09-29-2020, 16:17 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | RM-1187 after flashing best contact service??? Registered to: gsmiulian Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 138 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0865D432AB32994FF76624C55DF4770A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : SUEZ.40.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Suez.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 Executing FFS FORMAT now... FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:46 Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 138 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0865D432AB32994FF76624C55DF4770A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1187_SUEZ_ROM_eMP_12.00.11 VIVA : RM-1187_SUEZ_VIVA_eMP_12.00.11 LANG : RM-1187_SUEZ_LANG_PACK_ROM_IC_eMP_12.00.11 CUST : RM-1187_SUEZ_CUSTPACK_ROM_IC_eMP_12.00.11 JMPT : RM-1187_SUEZ_JUMP_TABLE_IC_eMP_12.00.11 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 138 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0865D432AB32994FF76624C55DF4770A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : SUEZ.40.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Suez.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 SecureDecrypt : RM-1187_SUEZ_ROM_eMP_12.00.11 SecureDecrypt : RM-1187_SUEZ_VIVA_eMP_12.00.11 SecureDecrypt : RM-1187_SUEZ_LANG_PACK_ROM_IC_eMP_12.00.11 SecureDecrypt : RM-1187_SUEZ_CUSTPACK_ROM_IC_eMP_12.00.11 SecureDecrypt : RM-1187_SUEZ_JUMP_TABLE_IC_eMP_12.00.11 Executing FFS FORMAT now... FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE OVRLP : 000069B900000001 PHPID : SUEZ.40.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1187_SUEZ_ROM_eMP_12.00.11 Write : RM-1187_SUEZ_LANG_PACK_ROM_IC_eMP_12.00.11 Write : RM-1187_SUEZ_CUSTPACK_ROM_IC_eMP_12.00.11 Write : RM-1187_SUEZ_JUMP_TABLE_IC_eMP_12.00.11 Write : RM-1187_SUEZ_VIVA_eMP_12.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1187_SUEZ_ROM_eMP_12.00.11 [VERIFY] DONE : RM-1187_SUEZ_LANG_PACK_ROM_IC_eMP_12.00.11 [VERIFY] DONE : RM-1187_SUEZ_CUSTPACK_ROM_IC_eMP_12.00.11 [VERIFY] DONE : RM-1187_SUEZ_JUMP_TABLE_IC_eMP_12.00.11 [VERIFY] DONE : RM-1187_SUEZ_VIVA_eMP_12.00.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:02:44 Reboot phone Ok ReadInfo can't be done! Re-insert battery and power up phone manually Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1187_ROM_eMP_40.00.11 VIVA : RM-1187_VIVA_eMP_40.00.11 LANG : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 CUST : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 JMPT : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 138 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0865D432AB32994FF76624C55DF4770A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : SUEZ.12.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Suez.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 SecureDecrypt : RM-1187_ROM_eMP_40.00.11 SecureDecrypt : RM-1187_VIVA_eMP_40.00.11 SecureDecrypt : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 SecureDecrypt : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 SecureDecrypt : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 OVRLP : 000069B900000001 PHPID : SUEZ.12.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1187_ROM_eMP_40.00.11 Write : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 Write : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 Write : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 Write : RM-1187_VIVA_eMP_40.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1187_ROM_eMP_40.00.11 [VERIFY] DONE : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 [VERIFY] DONE : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 [VERIFY] DONE : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 [VERIFY] DONE : RM-1187_VIVA_eMP_40.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:59 Reboot phone Ok Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1187_ROM_eMP_40.00.11 VIVA : RM-1187_VIVA_eMP_40.00.11 LANG : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 CUST : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 JMPT : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 138 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0865D432AB32994FF76624C55DF4770A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : SUEZ.40.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Suez.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 SecureDecrypt : RM-1187_ROM_eMP_40.00.11 SecureDecrypt : RM-1187_VIVA_eMP_40.00.11 SecureDecrypt : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 SecureDecrypt : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 SecureDecrypt : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 OVRLP : 000069B900000001 PHPID : SUEZ.40.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1187_ROM_eMP_40.00.11 Write : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 Write : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 Write : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 Write : RM-1187_VIVA_eMP_40.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1187_ROM_eMP_40.00.11 [VERIFY] DONE : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 [VERIFY] DONE : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 [VERIFY] DONE : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 [VERIFY] DONE : RM-1187_VIVA_eMP_40.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:59 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds - > AfterFlash Not Done! Reason : Driver/Connection fault or HW Error Re-insert battery and PowerUp phone manualy Phone disconected! Connect phone on selected interface... Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1187_ROM_eMP_40.00.11 VIVA : RM-1187_VIVA_eMP_40.00.11 LANG : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 CUST : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 JMPT : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 138 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0865D432AB32994FF76624C55DF4770A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : SUEZ.40.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Suez.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 SecureDecrypt : RM-1187_ROM_eMP_40.00.11 SecureDecrypt : RM-1187_VIVA_eMP_40.00.11 SecureDecrypt : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 SecureDecrypt : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 SecureDecrypt : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 OVRLP : 000069B900000001 PHPID : SUEZ.40.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1187_ROM_eMP_40.00.11 Write : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 Write : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 Write : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 Write : RM-1187_VIVA_eMP_40.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1187_ROM_eMP_40.00.11 [VERIFY] DONE : RM-1187_LANG_PACK_ROM_IC_eMP_40.00.11_001 [VERIFY] DONE : RM-1187_CUSTPACK_ROM_IC_MEA_MA_eMP_40.00.11_001 [VERIFY] DONE : RM-1187_JUMP_TABLE_IC_MEA_MA_eMP_40.00.11_001 [VERIFY] DONE : RM-1187_VIVA_eMP_40.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:07 Reboot phone Ok Connect phone on selected interface... i write 3 version ver 10 ver 12 and ver 40 now phone is in contact service |
09-29-2020, 17:42 | #4 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | --- Insert USB cable now! --- Wait for phone... Phone found! [ 162 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0865D432AB32994FF76624C55DF4770A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : SUEZ.40.00.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : Code 0x08 : CBR Info is wrong! CBR SN not match with BB SN! Say thanks to some "great chinese tools" for kill your phone If backup not done - phone just a brick RPL Saved to : 357758101526244_MTKx.mtsec Read Done! Connect phone on selected interface... Say thanks to some "great chinese tools" for kill your phone If backup not done - phone just a brick i use only best and contact service after write flash |
