Nokia 106 ta 1114 hang on logo done by best Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM10) MODE : NOKIA USB SERIAL PORT : 10 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 909727D06427CA108B48AB9E7F01477E BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : NEMO61D.10.00.11.p2 FLASH : 00C2 : 0025 : 0036 : 0000 PRDC : 059Z0X8 IMEI[1] : 35768010 IMEI[2] : 35768010 NCK : 20 digits PROV : 24407000 Saved as : 35768010.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:59 Reconnect Power/Cable! Open VPLfile : TA-1114_059Z0X8_10.00.11.vpl Description : TA-1114 IM DeviceType : TA-1114 ProductCode : 059Z0X8 SoftwareVer : 10.00.11 PPM LangPack : [1] : Hindi (India) [2] : Urdu (Islamic Republic of Pakistan) [3] : Arabic (Saudi Arabia) [4] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM10) MODE : NOKIA USB SERIAL PORT : 10 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 909727D06427CA108B48AB9E7F01477E BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 10.00.11 [TA-1114] DEV SoftwareVersion : 10.00.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1114_ROM_eMP_10.00.11 LANG : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001 CUST : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001 JUMP : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001 VIVA : TA-1114_VIVA_eMP_10.00.11 Prepare FlashSet : DCR : TA-1114_ROM_eMP_10.00.11 DCR : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001 DCR : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001 DCR : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001 DCR : TA-1114_VIVA_eMP_10.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1114_ROM_eMP_10.00.11 Write : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001 Write : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001 Write : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001 Write : TA-1114_VIVA_eMP_10.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1114_ROM_eMP_10.00.11 Verify : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001 Verify : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001 Verify : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001 Verify : TA-1114_VIVA_eMP_10.00.11 Done! Elapsed: 00:01:11 Reconnect Power/Cable! |
Nokia 106 format done Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM29) MODE : NOKIA USB SERIAL PORT : 29 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 54C65CC61B7CAB3E791712149B156AAF BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
Nokia 150 dual sim RM-1190 Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM29) MODE : NOKIA USB SERIAL PORT : 29 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : FD564B8B66684389285A4D3DF9BD00BB BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.11.00.11.p1 BOOT : SWR : 11.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.11.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.00.11 [RM-1190] DEV SoftwareVersion : 11.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1190_DUBAI_ROM_eMP_11.00.11 LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 JUMP : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 VIVA : RM-1190_DUBAI_VIVA_eMP_11.00.11 Prepare FlashSet : DCR : RM-1190_DUBAI_ROM_eMP_11.00.11 DCR : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 DCR : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 DCR : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 DCR : RM-1190_DUBAI_VIVA_eMP_11.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1190_DUBAI_ROM_eMP_11.00.11 Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 Write : RM-1190_DUBAI_VIVA_eMP_11.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1190_DUBAI_ROM_eMP_11.00.11 Verify : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 Verify : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 Verify : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 Verify : RM-1190_DUBAI_VIVA_eMP_11.00.11 Done! Elapsed: 00:01:18 Reconnect Power/Cable! |
Open VPLfile : TA-1034_059Z107_30.04.11.vpl Description : TA-1034 IJ DeviceType : TA-1034 ProductCode : 059Z107 SoftwareVer : 30.04.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : False Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM29) MODE : NOKIA USB SERIAL PORT : 29 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 835345BFA7484B7CB1286B4D8F8BE5DC BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.04.11 [TA-1034] DEV SoftwareVersion : 30.04.11 SWInfo compare result : SAME Load FlashSet : LANG : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 CUST : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 JUMP : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Prepare FlashSet : DCR : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 Write : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 Write : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 Verify : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 Verify : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
