NOKIA 206 RM-872 Flash Done By Infinity Best Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__03.59.mcusw PPM : rm872__03.59.ppm_mh2 CNT : rm872__03.59.image_mh2_059Q316_059R9M3_232_01 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__03.59.mcusw Image : rm872__03.59.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:41 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:40 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xB02A ===Flashing [PPM]=== File : rm872__03.59.ppm_mh2 Image : package_mh2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:11 Write , Start : 0x41A80000 , Len : 0x005392C8 Flashing , wait ... Region flash done, time : 00:00:08 CRC check passed , 0xAB61 ===Flashing [CNT]=== File : rm872__03.59.image_mh2_059Q316_059R9M3_232_01 Image : rm872__03.59.image_mh2_059Q316_059R9M3_232_01.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:07 Write , Start : 0x42100000 , Len : 0x01080000 Flashing , wait ... Region flash done, time : 00:00:26 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xCF52 Flashing done! Total flash time : 00:03:23 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 03.59 24-12-12 RM-872 (c) Nokia IMEI: 3578890578XXXXX PPM version : V 03.59 24-12-12 RM-872 (c) Nokia MH2 Product code: 059R9M3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:22 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
Nokia 7210 flashing done Code: Core : v2.29 , BB5XG FlashEngine : v10.5 |
Nokia Asha 230 old flashing done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm986_14.0.6.mcusw.fls PPM : rm986_14.0.6_059V2Q3_m1.rofs.fls CNT : rm986_14.0.6_059V2Q3_m1.image.fls Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 221 [XMM2210 QIMING] IF uCHIPID : 194200021C030101CA8A180982A22C44D9883B00FFFF IF Resp Data : 194200021C030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : 1_1336.500_MKEYSKEY QIMING EEP config Ok FLASHID : 52F00000 , [ NOR ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359983051867285 IMEI 2 : 359983051867293 Phone Product Code : 059V2Q3 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359983051867285_XG 221_CRT.rpl ===Flashing [MCU]=== Processing file : rm986_14.0.6.mcusw.fls Region count : 2 00 : [ PSI ] : rm986_14.0.6.mcusw.fls.fls 01 : [ Code ] : rm986_14.0.6.mcusw.fls.fls Parse done , flashing now Flash : 00 : rm986_14.0.6.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40000000 , Len : 0x00020000 Erase done Region Start : 0x40000000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done rm986_14.0.6.mcusw.fls.fls image flash done Flash : 01 : rm986_14.0.6.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40040000 , Len : 0x00020000 Erase done Erase area 0x01 , Start 0x40060000 , Len : 0x00160000 Erase done Erase area 0x02 , Start 0x40340000 , Len : 0x023C0000 Erase done Erase area 0x03 , Start 0x47E00000 , Len : 0x00040000 Erase done Region Start : 0x40040000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40060000 , Data Len : 0x00160000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40340000 , Data Len : 0x01E69954 Region Load done Wait for phone write all data ... Write done rm986_14.0.6.mcusw.fls.fls image flash done ===Flashing [PPM]=== Processing file : rm986_14.0.6_059V2Q3_m1.rofs.fls Region count : 1 00 : [ Cust ] : rofs_ebl_psi.fls Parse done , flashing now Flash : 00 : rofs_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x42880000 , Len : 0x00F80000 Erase done Region Start : 0x42880000 , Data Len : 0x005EBE5C Region Load done Wait for phone write all data ... Write done rofs_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm986_14.0.6_059V2Q3_m1.image.fls Region count : 1 00 : [ Cust ] : rm986_14.0.6_059V2Q3_m1.image.fls.image.fls Parse done , flashing now Flash : 00 : rm986_14.0.6_059V2Q3_m1.image.fls.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x43800000 , Len : 0x04600000 Erase done Erase area 0x01 , Start 0x47E40000 , Len : 0x000E0000 Erase done Region Start : 0x43800000 , Data Len : 0x02A60000 Region Load done Wait for phone write all data ... Write done rm986_14.0.6_059V2Q3_m1.image.fls.image.fls image flash done Flashing done! Total flash time : 00:02:14 Reboot phone now... Reading Phone Info.... Connected phone - 230 Software Info: V 14.0.6 10-07-14 RM-986 (c) Nokia IMEI: 359983051867285 PPM version : fad8cc0caecb31d1dae24dfac82405b7f6ee7a45 Product code: 059V2Q3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... ===== WARNING ===== Battery voltage is NOT enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:02:57 |
Nokia 3310 User Code Reset Done --- Insert USB cable now! --- Wait for phone... Phone found! [ 266 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 912671FD4EAB7EEFFF377BF065A5059E BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : RETRO.11.02.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info IMEI : 357314089985968 BBUID : 912671FD4EAB7EEFFF377BF065A5059E PCCode: 059Z014 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 357314089985968_MTKx.mtsec Read Done! --- Insert USB cable now! --- Wait for phone... Phone found! [ 266 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 912671FD4EAB7EEFFF377BF065A5059E BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
