Dragon Box Chinese Phone Tool |
![]() | #2026 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2012
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Action=ReadInfo FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM44 Baudrate=921600 CPU_Type=MT6236 CPU_ID=00000000 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=009800B100000055 NAND_Size=128MB NAND_Name=[ST] ST512R3A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6236, HardwareVer:8A02, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Loading boot... Boot3 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 009800B100000055 Read Hardware Information is done. Config EMI(Nor Flash only)... Failed to check H/W. Get Project ID from phone... Project ID: PN-SC_CN_LLNUMLD_202_YYMMDD +++++++++++++++++++End at: 3/6/2012 4:03:14 PM+++++++++++++++++++ -------------------Created: 3/6/2012 4:03:19 PM------------------- |
![]() | #2027 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=ReadInfo FlashType=Nand boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM44 Baudrate=921600 CPU_Type=MT6236 CPU_ID=00000000 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=009800B100000055 NAND_Size=128MB NAND_Name=[ST] ST512R3A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6236, HardwareVer:8A02, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Loading boot... Boot3 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 009800B100000055 Read Hardware Information is done. Get Project ID from phone... Project ID: PN-SC_CN_LLNUMLD_202_YYMMDD +++++++++++++++++++End at: 3/6/2012 4:03:54 PM+++++++++++++++++++ -------------------Created: 3/6/2012 4:05:14 PM------------------- |
![]() | #2028 (permalink) |
![]() | #2029 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=Format FlashType=Nand boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\spice m6800 WORK Comport=COM44 Baudrate=921600 CPU_Type=MT6236 CPU_ID=00000000 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=009800B100000055 NAND_Size=128MB NAND_Name=[ST] ST512R3A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6236, HardwareVer:8A02, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Loading boot... Boot3 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 009800B100000055 Read Hardware Information is done. Get Project ID from phone... Project ID: PN-SC_CN_LLNUMLD_202_YYMMDD Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x04000000, size=0x04000000 All Done +++++++++++++++++++End at: 3/6/2012 4:12:09 PM+++++++++++++++++++ -------------------Created: 3/6/2012 4:18:53 PM------------------- |
![]() | #2030 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM40 Baudrate=921600 CPU_Type=MT6225 CPU_ID=8F030002 NOR_ID=0098000300000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FVM7TDD NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A03, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: JLA6_AR8_NS5_V1.9CTEST +++++++++++++++++++End at: 3/7/2012 12:19:24 PM+++++++++++++++++++ -------------------Created: 3/7/2012 12:20:17 PM------------------- |
![]() | #2031 (permalink) |
![]() | #2032 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=ReadFlash FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\TEST Comport=COM40 Baudrate=921600 CPU_Type=MT6225 CPU_ID=8F030002 NOR_ID=0098000300000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FVM7TDD NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A03, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: JLA6_AR8_NS5_V1.9CTEST Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\Documents and Settings\GPGMobileLab\Desktop\TEST All Done. +++++++++++++++++++End at: 3/7/2012 12:23:54 PM+++++++++++++++++++ -------------------Created: 3/7/2012 12:25:27 PM------------------- |
![]() | #2033 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=Format FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=C:\Documents and Settings\GPGMobileLab\Desktop\TEST Comport=COM40 Baudrate=921600 CPU_Type=MT6225 CPU_ID=8F030002 NOR_ID=0098000300000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FVM7TDD NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A03, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: JLA6_AR8_NS5_V1.9CTEST Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done +++++++++++++++++++End at: 3/7/2012 12:25:55 PM+++++++++++++++++++ -------------------Created: 3/7/2012 1:17:17 PM------------------- |
![]() | #2034 (permalink) |
![]() | #2035 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver3.920 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM44 Baudrate=921600 CPU_Type=MT6225 CPU_ID=0C030002 NOR_ID=0098004900000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TV00578002DABD NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A03, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098004900000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: MAUI.GEMINI.W08.12.F2 +++++++++++++++++++End at: 3/7/2012 1:17:30 PM+++++++++++++++++++ -------------------Created: 3/7/2012 1:17:41 PM------------------- |
![]() | #2036 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM44 Baudrate=921600 CPU_Type=MT6253 CPU_ID=0000000F NOR_ID=0098009E00000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FYM7T8C NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=23 TXD=13 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098009E00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: L5AMM23.9.52.1.0T04M0126_M012 +++++++++++++++++++End at: 3/7/2012 1:23:29 PM+++++++++++++++++++ -------------------Created: 3/7/2012 1:23:49 PM------------------- |
![]() | #2037 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=Format FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM44 Baudrate=921600 CPU_Type=MT6253 CPU_ID=0000000F NOR_ID=0098009E00000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FYM7T8C NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=23 TXD=13 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098009E00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: L5AMM23.9.52.1.0T04M0126_M012 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done +++++++++++++++++++End at: 3/7/2012 1:24:31 PM+++++++++++++++++++ -------------------Created: 3/7/2012 1:24:38 PM------------------- |
![]() | #2038 (permalink) |
![]() | #2039 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver3.1108 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM40 Baudrate=921600 CPU_Type=MT6223 CPU_ID=50F3000C NOR_ID=0098000300000000 NOR_Size=16MB NOR_Name=[TOSHIBA] TC58FVM7TDD NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: K444_18N3V01.01B03 +++++++++++++++++++End at: 3/7/2012 3:42:45 PM+++++++++++++++++++ -------------------Created: 3/7/2012 3:43:01 PM------------------- |
![]() | #2040 (permalink) |
Member: 1778065 Status: Offline Sonork: 1618144 Thanks Meter: 5 | Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6600L/WT6226-COM Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile= Comport=COM40 Baudrate=115200 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00F8003200160000 NOR_Size=4MB NOR_Name=SF_FM25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=7 TXD=9 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000506A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_FM25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=910567800862192 IMEI 2=910575601400468 ------Auto Format Address------- Start=0x003C0000 Size =0x00040000 Read FS info...done +++++++++++++++++++End at: 3/8/2012 10:57:09 AM+++++++++++++++++++ -------------------Created: 3/8/2012 11:46:46 AM------------------- |