Nokia 150 flashing done Open VPLfile : RM-1190_059X8X2_30.00.11.vpl Description : RM-1190 059X8X2 IJ 30.00.11 DeviceType : RM-1190 ProductCode : 059X8X2 SoftwareVer : 30.00.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM14) MODE : NOKIA USB SERIAL PORT : 14 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 1436BCDDD77B8EE27A2E6F8C4FEF6960 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.30.00.11.p1 BOOT : SWR : 30.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.30.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.00.11 [RM-1190] DEV SoftwareVersion : 30.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1190_DUBAI_ROM_eMP_30.00.11 LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 JUMP : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 VIVA : RM-1190_DUBAI_VIVA_eMP_30.00.11 Prepare FlashSet : DCR : RM-1190_DUBAI_ROM_eMP_30.00.11 DCR : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 DCR : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 DCR : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 DCR : RM-1190_DUBAI_VIVA_eMP_30.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1190_DUBAI_ROM_eMP_30.00.11 Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_VIVA_eMP_30.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1190_DUBAI_ROM_eMP_30.00.11 Verify : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 Verify : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 Verify : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 Verify : RM-1190_DUBAI_VIVA_eMP_30.00.11 Done! Elapsed: 00:01:05 Reconnect Power/Cable! |
Nokia 106 (2019) write Firmware Done :) Code: Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 |
Nokia E71 Unlock Done Code: Phone Imei: 35194xxxxxxxxxxx |
Nokia 210 Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm924__06.09.mcusw PPM : rm924__06.09.ppm_ma3 CNT : rm924__06.09.image_ma3_059R775 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359190059993465 IMEI 2 : 359190059993473 PCcode : 059R775 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359190059993465_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm924__06.09.mcusw Image : rm924__06.09.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01A40000 Erasing, wait ... Erase done, time : 00:00:54 Write , Start : 0x40280000 , Len : 0x01A40000 Flashing , wait ... Region flash done, time : 00:00:38 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip [Minor Error] : CRC returned by phone is wrong! [CHK] : 0100E361 ===Flashing [PPM]=== File : rm924__06.09.ppm_ma3 Image : package_ma3.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41CC0000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41CC0000 , Len : 0x003EFB64 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x44C0 ===Flashing [CNT]=== File : rm924__06.09.image_ma3_059R775 Image : package_ma3_059R775.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:01:18 Write , Start : 0x42300000 , Len : 0x00C60000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x98EC Flashing done! Total flash time : 00:03:29 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 210 Software Info: V 06.09 14-10-13 RM-924 (c) Nokia IMEI: 359190059993465 PPM version : V 06.09 14-10-13 RM-924 (c) Nokia MA3 Product code: 059R775 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:30 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
Nokia 225 4G (TA-1279) SecurIty Code Read / Reset with InfinityBox BEST2 Nokia 225 4G (TA-1279) SecurIty Code Read / Reset with InfinityBox BEST2 |
NOKIA 225 RM-1012 Read User Code Done Card found: S/N : 5C203D37 , v0151 Registered to: Yuran Williams Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : DB1142A20A2A5CB12008962CFC37FD5B BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! |
Nokia 106 full flash done Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM29) MODE : NOKIA USB SERIAL PORT : 29 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : A0210B1C60DB07939EC24D0A49CB2B2F BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 10.00.11 [TA-1114] DEV SoftwareVersion : 10.00.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1114_ROM_eMP_10.00.11 LANG : TA-1114_LANG_PACK_ROM_IB_eMP_10.00.11_001 CUST : TA-1114_CUSTPACK_ROM_IB_eMP_10.00.11_001 JUMP : TA-1114_JUMP_TABLE_IB_eMP_10.00.11_001 VIVA : TA-1114_VIVA_eMP_10.00.11 Prepare FlashSet : DCR : TA-1114_ROM_eMP_10.00.11 DCR : TA-1114_LANG_PACK_ROM_IB_eMP_10.00.11_001 DCR : TA-1114_CUSTPACK_ROM_IB_eMP_10.00.11_001 DCR : TA-1114_JUMP_TABLE_IB_eMP_10.00.11_001 DCR : TA-1114_VIVA_eMP_10.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1114_ROM_eMP_10.00.11 Write : TA-1114_LANG_PACK_ROM_IB_eMP_10.00.11_001 Write : TA-1114_CUSTPACK_ROM_IB_eMP_10.00.11_001 Write : TA-1114_JUMP_TABLE_IB_eMP_10.00.11_001 Write : TA-1114_VIVA_eMP_10.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1114_ROM_eMP_10.00.11 Verify : TA-1114_LANG_PACK_ROM_IB_eMP_10.00.11_001 Verify : TA-1114_CUSTPACK_ROM_IB_eMP_10.00.11_001 Verify : TA-1114_JUMP_TABLE_IB_eMP_10.00.11_001 Verify : TA-1114_VIVA_eMP_10.00.11 Done! Elapsed: 00:01:06 Reconnect Power/Cable! |