NOKIA ASHA 210 WRITE FIRMWARE DONE Card found: S/N : A6936825 , v0137 Registered to: yuslamuique Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : 1FBBABE4_rm924__06.09.mcusw PPM : F8DA1D82_rm924__06.09.ppm_mel CNT : 6A12511D_rm924__06.09.image_mel_059R786 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359955054035300 IMEI 2 : 359955054035318 PCcode : 059R9P6 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359955054035300_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : 1FBBABE4_rm924__06.09.mcusw Image : rm924__06.09.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01A40000 Erasing, wait ... Erase done, time : 00:00:59 Write , Start : 0x40280000 , Len : 0x01A40000 Flashing , wait ... Region flash done, time : 00:00:35 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip [Minor Error] : CRC returned by phone is wrong! [CHK] : 0100E361 ===Flashing [PPM]=== File : F8DA1D82_rm924__06.09.ppm_mel Image : package_mel.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41CC0000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:10 Write , Start : 0x41CC0000 , Len : 0x00394B10 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xCA7D ===Flashing [CNT]=== File : 6A12511D_rm924__06.09.image_mel_059R786 Image : package_mel_059R786.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:01:29 Write , Start : 0x42300000 , Len : 0x00C60000 Flashing , wait ... Region flash done, time : 00:00:16 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x35BE Flashing done! Total flash time : 00:03:44 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 210 Software Info: V 06.09 14-10-13 RM-924 (c) Nokia IMEI: 359955054035300 PPM version : V 06.09 14-10-13 RM-924 (c) Nokia MEL Product code: 059R9P6 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:05:19 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
Nokia XL flashing done Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 3416DCFB HWDetails : 0x000B , 0x0FC5 , 0x0081 , 0x0770 HWDetails : eMMC : VEN 15 , OEM : 0X100 , NAME : J5XWMB HWDetails : HW Revision V1 Processing : RM1030_1.2.3.1_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_1.2.3.1_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_1.2.3.1_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_1.2.3.1_059V6Q7_IMEA_PK_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:05:59 Reboot phone Ok Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok |
NOKIA 501 RM-902 WRITE FIRMWARE DONE Card found: S/N : A6936825 , v0137 Registered to: yuslamuique Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : FullFlash File [Ok] : rm902_14.0.5.mcusw.fpsx File [Ok] : rm902_14.0.5_059R2T4_m3.rofs.fpsx File [Ok] : rm902_14.0.5_059R2T4_m3.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- Phone not found :( - > Tip : Insert cable, without battery, Press Flash , Insert Battery Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : FullFlash File [Ok] : rm902_14.0.5.mcusw.fpsx File [Ok] : rm902_14.0.5_059R2T4_m3.rofs.fpsx File [Ok] : rm902_14.0.5_059R2T4_m3.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049B2210992C1C94A612ECA00 ASIC ID_E : 00000C2016100040 PUBLIC ID : 0A5B00C8E661B63049B2210992C1C94A612ECA00 XGCHIP ID : 0A5B00C8E661B630 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 357898053309288 IMEI [2] : 357898053309296 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357898053309288_XG 223_CRT.rpl PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E === SW Version Check === - > UPGRADE === SW Version Check === === Flashing MCU === Processing file : rm902_14.0.5.mcusw.fpsx Erasing... Writing... Total blocks : 82 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 81 blocks were writen === Flashing PPM === Processing file : rm902_14.0.5_059R2T4_m3.rofs.fpsx Erasing... Writing... Total blocks : 17 Writing RKH CRT [PPM] File processed Ok, 17 blocks were writen === Flashing CNT === Processing file : rm902_14.0.5_059R2T4_m3.image.fpsx Erasing... Writing... Total blocks : 55 File processed Ok, 55 blocks were writen Flashing done , total time : 00:01:02 Reboot phone to service mode... Reading Phone Info.... Connected phone - 501 Software Info: V 14.0.5 21-04-14 RM-902 (c) Nokia IMEI: 357898053309288 PPM version : cad038bf077da4b83f954a3fc663518eb42393cf Product code: 059T1N5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
Nokia 101 RM-769 Flash Done Code: UFS S/N 72XXX boot - Ok |
Nokia 2690 flashing done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm635__10.65.mcusw PPM : rm635__10.65.ppm_ms CNT : rm635__10.65.image_ms_black Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> Check SW version... FlashFile version : 10.65 Phone version : 10.10 22-04-10 RM-635 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354341042983874_SI M.rpl -> MMC pass Record found, saving... Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 198000161A790256585BF201CFF5FE488E943201 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: C6B9354E81AC464DED33FC7B90295086150F4539 Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm635__10.65.image_ms_black ConvertImage: Page Size is 128K, no need convert Loader len: 300160, CHK: 40AC ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm635__10.65.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:23 Write : Processing rm635__10.65.mcusw Total 1165 [1165/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:54 MCU Write done ===Flashing [PPM]=== Erase : Processing rm635__10.65.ppm_ms Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:01 Write : Processing rm635__10.65.ppm_ms Total 172 [172/0/0] blocks to write, writing... TIME : Write time : 00:00:09 PPM Write done ===Flashing [CNT]=== Erase : Processing rm635__10.65.image_ms_black Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:06:19 Write : Processing rm635__10.65.image_ms_black Total 496 [496/0/0] blocks to write, writing... TIME : Write time : 00:00:25 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:12 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2690 Software Info: V 10.65 09-12-10 RM-635 (c) Nokia IMEI: 354341042983874 PPM version : V 10.65 09-12-10 RM-635 (c) Nokia MS Product code: 0592533 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 0 certs Uploading User Certificates... Uploaded 26 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:12:16 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
Nokia 225 Dual SIM Flash Done Quote:
Nokia X2-00 Flash Done Quote:
Microsoft Lumia 430 Dual Sim (RM-1099) Flash Done Quote:
Nokia 130 RM-1035 Dual SIM Flash Done Quote:
Lumia 540 (RM-1141) Flash Done Quote:
Nokia 105 Format Done --- Insert USB cable now! --- Wait for phone... Phone found! [ 266 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : BF56EDD39BC5F075A6F53AED181291CA BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Lagos.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 Executing FFS FORMAT now... FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:21 Connect phone on selected interface... |
