Dragon Box Chinese Phone Tool |
09-11-2012, 20:00 | #2011 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Action=ReadFlash FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\ZTE TEST Comport=COM44 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=7 D+=10 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM150 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Documents and Settings\GPGMobileLab\Desktop\ZTE TEST All Done. Reading Project Version... Platform Version: L6202A_MUL_AD_R1.16_101116 Project Version: SC6600L_sp6601l MMI Version: L6202_MUL_HJ_R1.04_100108 BASE Version: BASE_W09.20_P9 HW Version: SC6600L_sp6601l Project Bulid Time: 11-16-2010 14:7:51 +++++++++++++++++++End at: 3/6/2012 12:38:28 PM+++++++++++++++++++ -------------------Created: 3/6/2012 12:38:48 PM------------------- |
09-11-2012, 20:01 | #2012 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=SpreadTrum Action=ReadFlash FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\ZTE TEST Comport=COM44 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=7 D+=10 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM150 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Documents and Settings\GPGMobileLab\Desktop\ZTE TEST All Done. Reading Project Version... Platform Version: L6202A_MUL_AD_R1.16_101116 Project Version: SC6600L_sp6601l MMI Version: L6202_MUL_HJ_R1.04_100108 BASE Version: BASE_W09.20_P9 HW Version: SC6600L_sp6601l Project Bulid Time: 11-16-2010 14:7:51 +++++++++++++++++++End at: 3/6/2012 12:38:28 PM+++++++++++++++++++ -------------------Created: 3/6/2012 12:38:48 PM------------------- |
09-11-2012, 20:01 | #2013 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=SpreadTrum Action=Reset FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\ZTE TEST Comport=COM44 Baudrate=921600 CPU_Type=SC6600L2 CPU_ID=66007001 NOR_ID=0020881000208810 NOR_Size=8MB NOR_Name=NOR_ST_M58WR064KT NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=7 D+=10 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM150 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. +++++++++++++++++++End at: 3/6/2012 12:40:18 PM+++++++++++++++++++ -------------------Created: 3/6/2012 12:56:03 PM------------------- |
09-11-2012, 20:02 | #2014 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM44 Baudrate=921600 CPU_Type=MT6225 CPU_ID=7203000F NOR_ID=0001227E22212201 NOR_Size=16MB NOR_Name=[SPANSION] S29GL128N_T NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=12 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A03, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0001227E22212201 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: ZHA85I_VI9_NG8_SD_V2.3ATEST +++++++++++++++++++End at: 3/6/2012 12:58:09 PM+++++++++++++++++++ -------------------Created: 3/6/2012 12:58:15 PM------------------- |
09-11-2012, 20:03 | #2015 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM44 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=4 D+=5 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM150 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000045A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=359038529024070 (CRC Error) IMEI 2=910575601400468 ------Auto Format Address------- Start=0x003B0000 Size =0x00050000 Read FS info...done +++++++++++++++++++End at: 3/6/2012 1:00:45 PM+++++++++++++++++++ -------------------Created: 3/6/2012 1:01:11 PM------------------- |
09-11-2012, 20:03 | #2016 (permalink) |
09-11-2012, 20:04 | #2017 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=SpreadTrum Action=ReadFlash FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\NITHIN IMEI Comport=COM44 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=4 D+=5 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM150 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000045A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Documents and Settings\GPGMobileLab\Desktop\NITHIN IMEI All Done. Reading Project Version... Platform Version: MOCOR_09A_MP.W11.16_P4_Release Project Version: SC6600L_6620 MMI Version: SC6600L_6620 BASE Version: BASE_10A.W11.24.08 HW Version: SC6620 Project Bulid Time: 9-17-2011 11:27:32 +++++++++++++++++++End at: 3/6/2012 1:02:03 PM+++++++++++++++++++ -------------------Created: 3/6/2012 1:02:13 PM------------------- |
09-11-2012, 20:05 | #2018 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\NITHIN IMEI Comport=COM44 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=4 D+=5 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM150 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000045A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=359038529024070 (CRC Error) IMEI 2=910575601400468 ------Auto Format Address------- Start=0x003B0000 Size =0x00050000 Read FS info...done +++++++++++++++++++End at: 3/6/2012 1:02:47 PM+++++++++++++++++++ -------------------Created: 3/6/2012 1:02:51 PM------------------- |
