nokia 130 security damage |
Check device by Read RPL, if Ok -then try flash correct SW version to repair it. |
Need RM-1035 V14.00.11 flash please Not available on Navimanager Thanks |
flash v10.01.11 problem slove |
now many pcs showing problem condact service how can fix this plzz help urgently infinnty team becose i will flash 3 pce nokia it is all now codact service |
no solutionnnnn hardwer |
nokia rm 1035 cod 059w037 need flash file conect servis solution plz help me |
RM-1035 contact service problem Card found: S/N : , v0122 Registered to: Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IM_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IM_MEA_BH_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IM_MEA_BH_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 184 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 57037B035C235583B4E8B5AF56159CA9 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IM_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IM_MEA_BH_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IM_MEA_BH_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IM_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IM_MEA_BH_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IM_MEA_BH_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IM_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IM_MEA_BH_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IM_MEA_BH_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:59 Reboot phone Ok Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok |
the best way is reading rpl |
Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 17 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : A291C772B2770D88E419472B947CB60A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : AA DA_JUMP : AAAAAAAA DA_AUTH : Fail! DA Run failed! Connect phone on selected interface... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 17 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : A291C772B2770D88E419472B947CB60A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : Code 0x08 : CBR Info is wrong! CBR SN not match with BB SN! Say thanks to some "great chinese tools" for kill your phone If backup not done - phone just a brick RPL Saved to : 353714079752365_MTKx_2nd.mtsec Read Done! Connect phone on selected interface... is RPL ok? its say's CRB Info is wrong. what can i do for contact service?? :confused::confused::confused: |
JayDi where to find v13 or 12................? |
