02-07-2019, 11:25 | #736 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Online Thanks Meter: 1,273 | Nokia 3310 TA-1030 Language flash done -------------------------- Card found : 07XXXXXX , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Open VPLfile : TA1030_059X9V9_11.02.11.vpl Description : TA-1030 NDT EURO ED GREY LATIN HR DeviceType : TA-1030 ProductCode : 059X9V9 SoftwareVer : 11.02.11 PPM LangPack : [1] : Slovenian (Slovenia) [2] : Croatian (Croatia) [3] : Hungarian (Hungary) [4] : Bosnian (Bosnia and Herzegovina) [5] : FYRO Macedonian (Former Yugoslav Republic of Macedonia) [6] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : False Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM925) MODE : NOKIA USB SERIAL PORT : 925 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : False Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM925) MODE : NOKIA USB SERIAL PORT : 925 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 751CDCCB483FC9407EDBBA22A14B8813 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00C2 : 0025 : 0038 : 0000 NOR: [MXIC] MX25U12835FZNI_10G NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1030] DEV SoftwareVersion : 11.02.11 SWInfo compare result : SAME Load FlashSet : LANG : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001 CUST : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001 JUMP : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001 Prepare FlashSet : DCR : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001 DCR : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001 DCR : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 Erase Target Flash Erase done! Write Target Flash Write : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001 Write : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001 Write : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001 Verify : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001 Verify : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001 Done! Elapsed: 00:01:26 Reconnect Power/Cable! |
The Following User Says Thank You to gile@gile For This Useful Post: |
02-07-2019, 13:58 | #737 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 105 (TA-1034) write Urdu Language Done :) Code: Open VPLfile : TA-1034_059Z107_30.04.11.vpl Description : TA-1034 IJ DeviceType : TA-1034 ProductCode : 059Z107 SoftwareVer : 30.04.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : False Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM53) MODE : NOKIA USB SERIAL PORT : 53 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCA02 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 1426FA865C738818AED7B88E8EBBEEE9 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0020 : 0016 : 0000 NOR: [MXIC] MX25L3291FWJI_09 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.04.11 [TA-1034] DEV SoftwareVersion : 30.04.11 SWInfo compare result : SAME Load FlashSet : LANG : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 CUST : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 JUMP : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Prepare FlashSet : DCR : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 Write : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 Write : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 Verify : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 Verify : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Done! Elapsed: 00:00:47 Reconnect Power/Cable! |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
02-08-2019, 13:15 | #738 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | nokia ta-1010 bangla flash done Code: Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM92) MODE : NOKIA USB SERIAL PORT : 92 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : EAA452A70454BAD3407F97986D55727C BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.11.00.11.p1 BOOT : SWR : 11.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.11.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 12.00.11 [TA-1010] DEV SoftwareVersion : 11.00.11 SWInfo compare result : DEVICE SW ( Minor version ) is LOWER, than in VPL! Load FlashSet : MROM : TA-1010_ROM_eMP_12.00.11 LANG : TA-1010_LANG_PACK_ROM_MH_eMP_12.00.11_001 CUST : TA-1010_CUSTPACK_ROM_MH_INDIA_IN_eMP_12.00.11_001 JUMP : TA-1010_JUMP_TABLE_MH_INDIA_IN_eMP_12.00.11_001 VIVA : TA-1010_VIVA_eMP_12.00.11 Prepare FlashSet : DCR : TA-1010_ROM_eMP_12.00.11 DCR : TA-1010_LANG_PACK_ROM_MH_eMP_12.00.11_001 DCR : TA-1010_CUSTPACK_ROM_MH_INDIA_IN_eMP_12.00.11_001 DCR : TA-1010_JUMP_TABLE_MH_INDIA_IN_eMP_12.00.11_001 DCR : TA-1010_VIVA_eMP_12.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1010_ROM_eMP_12.00.11 Write : TA-1010_LANG_PACK_ROM_MH_eMP_12.00.11_001 Write : TA-1010_CUSTPACK_ROM_MH_INDIA_IN_eMP_12.00.11_001 Write : TA-1010_JUMP_TABLE_MH_INDIA_IN_eMP_12.00.11_001 Write : TA-1010_VIVA_eMP_12.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1010_ROM_eMP_12.00.11 Verify : TA-1010_LANG_PACK_ROM_MH_eMP_12.00.11_001 Verify : TA-1010_CUSTPACK_ROM_MH_INDIA_IN_eMP_12.00.11_001 Verify : TA-1010_JUMP_TABLE_MH_INDIA_IN_eMP_12.00.11_001 Verify : TA-1010_VIVA_eMP_12.00.11 Done! Elapsed: 00:01:09 Reconnect Power/Cable! |
The Following User Says Thank You to kothamamun For This Useful Post: |
02-08-2019, 19:39 | #739 (permalink) | |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Nokia Asha RM-902_{Hanging At Logo}_Successfully solved... Full logs of the operation/ Quote:
The Following User Says Thank You to lyes_albert For This Useful Post: |
