03-02-2017, 15:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Lg H810 Still dead after boot repair [Solved] Erase flash logs Code: Welcome to Medusa Pro Software version 1.3.2. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Reader #3: Generic EMV Smartcard Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : H811 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_H811_EMMC.SRF Voltage : 2.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 032G74 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 1101003033324737340052553F4E4209 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex) 52553F4E Manufacturing date : 04/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Boot partition enable : Device not boot enabled (default) Partition config : 00000000 Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/032G74_01_03_2017_22_47_31.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. Please select file. Erasing partition GPT... Done. Erasing partition modem... Done. Erasing partition pmic... Done. Erasing partition sbl1... Done. Erasing partition tz... Done. Erasing partition sdi... Done. Erasing partition hyp... Done. Erasing partition aboot... Done. Erasing partition sbl1bak... Done. Erasing partition pmicbak... Done. Erasing partition tzbak... Done. Erasing partition hypbak... Done. Erasing partition rpmbak... Done. Erasing partition abootbak... Done. Erasing partition sdibak... Done. Erasing partition limits... Done. Erasing partition devinfo... Done. Erasing partition apdp... Done. Erasing partition msadp... Done. Erasing partition dpo... Done. Erasing partition spare1... Done. Erasing partition misc... Done. Erasing partition persist... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Erasing partition fsg... Done. Erasing partition fsc... Done. Erasing partition ssd... Done. Erasing partition keystore... Done. Erasing partition DDR... Done. Erasing partition sec... Done. Erasing partition encrypt... Done. Erasing partition eksst... Done. Erasing partition rct... Done. Erasing partition persistent... Done. Erasing partition spare2... Done. Erasing partition laf... Done. Erasing partition boot... Done. Erasing partition recovery... Done. Erasing partition drm... Done. Erasing partition sns... Done. Erasing partition mpt... Done. Erasing partition eri... Done. Erasing partition raw_resources... Done. Erasing partition raw_resourcesbak... Done. Erasing partition operatorlogging... Done. Erasing partition carrier... Done. Erasing partition felica... Done. Erasing partition factory... Done. Erasing partition spare3... Done. Erasing partition fota... Done. Erasing partition spare4... Done. Erasing partition system... Done. Erasing partition cache... Done. Erasing partition userdata... Done. Erasing partition grow... Done. Erasing is finished. SW: 1.3.2; FW: 1.15. Code: Welcome to Medusa Pro Software version 1.3.2. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Reader #3: Generic EMV Smartcard Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : H811 SRF : D:/JTAG/medusa + pro/medusa pro/LG_H811_EMMC.SRF Voltage : 2.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 032G74 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 1101003033324737340052553F4E4209 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex) 52553F4E Manufacturing date : 04/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Boot partition enable : Device not boot enabled (default) Partition config : 00000000 Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/032G74_02_03_2017_19_12_29.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. Opening E:/LG/H810 downgrad will dead/LGH810AT-00-V10o-ATT-US-SEP-10-2015-ARB02+0_User_Secure.tot file... Signature OK. Signature 2 OK. Open file "E:/LG/H810 downgrad will dead/LGH810AT-00-V10o-ATT-US-SEP-10-2015-ARB02+0_User_Secure.tot". Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition pmic... Done. Writing partition sbl1... Done. Writing partition tz... Done. Writing partition sdi... Done. Writing partition hyp... Done. Writing partition rpm... Done. Writing partition aboot... Done. Writing partition sbl1bak... Done. Writing partition pmicbak... Done. Writing partition tzbak... Done. Writing partition hypbak... Done. Writing partition rpmbak... Done. Writing partition abootbak... Done. Writing partition sdibak... Done. Writing partition misc... Done. Writing partition persist... Done. Writing partition sec... Done. Writing partition rct... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition raw_resources... Done. Writing partition raw_resourcesbak... Done. Writing partition factory... Done. Writing partition BackupGPT... Done. Writing is finished. SW: 1.3.2; FW: 1.15. Last edited by Medusa Box; 03-02-2017 at 22:26. |
03-02-2017, 18:55 | #2 (permalink) |
No Life Poster Join Date: Jul 2012
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | Hello , If your LG H810 has bootloader / firmware 21Y which is android 6.0 I'm afraid your V10o firmware will not work because 21Y cannot be downgraded. You have to find phone with 21Y and read / flash to dead phone. read here: http://forum.gsmhosting.com/vbb/f453...mware-2150692/ |
The Following User Says Thank You to spagman For This Useful Post: |
03-02-2017, 19:04 | #3 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Thanks problem solve Code: Welcome to Medusa Pro Software version 1.3.2. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Reader #3: Generic EMV Smartcard Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : H811 SRF : D:/JTAG/medusa + pro/medusa pro/LG_H811_EMMC.SRF Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : H811 SRF : D:/JTAG/medusa + pro/medusa pro/LG_H811_EMMC.SRF Voltage : 2.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 032G74 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 1101003033324737340052553F4E4209 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex) 52553F4E Manufacturing date : 04/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Boot partition enable : Device not boot enabled (default) Partition config : 00000000 Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/032G74_02_03_2017_20_20_19.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. Opening E:/LG/H810 downgrad will dead/LGH810AT-01-V21y-310-410-JUN-20-2016-ARB03+0.tot file... Signature OK. Signature 2 OK. Open file "E:/LG/H810 downgrad will dead/LGH810AT-01-V21y-310-410-JUN-20-2016-ARB03+0.tot". Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition pmic... Done. Writing partition sbl1... Done. Writing partition tz... Done. Writing partition sdi... Done. Writing partition hyp... Done. Writing partition rpm... Done. Writing partition aboot... Done. Writing partition sbl1bak... Done. Writing partition pmicbak... Done. Writing partition tzbak... Done. Writing partition hypbak... Done. Writing partition rpmbak... Done. Writing partition abootbak... Done. Writing partition sdibak... Done. Writing partition apdp... Done. Writing partition msadp... Done. Writing partition persist... Done. Writing partition sec... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition raw_resources... Done. Writing partition raw_resourcesbak... Done. Writing partition felica... Done. Writing partition factory... Done. Writing is finished. SW: 1.3.2; FW: 1.15. Thanks to Jamil mobile |
The Following 2 Users Say Thank You to maanarman For This Useful Post: |
