04-30-2016, 08:43 | #1 (permalink) |
Junior Member Join Date: May 2011 Location: Poland
Member: 1583869 Status: Offline Thanks Meter: 10 | Nokia 130 RM-1035 Contact Service! I received a phone right to the message and try to fix it in a way that I do I read RPL backup then it can flash by product code 059W071 upload the whole procedure is successful. The problem is, however, how Loading a backup security RPL is the info I have damaged IMEI visible in the log. Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info : IMEI : 35371407107xxxx BBUID : C7DDEF8609987C9BF91B5E6591AD5733 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 35371407107xxxx_MTKx_2nd.mtsec Read Done! ================================================== ============== Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.02.11 00-00-00 RM-1035 IMEI 1 : 123456789012345 IMEI 2 : 123456789012345 XappVer : 00000898 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : AD CNT : CRYSTAL.10.02.11.p1 Product code : Hardware info======= HWID : LCDVer: TPO Lock info =========== IMEI : 123456789012345 IMEI spNet : 0A 00 00 00 00 00 00 00 Lock info: SimLock status : Ok Security status : Damaged!!!!! Done! |
04-30-2016, 09:31 | #3 (permalink) |
Member: 1583869 Status: Offline Thanks Meter: 10 | On a sticker under the battery have clearly RM -1035. Under the product code are two versions of the software 10.01.10 - i not tried, because I can not find 10.02.10 - for this version I as described |
04-30-2016, 13:00 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Did you read my post? Better just attach here RPL backup. I will check it and say ezxactly where problem is. |
05-02-2016, 08:34 | #9 (permalink) | |
Member: 1583869 Status: Offline Thanks Meter: 10 | Quote:
Ok file here http://www.filedropper.com/353714071072481mtkx | |
07-16-2016, 10:16 | #14 (permalink) |
Member: 1583869 Status: Offline Thanks Meter: 10 | Hello! The latest update Best v2.22 saved phone and here's the log: Core : v2.22 , MTKx FlashEngine : v9.9 Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Software Info: 10.01.11 00-00-00 RM-1035 IMEI: 123456789012345 PPM version : MH Product code: 059W2F9 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : C7DDEF8609987C9BF91B5E6591AD5733 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 Boot Ok Get settings... [INFO] : Encrypted RPL [RPL VERIFY] : Code 0x10 : MOBILE_ID match with MOBILE_ID info in RPL! Trying recover security data ... Security restored Wait for re-connection ... Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : C7DDEF8609987C9BF91B5E6591AD5733 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done PostFixing ... PostFix done! All done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.01.11 00-00-00 RM-1035 IMEI 1 : 35371407107XXXX IMEI 2 : 35371407107XXXX XappVer : 000008AC Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : MH CNT : CRYSTAL.10.01.11.p2 Product SN : AC499EAAU Product code : 059W071 Base Prd.code: 059W669 Module code : 0206396 Hardware info======= HWID : 3200 LCDVer: TPO Lock info =========== IMEI : 35371407107XXXX IMEI spNet : 3A 35 17 04 17 70 42 18 Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Thx! Last edited by pawel-ciesla3; 07-16-2016 at 10:23. |
The Following 4 Users Say Thank You to pawel-ciesla3 For This Useful Post: |