02-09-2019, 08:23 | #740 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 108 Read User Code Done :) Code: Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 12.06.11 00-00-00 RM-944 IMEI 1 : 359186058999503 IMEI 2 : 359186058999511 XappVer : 000008F2 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IJ CNT : Bree.12.06.11.p1 Product SN : 493534EBH Product code : 059S7R0 Base Prd.code: 059S0R7 Module code : 0205624 Hardware info======= HWID : 1001 LCDVer: TPO Lock info =========== IMEI : 359186058999503 IMEI spNet : 3A 95 81 06 85 99 59 30 Conf key : 800000000004000B Provider key : 0010100000000000 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Software Info: 12.06.11 00-00-00 RM-944 IMEI: 359186058999503 PPM version : IJ Product code: 059S7R0 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 53 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 67E785D33DE0B2CC7CBA7B86211D1414 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.12.06.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA0_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 MT625x : Read User Code User Code : 008855 Done! Connect phone on selected interface... |
02-10-2019, 14:03 | #741 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | nokia asha 206 Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q4J7 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358371054105948 IMEI 2 : 358371054105955 PCcode : 059S8K9 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358371054105948_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:49 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:31 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q4J7 Image : package_m2_059Q4J7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:08 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x5521 Flashing done! Total flash time : 00:03:09 Reboot phone now... |
The Following User Says Thank You to Luckey1 For This Useful Post: |
02-13-2019, 10:17 | #742 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 206 flash done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q4J7 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 355902054616261 IMEI 2 : 355902054616279 PCcode : 059Q8L5 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355902054616261_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:08 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:27 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:21 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q4J7 Image : package_m2_059Q4J7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:04:26 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:26 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x5521 Flashing done! Total flash time : 00:08:10 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 355902054616261 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q8L5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:04 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
02-13-2019, 13:46 | #743 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 3310 Reaset User Code Done Operation : Reset Settings [ v1.08 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM20) MODE : NOKIA USB SERIAL PORT : 20 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 3566798C1616AC751F6EE546881AD1E0 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.10.03.11_2.p1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.10.03.11_2.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00C2 : 0025 : 0038 : 0000 NOR: [MXIC] MX25U12835FZNI_10G NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CD0000 : 0x00324000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
02-19-2019, 08:19 | #744 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 3 Remove User Lock Done :) Code: Operation : Identify [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM188) MODE : PRELOADER PORT PORT : 188 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 450100444634303136011C8BA92A4A61 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 450100444634303136011C8BA92A1461 EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : ABBF87B0D8499A69CCBADA54D522032B STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! --- SysInfoSub : Patch Level : O00623 Display ID : 00WW_3_38G Ver. CodeName : REL Ver. Release : 8.0.0 Sec. Patch : 2018-11-05 Build Time : 1540552027 Product Model : NE1 Product Brand : alps Product Name : NE1_00WW_FIH Product Device : NE1 Product Manfct : alps Product Info : NE1 Board Platform : mt6737m --- SecuritySub : IMEI[0] : 356049087854xxx IMEI[1] : 356049087854xxx NVRAM check : Passed! Done! Elapsed: 00:00:24 Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM188) MODE : PRELOADER PORT PORT : 188 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 450100444634303136011C8BA92A4A61 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 450100444634303136011C8BA92A1461 EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : ABBF87B0D8499A69CCBADA54D522032B STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
