing. File : TA-1022_20.0.0.17.00_AX_059Z3N5.sprd SWVersion : 20.0.0.17.00_AX_059Z3N5 Operation : Write FirmWare [ v1.16 ] Setting : False : Full Factory Reset Setting : True : NVRAM Update/Swap 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! [NVM] : Initialize SRC [NVM] : Initialize DST [NVM] : Prepare [NVM] : SWP : 0x000B : 0x000A [NVM] : Update [NVM] : Update Ok! Flash : KERNELIMG Flash : BOOTLOADER Flash : USERIMG Flash : MMIRES Flash : DSPCODE Flash : DSPCODE2 Erase : ERASE AUTOSMS Erase : ERASE PRELOAD Flash : PRELOAD Erase : FLASH Flashing finished! Done! Elapsed: 00:01:20 Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! SW_VERS : 20.0.0.17.00 PC_EXTR : AX 059Z3N5 IMEI[1] : 357305086****** IMEI[2] : 352751019****** BT_ADDR : D7725165A390 Security saved : NKSPDv2_357305086******.scnv Done! Elapsed: 00:00:28 Reconnect Power/Cable! Card found : 252258CA , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 File : TA-1006_20.0.0.17.00_AW_059Z3B7.sprd SWVersion : 20.0.0.17.00_AW_059Z3B7 Operation : Write FirmWare [ v1.16 ] Setting : False : Full Factory Reset Setting : True : NVRAM Update/Swap 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! [NVM] : Initialize SRC [NVM] : Initialize DST [NVM] : Prepare [NVM] : SWP : 0x000B : 0x000A [NVM] : Update [NVM] : Update Ok! Flash : KERNELIMG Flash : BOOTLOADER Flash : USERIMG Flash : MMIRES Flash : DSPCODE Flash : DSPCODE2 Erase : ERASE AUTOSMS Erase : ERASE PRELOAD Flash : PRELOAD Erase : FLASH Flashing finished! Done! Elapsed: 00:01:21 Reconnect Power/Cable! Last edited by Hepatus; 05-30-2019 at 15:25. |
The Following User Says Thank You to Hepatus For This Useful Post: |
06-02-2019, 03:04 | #35 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Also we updates support area with new language packs freqently, depend on users dump upload activity. |
06-03-2019, 02:06 | #36 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Somewhere in the World Age: 54
Member: 9848 Status: Offline Thanks Meter: 144 | GDPR prohibits the transfer of personal data without consent in this case. Since you are crypting the backup nobody can look into it and check, if personal data are included in the backup or a consent can be given. So please switch off the encryption. |
06-03-2019, 03:06 | #37 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
We work with different forensic stuff from a long time and have idea about GDPR and it local variations. When user uploading data to our server, he can be sure about anything, what can be inside, include security and device unical data, will be removed from server after making firmware. | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
06-03-2019, 23:36 | #38 (permalink) |
Member: 9848 Status: Offline Thanks Meter: 144 | If you have idea of GDPR does not matter at all. The transfer of personal data in this way especially to a non-EU country is prohibited. So please switch off the encryption. |
06-04-2019, 02:42 | #39 (permalink) | |
Will add special string in EULA for this case, if you sleep bad with this problem. | |
06-09-2019, 14:51 | #40 (permalink) |
Member: 9848 Status: Offline Thanks Meter: 144 | Why should I delete what I have paid for? You are the person who have to be compliant: Art. 3 No. 2 GDPR This Regulation applies to the processing of personal data of data subjects who are in the Union by a controller or processor not established in the Union, where the processing activities are related to: a) the offering of goods or services, irrespective of whether a payment of the data subject is required, to such data subjects in the Union; or |
06-09-2019, 16:53 | #41 (permalink) | |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Hey Quote:
08-11-2020, 22:21 | #43 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | Hello, was just playing with one 3310... I dont see the SP Unlock b utton available. using Best 2 1.20 I can read the the phone info and read flash, didnt try to write anything. is it worth the wait for sp unlock solution ? Quote:
11-23-2020, 14:56 | #45 (permalink) | |
Freak Poster Join Date: Nov 2019 Location: isr
Member: 2937153 Status: Offline Thanks Meter: 103 | Quote:
i thought thats not possible because best2 creating firmware only with .sprd encrypted files. | |
