05-11-2017, 10:51 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: eproom memory Age: 41
Member: 264366 Status: Offline Thanks Meter: 29 | I got same issue after flash 130 , contact service Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info IMEI : 354895080640407 BBUID : F8237DD2A00F968D5CAC0D3586339881 PCCode: 059W035 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 354895080640407_MTKx_2nd.mtsec Any solution please guys , software 2.28 |
05-11-2017, 11:34 | #3 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
05-11-2017, 14:23 | #4 (permalink) |
Member: 264366 Status: Offline Thanks Meter: 29 | Connect phone on selected interface... Core : v2.28 , MTKx FlashEngine : v12.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IM_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IM_MEA_BH_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IM_MEA_BH_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 19 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : F8237DD2A00F968D5CAC0D3586339881 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.11.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IM_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IM_MEA_BH_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IM_MEA_BH_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.11.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IM_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IM_MEA_BH_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IM_MEA_BH_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IM_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IM_MEA_BH_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IM_MEA_BH_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:05 Reboot phone Ok Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 11.00.11 00-00-00 RM-1035 IMEI 1 : 123456789012345 IMEI 2 : 123456789012345 XappVer : 000008E8 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IM CNT : CRYSTAL.11.00.11.p1 Product SN : 03FFCAABU Product code : 059W035 Base Prd.code: 059X9M1 Module code : 0207191 Hardware info======= HWID : 3200 LCDVer: TPO Lock info =========== IMEI : 123456789012345 IMEI spNet : 0A 00 00 00 00 00 00 00 Conf key : 0000000000040000 Provider key : 0000000000000000 Country : Unknown Operator : Unknown Lock info: SimLock status : Ok Security status : Damaged!!!!! Done! |
05-12-2017, 09:41 | #6 (permalink) |
Member: 264366 Status: Offline Thanks Meter: 29 | Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 19 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : F8237DD2A00F968D5CAC0D3586339881 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.11.00.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info IMEI : 354895080640407 BBUID : F8237DD2A00F968D5CAC0D3586339881 PCCode: 059W035 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 354895080640407_MTKx_2nd.mtsec Read Done! Connect phone on selected interface... |
05-12-2017, 09:47 | #7 (permalink) |
Member: 264366 Status: Offline Thanks Meter: 29 | Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IC_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IC_MEA_JO_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IC_MEA_JO_eMP_11.00.11_002 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 19 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : F8237DD2A00F968D5CAC0D3586339881 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.11.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IC_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IC_MEA_JO_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IC_MEA_JO_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.11.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IC_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IC_MEA_JO_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IC_MEA_JO_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IC_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IC_MEA_JO_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IC_MEA_JO_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:03 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 11.00.11 00-00-00 RM-1035 IMEI: 123456789012345 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : IC Product code: 059W035 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security Damaged!!!!! Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Seems security is damaged . How to fix it please |
05-12-2017, 12:11 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | There is can be few reasons : 1. Downgrade ( almost possible ) you post not first try log, seems, so can't say exactly what has been inside phone before. 2. Wrong RM. |
05-23-2017, 09:39 | #9 (permalink) | |
Member: 264366 Status: Offline Thanks Meter: 29 | Quote:
--- Insert USB cable now! --- Wait for phone... Phone found! [ 19 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : F8237DD2A00F968D5CAC0D3586339881 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.14.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.02.11 SecureDecrypt : RM-1035_VIVA_eMP_10.02.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_AD_eMP_10.02.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_AD_EURO_DE_eMP_10.02.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_AD_EURO_DE_eMP_10.02.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.14.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.02.11 Write : RM-1035_LANG_PACK_ROM_AD_eMP_10.02.11_001 Write : RM-1035_CUSTPACK_ROM_AD_EURO_DE_eMP_10.02.11_001 Write : RM-1035_JUMP_TABLE_AD_EURO_DE_eMP_10.02.11_001 Write : RM-1035_VIVA_eMP_10.02.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.02.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_AD_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_AD_EURO_DE_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_AD_EURO_DE_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_VIVA_eMP_10.02.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now | |
05-12-2017, 14:28 | #11 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | If you flash other sw version ppm/cnt/jmpt - then it can go to such state. Try find first flashing log from it. Preferably when it was fully alive. Is it was? |
