09-03-2016, 19:07 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: istanbul - turkey
Member: 1739390 Status: Offline Sonork: 100.1623876 Thanks Meter: 5 | I9505 dead EMMC programming I had this driver : Qualcomm hs-usb QDloader 9008 but the odin cant see it and I cant flash it by odin I linked EMMC to Medusa Pro and made repair by tar I used this flash file :I9505_XXUHOJ2_XEGHOJ1 with 4files and used this pit : JFLTE_EUR_OPEN.pit the flash operation 100% finish after 15 minutes but the phone is the same problem the is no bood , no download mode with power supply it takes 30 mA could anyone help me please thanks in advance ---------- when I make connecting to the box : this is logs Welcome to Medusa Pro Software version 1.1.8. Started. Reader #0: Alcor Micro USB Smart Card Reader 1 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. eMMC interface selected. Connecting... Device : Toshiba eMMC 016G94 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB -------------------------------------------------------- CID Info CID : 110100303136473934B0940B54BF2193 Manufacturer ID : 0X11 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : 016G94 Product revision : 11.0 Product serial number : (hex)940B54BF Manufacturing date : 02/2014 -------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFFF92400025 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO -------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Boot partition enable : Device not boot enabled (default) Partition config : 00000000 Backup EXT_CSD saved to file E:/program files/Medusa Pro Software/EXT_CSD Backups/016G94_03_09_2016_21_04_56.bin. Connect successful. -------------------------------------------------------- I tried Erase the chip , then flashing again but the same problem I tried j-tag with other box but I couldnt repair it by j-tag |
09-05-2016, 20:39 | #4 (permalink) |
Member: 1739390 Status: Offline Sonork: 100.1623876 Thanks Meter: 5 | Yes i tried but the same thing İ removed the emmc from pcb and the same problem too İ tried another working emmc but the same problem Any advice ??!!! Thank you |
09-06-2016, 13:28 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Unfortunately, partitions which contains firmware isn't enough to repair your device, please post here full Software log of repair operation with old Medusa Software. |
