Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 11-16-2017, 10:05   #1 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,810
Very important how to avoid contact service in new nokia phone
hi
in old nokia phone u get contact service when u downgrade phone version as security file damaged
rpl etc
but in recent time u get contact service after flashing lower or higher version
but not the version is the problem but manfucturer
after nokia fall in buisness microsft bought it
and issued new nokia such as nokia 105
on phone cover nokia name and nokia logo on sofware
but on sticker microsoft
after 2016 nokia bought buy HMD global
u will read HMD global on phone sticker under battery
so if flash Nokia by Microsoft with hmd global version u will get contact service
and vice virsa
ok first before u flash phone do this
open Best
go mtk section
service tab
tick rpl only and press flash then connect phone
now from log u can check version
just flash phone with same version in log
but if u got phone with contcat service issue
do same method
read flash with rpl only ticked
if in log
Control Block Validation (Security Test) :
CBR is Ok, match with BB SN. Phone Security is Alive
Mobile Info
just flash phone with same version in log or with lower if phone by microsoft
or higher if by HMD global
but if u get this in log after reading rpl
CBR Info is wrong! CBR SN not match with BB SN!
Say thanks to some "great chinese tools" for kill your phone
If backup not done - phone just a brick
then no solution
this happen after flashing some chinese boxes that support nokia but destroy them
if post helpful press thank button
The Following 90 Users Say Thank You to profkefah For This Useful Post:
Old 11-17-2017, 20:59   #2 (permalink)
Member: 1423054
Thanks Meter: 7
Thx for giving information
Sent from my iPhone using Tapatalk
The Following User Says Thank You to abbasans For This Useful Post:
Old 11-18-2017, 18:28   #3 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,810
]you are welcome pal
The Following User Says Thank You to profkefah For This Useful Post:
Old 11-21-2017, 12:34   #4 (permalink)
Member: 1423054
Thanks Meter: 7
bro i am getting error after flash wrong file
for nokia 225 can u help me
tiger bhai how to solve this error any idea
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
- > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 11 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : 7C04F71A12419CB09A9C1B44CFA4CAFE
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL failed! (Bad ACK) BL INIT : DEAD
BootLoader Init Failed (HW/Connection Error)
Connect phone on selected interface...
Boot Error
Flashing failed!
nokia 225 getting error
Old 11-21-2017, 14:42   #5 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,810
see this
http://forum.gsmhosting.com/vbb/f641...flash-1753261/
Old 11-21-2017, 14:43   #6 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,810
also this check
its useful
Originally Posted by JayDi View Post
BAD ACK error mean some problems with connection. Close ALL sw, which can use , slow down ports and etc.
Old 11-23-2017, 09:01   #7 (permalink)
Member: 2558214
Thank you for the information ..well done
The Following User Says Thank You to moh9122 For This Useful Post:
Old 11-23-2017, 09:06   #8 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,810
you are welcome bro
thank u
Old 01-11-2018, 09:15   #9 (permalink)
Member: 2333062
Sonork: 100.1671476
Thanks Meter: 4
thanks for this helpful wellcome
The Following User Says Thank You to alimola For This Useful Post:
Old 02-06-2018, 15:35   #10 (permalink)
Member: 1629444
Thanks Meter: 47
thanks.
but Project ID in log just show us which file on the phone, not which file can solve the contact service.
before flash:
Project ID : SUEZ.30.01.11.p1
after flash:
Project ID : SUEZ.12.00.11.p1
Old 02-07-2018, 07:55   #11 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,810
as i wrote
by log u will know before flashing which version in phone
]so u flash same one
Old 03-15-2018, 12:06   #12 (permalink)
Member: 2475109
Thanks Meter: 140
Nice share .............
The Following User Says Thank You to babarmaqbool For This Useful Post:
Old 04-04-2018, 12:28   #13 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,810
http://www.youtube.com/watch?v=XXZMhj3Zm9k&feature=*********
The Following 2 Users Say Thank You to profkefah For This Useful Post:
Old 05-23-2018, 19:31   #14 (permalink)
Member: 2550445
Thanks Meter: 26
nokia 230 rm-1173 after flash contact service plxxxxx help....
Old 05-23-2018, 19:41   #15 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,810
your set is hmd global or microsoft
also read rpl and post log
Page generated in 0.20737 seconds with 8 queries