02-19-2019, 13:39 | #745 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 206 Write Only CNT File Done :) Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm872__04.52.image_m2_059V0F5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358372053782380 IMEI 2 : 358372053782398 PCcode : 059S8K5 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\358372053782380_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [CNT]=== File : rm872__04.52.image_m2_059V0F5 Image : package_m2_059V0F5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:23 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:22 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xA340 Flashing done! Total flash time : 00:01:47 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 358372053782380 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059S8K5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:02:41 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
02-20-2019, 15:12 | #746 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Narowal
Member: 207708 Status: Offline Sonork: 100.1602241 Thanks Meter: 1,005 | Nokia 105 2017 TA 1034 Flashing Done With CM2 Nokia 105 2017 TA-1034 Flashing Done With CM2 Here are logs Youtube link https://www.youtube.com/watch?v=JvLJ...ture=********* Last edited by umarnlw; 02-20-2019 at 15:19. |
The Following User Says Thank You to umarnlw For This Useful Post: |
02-22-2019, 06:16 | #747 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 3310 Reset Settings Done Operation : Reset Settings [ v1.08 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM44) MODE : NOKIA USB SERIAL PORT : 44 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 779E27A93A59CFAEC2C9269C56D3A76F BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00C2 : 0025 : 0038 : 0000 NOR: [MXIC] MX25U12835FZNI_10G NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CD0000 : 0x00324000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:03:21 Reconnect Power/Cable! |
02-22-2019, 15:50 | #748 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 108 format done PTFN : MediaTek PreLoader USB VCOM Port (COM44) MODE : NOKIA USB SERIAL PORT : 44 BROM : Init BROM BROM init passed! CHIP : MT625A , SBID : 0xCA01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7E99CB91857D6C29E37005A424929675 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : Bree.20.06.11.p4 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT625A AGENT : Bree.20.06.11.p4 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x88 NOR: 00EF : 0040 : 0016 : 0000 NOR: [WINBOND] W25Q32BV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x003A6000 : 0x0004E000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
02-24-2019, 08:37 | #749 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 150 / HMD RM-1190 Operation : Write FirmWare [ v1.08 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM44) MODE : NOKIA USB SERIAL PORT : 44 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 5F485F5C2186208D479861DCBFC2343D BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.40.00.11.p1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.40.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0020 : 0016 : 0000 NOR: [MXIC] MX25L3291FWJI_09 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! Load FlashSet : MROM : RM-1190_DUBAI_ROM_eMP_30.00.11 LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 JUMP : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 VIVA : RM-1190_DUBAI_VIVA_eMP_30.00.11 Prepare FlashSet : DCR : RM-1190_DUBAI_ROM_eMP_30.00.11 DCR : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 DCR : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 DCR : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 DCR : RM-1190_DUBAI_VIVA_eMP_30.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1190_DUBAI_ROM_eMP_30.00.11 Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_VIVA_eMP_30.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1190_DUBAI_ROM_eMP_30.00.11 Verify : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 Verify : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 Verify : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 Verify : RM-1190_DUBAI_VIVA_eMP_30.00.11 Done! Elapsed: 00:01:13 Reconnect Power/Cable! |
02-24-2019, 09:11 | #750 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia X2-02 Fullflash Done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm694__11.84.mcusw PPM : rm694__11.84.ppm_m_a CNT : rm694__11.84.image_m_a_059D1B3 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 353295050379667 IMEI 2 : 353295050379675 PCcode : 059P1X1 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353295050379667_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm694__11.84.mcusw Image : rm694__11.84.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01980000 Erasing, wait ... Erase done, time : 00:00:49 Write , Start : 0x40280000 , Len : 0x01900000 Flashing , wait ... Region flash done, time : 00:00:33 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xB615 ===Flashing [PPM]=== File : rm694__11.84.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:09 Write , Start : 0x41C00000 , Len : 0x00440340 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x40FC ===Flashing [CNT]=== File : rm694__11.84.image_m_a_059D1B3 Image : package_m_a_059D1B3.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:01:03 Write , Start : 0x42300000 , Len : 0x00DC0000 Flashing , wait ... Region flash done, time : 00:00:17 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x1F63 Flashing done! Total flash time : 00:03:05 Reboot phone now... Reading Phone Info.... Connected phone - X2-02 Software Info: V 11.84 13-09-12 RM-694 (c) Nokia IMEI: 353295050379667 PPM version : V 11.84 13-09-12 RM-694 (c) Nokia M_A Product code: 059P1X1 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 43 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:13 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