09-11-2012, 20:05 | #2019 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=SpreadTrum Action=IMEI FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\NITHIN IMEI Comport=COM44 Baudrate=921600 Initializing... DA_LIB_VER_4.0.3.2 Auto analyzing... IMEI has been detected in rom-image. Group=1 Rebulid IMEI: [359038529024070] to [351094894726288] Rebulid IMEI: [910575601400468] to [358295007268471] Create out file: C:\Documents and Settings\GPGMobileLab\Desktop\Rebulid_IMEI_NITHIN IMEI All Done. +++++++++++++++++++End at: 3/6/2012 1:04:05 PM+++++++++++++++++++ -------------------Created: 3/6/2012 1:04:23 PM------------------- |
09-11-2012, 20:06 | #2020 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x00400000 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\Rebulid_IMEI_NITHIN IMEI Comport=COM44 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=4 D+=5 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM150 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000045A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. +++++++++++++++++++End at: 3/6/2012 1:04:48 PM+++++++++++++++++++ -------------------Created: 3/6/2012 1:05:52 PM------------------- |
09-11-2012, 20:06 | #2021 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=SpreadTrum Action=IMEI FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x00400000 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\Rebulid_IMEI_NITHIN IMEI Comport=COM44 Baudrate=921600 Initializing... DA_LIB_VER_4.0.3.2 Auto analyzing... IMEI has been detected in rom-image. Group=1 Rebulid IMEI: [359038529124072] to [359502009113186] Create out file: C:\Documents and Settings\GPGMobileLab\Desktop\Rebulid_IMEI_Rebulid _IMEI_NITHIN IMEI All Done. +++++++++++++++++++End at: 3/6/2012 1:08:17 PM+++++++++++++++++++ -------------------Created: 3/6/2012 1:09:15 PM------------------- |
09-11-2012, 20:07 | #2022 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=ReadInfo FlashType=Nand boot=Ver3.920 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM44 Baudrate=921600 CPU_Type=MT6236 CPU_ID=00000000 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=009800B100000055 NAND_Size=128MB NAND_Name=[TOSHIBA] TC58NYG1S8C Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6236, HardwareVer:8A02, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Loading boot... Boot3 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 009800B100000055 Read Hardware Information is done. Get Project ID from phone... Project ID: PN-SC_CN_LLNUMLD_202_YYMMDD +++++++++++++++++++End at: 3/6/2012 2:32:20 PM+++++++++++++++++++ -------------------Created: 3/6/2012 2:32:41 PM------------------- |
09-11-2012, 20:08 | #2023 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver3.920 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM44 Baudrate=921600 CPU_Type=MT6236 CPU_ID=00000000 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=009800B100000055 NAND_Size=128MB NAND_Name=[TOSHIBA] TC58NYG1S8C Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6236, HardwareVer:8A02, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Loading boot... Boot3 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 009800B100000055 Read Hardware Information is done. Config EMI(Nor Flash only)... Failed to check H/W. Get Project ID from phone... Project ID: PN-SC_CN_LLNUMLD_202_YYMMDD +++++++++++++++++++End at: 3/6/2012 2:33:14 PM+++++++++++++++++++ -------------------Created: 3/6/2012 2:33:25 PM------------------- |
09-11-2012, 20:08 | #2024 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=ReadFlash FlashType=Nand boot=Ver3.920 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\spice m6800 Comport=COM44 Baudrate=921600 CPU_Type=MT6236 CPU_ID=00000000 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=009800B100000055 NAND_Size=128MB NAND_Name=[TOSHIBA] TC58NYG1S8C Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6236, HardwareVer:8A02, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Loading boot... Boot3 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 009800B100000055 Read Hardware Information is done. Get Project ID from phone... Project ID: PN-SC_CN_LLNUMLD_202_YYMMDD Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\Documents and Settings\GPGMobileLab\Desktop\spice m6800 All Done. +++++++++++++++++++End at: 3/6/2012 3:10:47 PM+++++++++++++++++++ -------------------Created: 3/6/2012 3:46:43 PM------------------- |
09-11-2012, 20:09 | #2025 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=Format FlashType=Nand boot=Ver3.920 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\spice m6800 Comport=COM44 Baudrate=921600 CPU_Type=MT6236 CPU_ID=00000000 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=009800B100000055 NAND_Size=128MB NAND_Name=[TOSHIBA] TC58NYG1S8C Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6236, HardwareVer:8A02, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Loading boot... Boot3 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 009800B100000055 Read Hardware Information is done. Get Project ID from phone... Project ID: PN-SC_CN_LLNUMLD_202_YYMMDD Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x04000000, size=0x04000000 All Done +++++++++++++++++++End at: 3/6/2012 3:49:59 PM+++++++++++++++++++ -------------------Created: 3/6/2012 3:55:54 PM------------------- |