Nokia 106 fullflash done Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM29) MODE : NOKIA USB SERIAL PORT : 29 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 1C670F2AD0C861577831E0302A59FC9B BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 10.00.11 [TA-1114] DEV SoftwareVersion : 10.00.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1114_ROM_eMP_10.00.11 LANG : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001 CUST : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001 JUMP : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001 VIVA : TA-1114_VIVA_eMP_10.00.11 Prepare FlashSet : DCR : TA-1114_ROM_eMP_10.00.11 DCR : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001 DCR : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001 DCR : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001 DCR : TA-1114_VIVA_eMP_10.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1114_ROM_eMP_10.00.11 Write : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001 Write : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001 Write : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001 Write : TA-1114_VIVA_eMP_10.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1114_ROM_eMP_10.00.11 Verify : TA-1114_LANG_PACK_ROM_IJ_eMP_10.00.11_001 Verify : TA-1114_CUSTPACK_ROM_IJ_eMP_10.00.11_001 Verify : TA-1114_JUMP_TABLE_IJ_eMP_10.00.11_001 Verify : TA-1114_VIVA_eMP_10.00.11 Done! Elapsed: 00:01:03 Reconnect Power/Cable! |
Nokia 106 Ta 1114 Full Flash Done By Best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM13) MODE : NOKIA USB SERIAL PORT : 13 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 50938688A137C5DC3017DC67CFD53E31 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : NEMO61D.10.00.11.p2 FLASH : 00C2 : 0025 : 0036 : 0000 PRDC : 059Z0X8 IMEI[1] : 352882102985442 IMEI[2] : 352882103985441 NCK : 20 digits PROV : 24407000 Saved as : 352882102985442.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:01:13 Reconnect Power/Cable! Open VPLfile : TA-1114_059Z0X8_10.00.11.vpl Description : TA-1114 IM DeviceType : TA-1114 ProductCode : 059Z0X8 SoftwareVer : 10.00.11 PPM LangPack : [1] : Hindi (India) [2] : Urdu (Islamic Republic of Pakistan) [3] : Arabic (Saudi Arabia) [4] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM13) MODE : NOKIA USB SERIAL PORT : 13 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 50938688A137C5DC3017DC67CFD53E31 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 10.00.11 [TA-1114] DEV SoftwareVersion : 10.00.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1114_ROM_eMP_10.00.11 LANG : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001 CUST : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001 JUMP : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001 VIVA : TA-1114_VIVA_eMP_10.00.11 Prepare FlashSet : DCR : TA-1114_ROM_eMP_10.00.11 DCR : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001 DCR : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001 DCR : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001 DCR : TA-1114_VIVA_eMP_10.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1114_ROM_eMP_10.00.11 Write : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001 Write : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001 Write : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001 Write : TA-1114_VIVA_eMP_10.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1114_ROM_eMP_10.00.11 Verify : TA-1114_LANG_PACK_ROM_IM_eMP_10.00.11_001 Verify : TA-1114_CUSTPACK_ROM_IM_eMP_10.00.11_001 Verify : TA-1114_JUMP_TABLE_IM_eMP_10.00.11_001 Verify : TA-1114_VIVA_eMP_10.00.11 Done! Elapsed: 00:01:11 Reconnect Power/Cable! |
Nokia 6303i classic rm 638 user lock reading done connect powered off phone to usb Code: Connect phone on selected interface... |
Nokia C2-03 RM-702 Password Reset / Reset Settings infinity Best Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm702__06.96.image_cis_059H282 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Keys check skipped by user request Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 35414xxxxxxxxxxx IMEI 2 : 35414xxxxxxxxxxx PCcode : 059J9Q2 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\3541410xxxxxxxxxxx xxx_2nd_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [CNT]=== File : rm702__06.96.image_cis_059H282 Image : package_cis_059H282.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:00:51 Write , Start : 0x424C0000 , Len : 0x00C20000 Flashing , wait ... Region flash done, time : 00:00:14 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xEE53 Flashing done! Total flash time : 00:01:08 Reboot phone now... Reading Phone Info.... Connected phone - C2-03 Software Info: V 07.65 19-09-12 RM-702 (c) Nokia IMEI: 354141xxxxxxxxxxx PPM version : V 07.65 19-09-12 RM-702 (c) Nokia M_A Product code: 059D434 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:02:13 Connect phone on selected interface... |
