Nokia 130 RM-1035 Contact Service! Hello, I received a phone right to the message and try to fix it in a way that I do I read RPL backup then it can flash by product code 059W071 upload the whole procedure is successful. The problem is, however, how Loading a backup security RPL is the info I have damaged IMEI visible in the log. Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info : IMEI : 35371407107xxxx BBUID : C7DDEF8609987C9BF91B5E6591AD5733 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 35371407107xxxx_MTKx_2nd.mtsec Read Done! ================================================== ============== Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.02.11 00-00-00 RM-1035 IMEI 1 : 123456789012345 IMEI 2 : 123456789012345 XappVer : 00000898 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : AD CNT : CRYSTAL.10.02.11.p1 Product code : Hardware info======= HWID : LCDVer: TPO Lock info =========== IMEI : 123456789012345 IMEI spNet : 0A 00 00 00 00 00 00 00 Lock info: SimLock status : Ok Security status : Damaged!!!!! Done! |
Hello. Seems as it is not a RM-1035, but another RM ( or RM1036 , RM1037 , RM1122 ) |
On a sticker under the battery have clearly RM -1035. Under the product code are two versions of the software 10.01.10 - i not tried, because I can not find 10.02.10 - for this version I as described |
I'm sorry my mistake! As for the software version:mad: 10.01.11 - i not tried , because I can not find 10.02.11 - for this version I as described |
Did you read my post? Better just attach here RPL backup. I will check it and say ezxactly where problem is. |
I can not put any attachment request to the admin of the solution to the problem. |
Does it really hard upload file to any sharing then put link here without http prefix??? |
i also recieved many phones with contact service...whats the solution? |
Ok file here http://www.filedropper.com/353714071072481mtkx |
If anyone can help solve the case of security ? Please help anyone:( |
Hi! Thank you for updating Best dongle. The phone finally rescued. Regards.:cool: |
Please, post operation logs as well. It help us improve next SW version more. |
Hello! The latest update Best v2.22 saved phone and here's the log: Core : v2.22 , MTKx FlashEngine : v9.9 Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Software Info: 10.01.11 00-00-00 RM-1035 IMEI: 123456789012345 PPM version : MH Product code: 059W2F9 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : C7DDEF8609987C9BF91B5E6591AD5733 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 Boot Ok Get settings... [INFO] : Encrypted RPL [RPL VERIFY] : Code 0x10 : MOBILE_ID match with MOBILE_ID info in RPL! Trying recover security data ... Security restored Wait for re-connection ... Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : C7DDEF8609987C9BF91B5E6591AD5733 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done PostFixing ... PostFix done! All done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.01.11 00-00-00 RM-1035 IMEI 1 : 35371407107XXXX IMEI 2 : 35371407107XXXX XappVer : 000008AC Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : MH CNT : CRYSTAL.10.01.11.p2 Product SN : AC499EAAU Product code : 059W071 Base Prd.code: 059W669 Module code : 0206396 Hardware info======= HWID : 3200 LCDVer: TPO Lock info =========== IMEI : 35371407107XXXX IMEI spNet : 3A 35 17 04 17 70 42 18 Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Thx!;) |
nokia 130 how to flash contact service |
